[postgis-tickets] [PostGIS] #5090: configure --with-protobuf-lib / --with-protobufdir broken
trac at osgeo.org
Sun Feb 13 15:03:36 PST 2022
Reporter: tbussmann | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.2.1
Component: build/upgrade/install | Version: master
Resolution: fixed | Keywords:
Comment (by tbussmann):
thanks for applying the patches!
> Unfortunately I'm not sure how to test this corner case.
Something among the following may work:
* configure postgis with the {{{--with-protobufdir}}} or {{{--with-
protobuf-lib}}}/{{{--with-protobuf-inc}}} set to your {{{protobuf-c}}}
installation
* without the first patch, the configure will be successful but the build
will fail.
* apply the first patch, repeat configure, verify that it now builds
For the second patch (original intention of #4964):
* remove the {{{libprotobuf-c.pc}}} from your {{{pkgconfig}}} directory
* make sure the {{{protobuf-c}}} library can be found in your default lib
/ include paths
* configure postgis w/o any protbuf related parameters.
* without the second patch, the configure will be successful but the build
will fail.
* apply the second patch, repeat configure, verify that it now builds
Make sure this does not interfere with pkg-config builds (#4977)
* move the {{{libprotobuf-c.pc}}} file back to your {{{pkgconfig}}}
directory
* with the patches applied, configure and build should still be successful
(I think, that was already verified by the CI)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5090#comment:6>
