[postgis-tickets] [PostGIS] #5099: Running make twice compiles again under postgis
trac at osgeo.org
Wed Feb 16 16:39:21 PST 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by strk):
This is what's being re-built:
---- Making all in postgis
make[1]: Entering directory '/home/src/postgis/postgis/build/postgis'
gcc -Wall -Wmissing-prototypes -Wpointer-arith -Wdeclaration-after-
statement -Werror=vla -Wendif-labels -Wmissing-format-attribute
-Wimplicit-fallthrough=3 -Wformat-security -fno-strict-aliasing -fwrapv
-fexcess-precision=standard -Wno-format-truncation -Wno-stringop-
truncation -g -g -O2 -flto=auto -ffat-lto-objects -fstack-protector-strong
-Wformat -Werror=format-security -fno-omit-frame-pointer -fPIC
-I../../liblwgeom -I../liblwgeom -std=gnu99 -O2 -g -Wall -fno-math-errno
-fno-signed-zeros -Wall -I../../libpgcommon -I../../deps/flatgeobuf
-I../../deps/wagyu -I../../deps/uthash/include -I/usr/local/include
-I/usr/include/libxml2 -I/usr/include -I/usr/include/json-c -DNDEBUG
-fPIC -DPIC -I. -I./ -I/usr/include/postgresql/13/server
-I/usr/include/postgresql/internal -Wdate-time -D_FORTIFY_SOURCE=2
-D_GNU_SOURCE -I/usr/include/libxml2 -c -o vector_tile.pb-c.o
vector_tile.pb-c.c
-D_GNU_SOURCE -I/usr/include/libxml2 -c -o geobuf.pb-c.o geobuf.pb-c.c
-Wformat -Werror=format-security -fno-omit-frame-pointer -fPIC -shared -o
postgis-3.3.so postgis_module.o lwgeom_accum.o lwgeom_spheroid.o
lwgeom_ogc.o lwgeom_functions_analytic.o lwgeom_inout.o
lwgeom_functions_basic.o lwgeom_btree.o lwgeom_box.o lwgeom_box3d.o
lwgeom_geos.o lwgeom_geos_prepared.o lwgeom_geos_clean.o
lwgeom_geos_relatematch.o lwgeom_generate_grid.o lwgeom_export.o
lwgeom_in_gml.o lwgeom_in_kml.o lwgeom_in_geohash.o lwgeom_in_geojson.o
lwgeom_in_encoded_polyline.o lwgeom_triggers.o lwgeom_dump.o
lwgeom_dumppoints.o lwgeom_functions_lrs.o lwgeom_functions_temporal.o
lwgeom_rectree.o long_xact.o lwgeom_sqlmm.o lwgeom_rtree.o
lwgeom_transform.o lwgeom_window.o gserialized_typmod.o
gserialized_gist_2d.o gserialized_gist_nd.o gserialized_supportfn.o
gserialized_spgist_2d.o gserialized_spgist_3d.o gserialized_spgist_nd.o
brin_2d.o brin_nd.o brin_common.o gserialized_estimate.o geography_inout.o
geography_btree.o geography_centroid.o geography_measurement.o
geography_measurement_trees.o geometry_inout.o postgis_libprotobuf.o
vector_tile.pb-c.o geobuf.pb-c.o mvt.o lwgeom_out_mvt.o geobuf.o
lwgeom_out_geobuf.o lwgeom_out_geojson.o flatgeobuf.o
lwgeom_in_flatgeobuf.o lwgeom_out_flatgeobuf.o postgis_legacy.o -lm
../deps/wagyu/libwagyu.la -lstdc++ ../deps/flatgeobuf/libflatgeobuf.la
-lstdc++ ../libpgcommon/libpgcommon.a ../liblwgeom/.libs/liblwgeom.a
-L/usr/local/lib -lgeos_c -lproj -ljson-c -lprotobuf-c -lxml2
-L/usr/lib/x86_64-linux-gnu -lSFCGAL -lgmpxx -Wl,--exclude-libs,ALL -lm
So it's basically:
- vector_tile.pb-c.o
- geobuf.pb-c.o
The two object files above, when rebuilt, trigger also rebuilding
postgis-3.3.so
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5099#comment:1>
