[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-555-g478811906
git at osgeo.org
git at osgeo.org
Thu Feb 17 08:49:49 PST 2022
the project "PostGIS".
via 47881190654a6988c5f136f68e55ecf058885f9d (commit)
from 5c679541c62a90ffbb97f2d9bd25b3da3a4dfe27 (commit)
revisions in full, below.
commit 47881190654a6988c5f136f68e55ecf058885f9d
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Feb 17 17:49:12 2022 +0100
Clean more generated files on `make clean`
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 6fa6a8f5a..ed18cbce0 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -49,15 +49,11 @@ all: sql/address_standardizer.sql sql/address_standardizer--1.0--$(EXTVERSION).
sql/$(EXTENSION)_data_us--$(EXTVERSION)next--$(EXTVERSION).sql sql/$(EXTENSION)_data_us--ANY--$(EXTVERSION).sql \
sql/test-init-extensions.sql sql/test-parseaddress.sql sql/test-standardize_address_1.sql sql/test-standardize_address_2.sql
-EXTRA_CLEAN = sql/
DOCS = README.address_standardizer
PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@ -DPCRE_VERSION=@PCRE_VERSION@
SHLIB_LINK = @SHLIB_LINK@ @PCRE_LDFLAGS@
-EXTRA_CLEAN = usps-st-city-name.txt mk-st-regexp mk-city-regex test_main
+EXTRA_CLEAN = sql/ usps-st-city-name.txt mk-st-regexp mk-city-regex test_main
REGRESS = test-init-extensions test-parseaddress test-standardize_address_1 test-standardize_address_2
diff --git a/extensions/postgis_tiger_geocoder/Makefile.in b/extensions/postgis_tiger_geocoder/Makefile.in
index bbf691875..49189aec5 100644
--- a/extensions/postgis_tiger_geocoder/Makefile.in
+++ b/extensions/postgis_tiger_geocoder/Makefile.in
@@ -32,7 +32,7 @@ REGRESS = test-normalize_address test-upgrade
REGRESS_OPTS = --load-extension=fuzzystrmatch --load-extension=postgis --load-extension=$(EXTENSION)
SQL_BITS = $(wildcard sql_bits/*.sql)
-EXTRA_CLEAN = sql ${SQL_BITS}
+EXTRA_CLEAN = sql expected ${SQL_BITS}
#test address standardizer if also built
ifeq (@ADDRESS_STANDARDIZER@,address_standardizer)
@@ -76,7 +76,7 @@ expected/test-upgrade.out: sql/test-upgrade.sql | expected
sql/test-pagc_normalize_address.sql: sql_bits/test_tuples_only_unaligned.sql.in ../../extras/tiger_geocoder/regress/pagc_normalize_address_regress.sql | sql
cat $^ > $@
-sql/$(EXTENSION).sql: sql_bits/tiger_geocoder.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
+sql/$(EXTENSION).sql: sql/tiger_geocoder.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
cat $^ > $@
sql/$(EXTENSION)--ANY--$(EXTVERSION).sql: ../postgis_extension_helper.sql sql_bits/remove_from_extension.sql.in sql/tiger_geocoder_upgrade_minor.sql sql_bits/mark_editable_objects.sql.in sql_bits/tiger_geocoder_comments.sql | sql
@@ -126,7 +126,7 @@ sql/tiger_geocoder_minor.sql.in: ../../extras/tiger_geocoder/utility/set_search_
cat $^ > $@
#also remove tiger_data from extension if it is part of it so data gets backed up
-sql_bits/tiger_geocoder.sql.in: sql_bits/norm_addy_create.sql.in \
+sql/tiger_geocoder.sql.in: sql_bits/norm_addy_create.sql.in \
../../extras/tiger_geocoder/utility/set_search_path.sql \
../../extras/tiger_geocoder/geocode_settings.sql \
../../extras/tiger_geocoder/tables/lookup_tables_2011.sql \
@@ -161,19 +161,16 @@ sql_bits/tiger_geocoder.sql.in: sql_bits/norm_addy_create.sql.in \
../../extras/tiger_geocoder/geocode/census_tracts_functions.sql \
../../extras/tiger_geocoder/topology/tiger_topology_loader.sql \
../postgis_extension_helper.sql \
- sql_bits/add_search_path.sql
- mkdir -p sql_bits
+ sql/add_search_path.sql | sql
cat $^ > $@
echo "SELECT postgis_extension_drop_if_exists('${EXTENSION}', 'DROP SCHEMA tiger_data');" >> $@
cat @srcdir@/../postgis_extension_helper_uninstall.sql >> $@
-sql_bits/tiger_geocoder.sql: sql_bits/tiger_geocoder.sql.in
- mkdir -p sql_bits
+sql/tiger_geocoder.sql: sql/tiger_geocoder.sql.in
sed -e 's/BEGIN;//g' -e 's/COMMIT;//g' -e '/^CREATE SCHEMA/d;' $< > $@
$(PERL) -pe 's/BEGIN\;//g ; s/COMMIT\;//g' $< > $@
-sql_bits/add_search_path.sql: sql_bits/add_search_path.sql.in
- mkdir -p sql_bits
+sql/add_search_path.sql: sql_bits/add_search_path.sql.in
cp $< $@
../../doc/tiger_geocoder_comments.sql:
@@ -183,20 +180,6 @@ sql_bits/tiger_geocoder_comments.sql: ../../doc/tiger_geocoder_comments.sql
mkdir -p sql_bits
cp $< $@
-#grep all lines that start with CREATE OR REPLACE FUNCTION, TRIGGER...
-#then replace CREATE OR REPLACE .. with ALTER EXTENSION..;
-#then remove default values and extra junk
-# sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: ../../tiger_geocoder/tiger_geocoder.sql
-# sed -e '/^CREATE \(OR REPLACE\|TYPE\|TABLE\|VIEW\|CAST\)/!d;' \
-# -e 's/OR REPLACE//g' \
-# -e 's/CREATE\(.*\)/ALTER EXTENSION $(EXTENSION) ADD\1;/' \
-# -e 's/DEFAULT [\.0-9a-zA-Z]\+//g' \
-# -e 's/\(BEFORE\|WITH FUNCTION\)\(.*\)/;/' \
-# -e 's/[ \t]+;/;/' \
-# -e 's/(;/;/' \
-# -e 's/\\(;/;/' \
-# -e 's/;;/;/g' $< > $@
#hardcode for now
#TODO: generate via create_unpackaged.pl
sql/$(EXTENSION)--unpackaged--$(EXTVERSION).sql: sql_bits/tiger_geocoder--unpackaged.sql.in | sql
Summary of changes:
extensions/address_standardizer/Makefile.in | 6 +-----
extensions/postgis_tiger_geocoder/Makefile.in | 29 ++++++---------------------
2 files changed, 7 insertions(+), 28 deletions(-)
hooks/post-receive
