[postgis-tickets] [PostGIS] #5100: Installation failure with PostgreSQL v15 (no more pg_atoi)
PostGIS trac at osgeo.org
Fri Feb 18 05:38:53 PST 2022
  Reporter:  robe                   |      Owner:  pramsey
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.0
 Component:  build/upgrade/install  |    Version:  3.2.x
Resolution:                         |   Keywords:
Comment (by Laurenz Albe):
 PostgreSQL
 [https://git.postgresql.org/gitweb/?p=postgresql.git;a=commitdiff;h=73508475d69e90f98ebd9b7e1a5933a26a49c5e9
 commit 73508475d69e90f98ebd9b7e1a5933a26a49c5e9] has removed `pg_atoi`, so
 building or creating the extension fails.
 The attached patch fixes the problem. This should be applied to all
 branches.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5100#comment:3>
