[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-586-g5698ad18a
git at osgeo.org
git at osgeo.org
Sat Feb 19 11:18:10 PST 2022
the project "PostGIS".
via 5698ad18aa32c30892f26c10e01ca6d79210de52 (commit)
from 5365111ef1120cc396ef8bac2d2511628b1f67a0 (commit)
revisions in full, below.
commit 5698ad18aa32c30892f26c10e01ca6d79210de52
Author: Regina Obe <lr at pcorp.us>
Date: Sat Feb 19 14:15:00 2022 -0500
MVT refactor from Victor Collod
References https://git.osgeo.org/gitea/postgis/postgis/pulls/93
for PostGIS 3.3.0
Squashed commit of the following:
commit 7d8d390ae6a4cd7a798aa4c4ff7831d9a276b4c6
Author: Victor "multun" Collod <victor.collod at epita.fr>
Date: Wed Feb 9 16:06:09 2022 +0100
mvt: restrict the ownership of the feature being built
mvt: refactor and comment mvt_agg_transfn
mvt: remove the ctx parameter of encode_ptarray{,_initial}
diff --git a/postgis/mvt.c b/postgis/mvt.c
index 4f5f9e87a..4ae8e6a5f 100644
--- a/postgis/mvt.c
+++ b/postgis/mvt.c
@@ -83,9 +83,7 @@ static inline uint32_t p_int(int32_t value)
return (value << 1) ^ (value >> 31);
-static uint32_t encode_ptarray(__attribute__((__unused__)) mvt_agg_context *ctx,
- enum mvt_type type, POINTARRAY *pa, uint32_t *buffer,
- int32_t *px, int32_t *py)
+static uint32_t encode_ptarray(enum mvt_type type, POINTARRAY *pa, uint32_t *buffer, int32_t *px, int32_t *py)
uint32_t offset = 0;
uint32_t i, c = 0;
@@ -134,88 +132,80 @@ static uint32_t encode_ptarray(__attribute__((__unused__)) mvt_agg_context *ctx,
return offset;
-static uint32_t encode_ptarray_initial(mvt_agg_context *ctx,
- POINTARRAY *pa, uint32_t *buffer)
+static uint32_t encode_ptarray_initial(enum mvt_type type, POINTARRAY *pa, uint32_t *buffer)
int32_t px = 0, py = 0;
- return encode_ptarray(ctx, type, pa, buffer, &px, &py);
+ return encode_ptarray(type, pa, buffer, &px, &py);
-static void encode_point(mvt_agg_context *ctx, LWPOINT *point)
+static void encode_point(VectorTile__Tile__Feature *feature, LWPOINT *point)
- VectorTile__Tile__Feature *feature = ctx->feature;
feature->type = VECTOR_TILE__TILE__GEOM_TYPE__POINT;
feature->n_geometry = 3;
feature->geometry = palloc(sizeof(*feature->geometry) * 3);
- encode_ptarray_initial(ctx, MVT_POINT, point->point, feature->geometry);
+ encode_ptarray_initial(MVT_POINT, point->point, feature->geometry);
-static void encode_mpoint(mvt_agg_context *ctx, LWMPOINT *mpoint)
+static void encode_mpoint(VectorTile__Tile__Feature *feature, LWMPOINT *mpoint)
size_t c;
// NOTE: inefficient shortcut LWMPOINT->LWLINE
LWLINE *lwline = lwline_from_lwmpoint(mpoint->srid, mpoint);
c = 1 + lwline->points->npoints * 2;
feature->geometry = palloc(sizeof(*feature->geometry) * c);
- feature->n_geometry = encode_ptarray_initial(ctx, MVT_POINT,
+ feature->n_geometry = encode_ptarray_initial(MVT_POINT,
lwline->points, feature->geometry);
-static void encode_line(mvt_agg_context *ctx, LWLINE *lwline)
+static void encode_line(VectorTile__Tile__Feature *feature, LWLINE *lwline)
size_t c;
feature->type = VECTOR_TILE__TILE__GEOM_TYPE__LINESTRING;
c = 2 + lwline->points->npoints * 2;
- feature->n_geometry = encode_ptarray_initial(ctx, MVT_LINE,
+ feature->n_geometry = encode_ptarray_initial(MVT_LINE,
-static void encode_mline(mvt_agg_context *ctx, LWMLINE *lwmline)
+static void encode_mline(VectorTile__Tile__Feature *feature, LWMLINE *lwmline)
uint32_t i;
size_t c = 0, offset = 0;
for (i = 0; i < lwmline->ngeoms; i++)
c += 2 + lwmline->geoms[i]->points->npoints * 2;
- offset += encode_ptarray(ctx, MVT_LINE,
+ offset += encode_ptarray(MVT_LINE,
lwmline->geoms[i]->points,
feature->geometry + offset, &px, &py);
feature->n_geometry = offset;
-static void encode_poly(mvt_agg_context *ctx, LWPOLY *lwpoly)
+static void encode_poly(VectorTile__Tile__Feature *feature, LWPOLY *lwpoly)
uint32_t i;
feature->type = VECTOR_TILE__TILE__GEOM_TYPE__POLYGON;
for (i = 0; i < lwpoly->nrings; i++)
c += 3 + ((lwpoly->rings[i]->npoints - 1) * 2);
- offset += encode_ptarray(ctx, MVT_RING,
+ offset += encode_ptarray(MVT_RING,
lwpoly->rings[i],
-static void encode_mpoly(mvt_agg_context *ctx, LWMPOLY *lwmpoly)
+static void encode_mpoly(VectorTile__Tile__Feature *feature, LWMPOLY *lwmpoly)
uint32_t i, j;
LWPOLY *poly;
for (i = 0; i < lwmpoly->ngeoms; i++)
for (j = 0; poly = lwmpoly->geoms[i], j < poly->nrings; j++)
@@ -223,31 +213,31 @@ static void encode_mpoly(mvt_agg_context *ctx, LWMPOLY *lwmpoly)
poly->rings[j], feature->geometry + offset,
&px, &py);
-static void encode_geometry(mvt_agg_context *ctx, LWGEOM *lwgeom)
+static void encode_feature_geometry(VectorTile__Tile__Feature *feature, LWGEOM *lwgeom)
int type = lwgeom->type;
switch (type)
case POINTTYPE:
- return encode_point(ctx, (LWPOINT*)lwgeom);
+ return encode_point(feature, (LWPOINT*)lwgeom);
case LINETYPE:
- return encode_line(ctx, (LWLINE*)lwgeom);
+ return encode_line(feature, (LWLINE*)lwgeom);
case POLYGONTYPE:
- return encode_poly(ctx, (LWPOLY*)lwgeom);
+ return encode_poly(feature, (LWPOLY*)lwgeom);
case MULTIPOINTTYPE:
- return encode_mpoint(ctx, (LWMPOINT*)lwgeom);
+ return encode_mpoint(feature, (LWMPOINT*)lwgeom);
case MULTILINETYPE:
- return encode_mline(ctx, (LWMLINE*)lwgeom);
+ return encode_mline(feature, (LWMLINE*)lwgeom);
case MULTIPOLYGONTYPE:
- return encode_mpoly(ctx, (LWMPOLY*)lwgeom);
- default: elog(ERROR, "encode_geometry: '%s' geometry type not supported",
+ return encode_mpoly(feature, (LWMPOLY*)lwgeom);
+ default: elog(ERROR, "encode_feature_geometry: '%s' geometry type not supported",
lwtype_name(type));
@@ -588,7 +578,7 @@ static uint32_t *parse_jsonb(mvt_agg_context *ctx, Jsonb *jb,
* Sets the feature id. Ignores Nulls and negative values
-static void set_feature_id(mvt_agg_context *ctx, Datum datum, bool isNull)
+static void set_feature_id(mvt_agg_context *ctx, VectorTile__Tile__Feature *feature, Datum datum, bool isNull)
Oid typoid = ctx->column_cache.column_oid[ctx->id_index];
int64_t value = INT64_MIN;
@@ -620,11 +610,11 @@ static void set_feature_id(mvt_agg_context *ctx, Datum datum, bool isNull)
return;
- ctx->feature->has_id = true;
- ctx->feature->id = (uint64_t) value;
+ feature->has_id = true;
+ feature->id = (uint64_t) value;
-static void parse_values(mvt_agg_context *ctx)
+static void parse_values(mvt_agg_context *ctx, VectorTile__Tile__Feature *feature)
uint32_t n_keys = ctx->keys_hash_i;
uint32_t *tags = palloc(n_keys * 2 * sizeof(*tags));
@@ -660,7 +650,7 @@ static void parse_values(mvt_agg_context *ctx)
if (i == ctx->id_index)
- set_feature_id(ctx, datum, cc.nulls[i]);
+ set_feature_id(ctx, feature, datum, cc.nulls[i]);
continue;
@@ -732,10 +722,10 @@ static void parse_values(mvt_agg_context *ctx)
- ctx->feature->n_tags = ctx->row_columns * 2;
- ctx->feature->tags = tags;
+ feature->n_tags = ctx->row_columns * 2;
+ feature->tags = tags;
- POSTGIS_DEBUGF(3, "parse_values n_tags %zd", ctx->feature->n_tags);
+ POSTGIS_DEBUGF(3, "parse_values n_tags %zd", feature->n_tags);
/* For a given geometry, look for the highest dimensional basic type, that is,
@@ -991,7 +981,7 @@ void mvt_agg_init_context(mvt_agg_context *ctx)
- * Aggregation step.
+ * Aggregation step. Parse a row, turn it into a feature, and add it to the layer.
* Expands features array if needed by a factor of 2.
* Allocates a new feature, increment feature counter and
@@ -1005,46 +995,42 @@ void mvt_agg_transfn(mvt_agg_context *ctx)
LWGEOM *lwgeom;
VectorTile__Tile__Feature *feature;
VectorTile__Tile__Layer *layer = ctx->layer;
-/* VectorTile__Tile__Feature **features = layer->features; */
POSTGIS_DEBUG(2, "mvt_agg_transfn called");
- if (layer->n_features >= ctx->features_capacity)
- size_t new_capacity = ctx->features_capacity * 2;
- layer->features = repalloc(layer->features, new_capacity *
- sizeof(*layer->features));
- ctx->features_capacity = new_capacity;
- POSTGIS_DEBUGF(3, "mvt_agg_transfn new_capacity: %zd", new_capacity);
+ /* geom_index is the cached index of the geometry. if missing, it needs to be initialized */
if (ctx->geom_index == UINT32_MAX)
parse_column_keys(ctx);
+ /* Get the geometry column */
datum = GetAttributeByNum(ctx->row, ctx->geom_index + 1, &isnull);
- POSTGIS_DEBUGF(3, "mvt_agg_transfn ctx->geom_index: %d", ctx->geom_index);
- POSTGIS_DEBUGF(3, "mvt_agg_transfn isnull: %u", isnull);
- POSTGIS_DEBUGF(3, "mvt_agg_transfn datum: %lu", datum);
if (isnull) /* Skip rows that have null geometry */
- POSTGIS_DEBUG(3, "mvt_agg_transfn got null geom");
return;
+ /* Allocate a new feature object */
feature = palloc(sizeof(*feature));
vector_tile__tile__feature__init(feature);
- ctx->feature = feature;
+ /* Deserialize the geometry */
gs = (GSERIALIZED *) PG_DETOAST_DATUM(datum);
lwgeom = lwgeom_from_gserialized(gs);
+ /* Add the feature to the result */
POSTGIS_DEBUGF(3, "mvt_agg_transfn encoded feature count: %zd", layer->n_features);
+ if (layer->n_features >= ctx->features_capacity)
+ size_t new_capacity = ctx->features_capacity * 2;
+ layer->features = repalloc(layer->features, new_capacity *
+ sizeof(*layer->features));
+ ctx->features_capacity = new_capacity;
+ POSTGIS_DEBUGF(3, "mvt_agg_transfn new_capacity: %zd", new_capacity);
layer->features[layer->n_features++] = feature;
- encode_geometry(ctx, lwgeom);
+ /* Set the geometry of the feature */
+ encode_feature_geometry(feature, lwgeom);
lwgeom_free(lwgeom);
// TODO: free detoasted datum?
- parse_values(ctx);
+ parse_values(ctx, feature);
static VectorTile__Tile * mvt_ctx_to_tile(mvt_agg_context *ctx)
diff --git a/postgis/mvt.h b/postgis/mvt.h
index fe4a87841..11d5dd922 100644
--- a/postgis/mvt.h
+++ b/postgis/mvt.h
@@ -72,7 +72,6 @@ typedef struct mvt_agg_context
uint32_t geom_index;
HeapTupleHeader row;
- VectorTile__Tile__Feature *feature;
VectorTile__Tile__Layer *layer;
VectorTile__Tile *tile;
size_t features_capacity;
Summary of changes:
postgis/mvt.c | 110 +++++++++++++++++++++++++---------------------------------
postgis/mvt.h | 1 -
2 files changed, 48 insertions(+), 63 deletions(-)
hooks/post-receive
