[postgis-tickets] [PostGIS] #5102: CopyTopology: ERROR: column "geom" is of type geometry but expression is of type integer
PostGIS trac at osgeo.org
Tue Feb 22 04:55:13 PST 2022
of type integer
 Reporter:  strk      |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  blocker   |  Milestone:  PostGIS 3.3.0
Component:  topology  |    Version:  master
 Keywords:            |
 Starting with commit [6893c542220566e29445faf6b2de2b54aca77169/git] the
 order of fields in the topology primitive tables changed, which in turn
 broke CopyTopology code assuming new and old topologies having the same
 structure.
 We should probably maintain the same structure, to be backward
 compatibility with external code, but avoiding the assumption in internal
 code would be also a good thing.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5102>
