[postgis-tickets] [SCM] postgis.net branch hugo updated. f04dd4491681ebb386a48549bc2a7c7f2e4ee752
git at osgeo.org
git at osgeo.org
Wed Feb 23 10:02:01 PST 2022
the project "postgis.net".
The branch, hugo has been updated
via f04dd4491681ebb386a48549bc2a7c7f2e4ee752 (commit)
from 4d623ac4044da9c6cef71487c0685ba444cb1d2f (commit)
revisions in full, below.
commit f04dd4491681ebb386a48549bc2a7c7f2e4ee752
Author: Regina Obe <lr at pcorp.us>
Date: Wed Feb 23 12:43:13 2022 -0500
add postgis variables and reformat for 2 column some docs
diff --git a/config/_default/config.toml b/config/_default/config.toml
index a3d8f25..9a67be7 100644
--- a/config/_default/config.toml
+++ b/config/_default/config.toml
@@ -1,13 +1,18 @@
baseurl = "https://postgis.net/"
+root = "https://postgis.net/"
languageCode = "en-us"
title = "PostGIS: Spatial and Geographic objects for PostgreSQL"
theme = "hugo-clarity"
paginate = 10
disqusShortname = ""
-[params]
-description = "PostGIS provides spatial objects for the PostgreSQL database, allowing storage and query of information about location and mapping."
-keywords = ["postgis", "database", "spatial", "sql", "mapping", "queries", "gis", "geocoding", "routing", "raster", "opensource gis"]
-enableRobotsTXT = true
+[postgis]
+version = "3.2.1"
+release_docs = "https://download.osgeo.org/postgis/docs"
+release_source = "https://download.osgeo.org/postgis/source"
+release_notes = "https://git.osgeo.org/gitea/postgis/postgis/raw/tag"
+dev_download = "/stuff"
[taxonomies]
category = "categories"
diff --git a/config/_default/params.toml b/config/_default/params.toml
index e0e36c8..4e43599 100644
--- a/config/_default/params.toml
+++ b/config/_default/params.toml
@@ -1,8 +1,10 @@
twitter = "@postgis"
+description = "PostGIS provides spatial objects for the PostgreSQL database, allowing storage and query of information about location and mapping."
+keywords = ["postgis", "database", "spatial", "sql", "mapping", "queries", "gis", "geocoding", "routing", "raster", "opensource gis"]
+enableRobotsTXT = true
largeTwitterCard = false # set to true if you want to show a large twitter card image. The default is a small twitter card image
-introDescription = "Technologist, perpetual student, teacher, continual incremental improvement."
+introDescription = "PostGIS provides spatial objects for the PostgreSQL database, allowing storage and query of information about location and mapping."
introURL = "index/" # set the url for the 'read more' button below the introDescription, or set to false to not show the button
-# description = "" # set your site's description here. will be use for home page content meta tags (seo). Alternatively set this description in your homepage content file i.e content/_index.md. Whatever is set in the latter will take precedence
# showShare = false # Uncomment to not show share buttons on each post. Also available in each post's front matter.
diff --git a/content/pages/development.md b/content/pages/development.md
index 57b7d57..1a576aa 100644
--- a/content/pages/development.md
+++ b/content/pages/development.md
@@ -16,7 +16,7 @@ PostGIS adds extra types (geometry, geography, raster and others) to the [Postgr
Since PostGIS is in C, it can make use of other libraries in C and C++, and it does so liberally. PostGIS depends on:
* [GEOS](http://trac.osgeo.org/geos) for many geometry processing algorithms
-* [Proj.4](https://trac.osgeo.org/proj/) for coordinate re-projection functions
+* [Proj](https://trac.osgeo.org/proj/) for coordinate re-projection functions
* [GDAL](http://gdal.org) for raster processing and format support
* [LibXML2](http://www.xmlsoft.org/) for XML parsing
* [JSON-C](https://github.com/json-c/json-c) for JSON parsing
diff --git a/content/pages/documentation.md b/content/pages/documentation.md
index 35da695..97abdab 100644
--- a/content/pages/documentation.md
+++ b/content/pages/documentation.md
@@ -6,8 +6,10 @@ buildbot_pre_release_docs:
buildbot_pre_release_trunk:
has_tags: [trunk, pre_release_source]
draft: false
+singlecolumn: true
+sidebar: false
+{{< columns >}}
## Stable Branch User Documentation
This documentation is for the released branches and will contain corrections and errata as they are available
@@ -31,7 +33,7 @@ Refer to our [Version compatibility and EOL Policy]({{ pcurl('eol_policy') }}) f
Versions that have reached end of life can still be downloaded from [PostGIS Release docs]({{postgis.release_docs}}).
---column--
+---column---
# Search Docs
Type search criteria here and enter:
@@ -69,6 +71,6 @@ window.location.href=url;
* [Planet PostGIS](http://planet.postgis.net) - keep a pulse on what people are saying about PostGIS and learn how to take advantage of new features as they are added.
* [GIS Stack Exchange](http://gis.stackexchange.com/questions/tagged/postgis) may already have your answer: search before you ask!
+{{< / columns >}}
diff --git a/content/pages/install.md b/content/pages/install.md
index a935e53..fe79f8f 100644
--- a/content/pages/install.md
+++ b/content/pages/install.md
@@ -3,7 +3,10 @@ title: Installation
description: How to install PostGIS and where to download PostGIS binaries
keywords: download, install
draft: false
+singlecolumn: true
+sidebar: false
+{{< columns >}}
# Compiling from Source
PostGIS has many packaged installations, but if you are more adventurous
and want to compile your own, refer to our source download and compilation
@@ -59,7 +62,7 @@ Binary distributions of PostGIS are available for various operating systems.
## Additional Install Guides
* [Source, Yum and other installs for latest and older versions of PostGIS](http://trac.osgeo.org/postgis/wiki/UsersWikiInstall)
----sidebar---
+---column---
# Getting Started
@@ -153,3 +156,4 @@ WHERE ST_DWithin(
ST_GeomFromText('POINT(0 0)', 26910),
1000
);{{< / highlight >}}
+{{< /columns >}}
diff --git a/content/pages/source.md b/content/pages/source.md
index 0a47d5f..8b64c7d 100644
--- a/content/pages/source.md
+++ b/content/pages/source.md
@@ -7,7 +7,7 @@ singlecolumn: true
# Source Code
The latest source code and companion user doc releases are:
-* [postgis-3.1.0alpah1.tar.gz]({{postgis.release_source}}/postgis-3.1.0alpah1.tar.gz) [pdf]({{postgis.release_docs}}/postgis-3.1.0alpah1.pdf) [html]({{postgis.release_docs}}/doc-html-3.1.0alpah1.tar.gz) ([Release Notes]({{postgis.release_notes}}/3.1.0alpha1/NEWS))
+* [postgis-3.1.0alpah1.tar.gz]({{ .Site.postgis.release_source }}/postgis-3.1.0alpah1.tar.gz) [pdf]({{postgis.release_docs}}/postgis-3.1.0alpah1.pdf) [html]({{postgis.release_docs}}/doc-html-3.1.0alpah1.tar.gz) ([Release Notes]({{postgis.release_notes}}/3.1.0alpha1/NEWS))
* [postgis-{{ postgis.version }}.tar.gz]({{postgis.release_source}}/postgis-{{ postgis.version }}.tar.gz) [pdf]({{postgis.release_docs}}/postgis-{{ postgis.version }}.pdf) [html]({{postgis.release_docs}}/doc-html-{{ postgis.version }}.tar.gz) ([Release Notes]({{postgis.release_notes}}/{{ postgis.version }}/NEWS))
* [postgis-2.5.4.tar.gz]({{postgis.release_source}}/postgis-2.5.4.tar.gz) [pdf]({{postgis.release_docs}}/postgis-2.5.4.pdf) [html]({{postgis.release_docs}}/doc-html-2.5.4.tar.gz) ([Release Notes]({{postgis.release_notes}}/2.5.4/NEWS))
* [postgis-2.4.8.tar.gz]({{postgis.release_source}}/postgis-2.4.8.tar.gz) [pdf]({{postgis.release_docs}}/postgis-2.4.8.pdf) [html]({{postgis.release_docs}}/doc-html-2.4.8.tar.gz) ([Release Notes]({{postgis.release_notes}}/2.4.8/NEWS))
Summary of changes:
config/_default/config.toml | 13 +++++++++----
config/_default/params.toml | 6 ++++--
content/pages/development.md | 2 +-
content/pages/documentation.md | 8 +++++---
content/pages/install.md | 6 +++++-
content/pages/source.md | 2 +-
6 files changed, 25 insertions(+), 12 deletions(-)
hooks/post-receive
postgis.net
