[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-597-g5f0dae2c6
git at osgeo.org
git at osgeo.org
Wed Feb 23 12:37:32 PST 2022
the project "PostGIS".
via 5f0dae2c6df72a3f2c42571aea08361eb2bba88a (commit)
from 03ed1f3a27760f540a7ca486f68ee9550bf602e0 (commit)
revisions in full, below.
commit 5f0dae2c6df72a3f2c42571aea08361eb2bba88a
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Feb 23 21:36:49 2022 +0100
Have top-level Makefile use build/ directory for building
diff --git a/.gitignore b/.gitignore
index c69659617..09f09a9cb 100644
--- a/.gitignore
+++ b/.gitignore
@@ -15,6 +15,7 @@ gmon.out
postgis_revision.h
aclocal.m4
autom4te.cache/
+build/
build-aux/
config.log
config.guess
diff --git a/Makefile b/Makefile
index 7ccdb648b..0c7aa3a61 100644
--- a/Makefile
+++ b/Makefile
@@ -2,7 +2,7 @@
# this file copied and adapted from PostgreSQL source
# to allow easy build on BSD systems
-all install uninstall clean distclean maintainer-clean test check docs docs-install docs-uninstall utils: GNUmakefile
+all install uninstall staged-install clean distclean maintainer-clean test check docs docs-install docs-uninstall utils: build/GNUmakefile
@IFS=':' ; \
for dir in $$PATH; do \
for prog in gmake gnumake make; do \
@@ -15,14 +15,17 @@ all install uninstall clean distclean maintainer-clean test check docs docs-inst
if [ x"$${GMAKE+set}" = xset ]; then \
echo "Using GNU make found at $${GMAKE}"; \
- $${GMAKE} $@ ; \
+ $${GMAKE} -C build/ $@ ; \
else \
echo "You must use GNU make to build PostGIS." ; \
false; \
fi
-configure: configure.in
+configure: configure.ac
./autogen.sh
-GNUmakefile: GNUmakefile.in
- ./configure
+build-dir:
+ mkdir -p build
+build/GNUmakefile: configure | build-dir
+ cd build && ../configure
Summary of changes:
.gitignore | 1 +
Makefile | 13 ++++++++-----
2 files changed, 9 insertions(+), 5 deletions(-)
hooks/post-receive
