[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-611-g79ab2e2ba
git at osgeo.org
git at osgeo.org
Fri Feb 25 03:03:48 PST 2022
the project "PostGIS".
via 79ab2e2ba50ec373053be5aee55f2d4853a17399 (commit)
via 784f393bbc52fa7b9c4a9591dbecda366a344b82 (commit)
via a9214782dbc8b35f86526c3822d777ac7bb092f5 (commit)
via ec2513dae7b3ac5d6fddb4a44ba4e33a6efba774 (commit)
via 7fd8bf5829d0d95fdda518635e47f5aaeb3947e6 (commit)
from 62e5bf1177595eee23190fc4be4ad6011778f0c7 (commit)
revisions in full, below.
commit 79ab2e2ba50ec373053be5aee55f2d4853a17399
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Feb 17 18:46:00 2022 +0100
[gitlab-ci] Test distclean
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index e57fd2aa1..057eb2c4c 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -30,6 +30,8 @@
- make install
- RUNTESTFLAGS=-v make installcheck
- RUNTESTFLAGS="-v --dumprestore" make installcheck
+ - make distclean
+ - ${SRCDIR}/utils/check_distclean.sh
test:
image: debian:buster
commit 784f393bbc52fa7b9c4a9591dbecda366a344b82
Date: Wed Feb 23 22:38:10 2022 +0100
Clean topology test subdir on make clean/distclean
diff --git a/topology/Makefile.in b/topology/Makefile.in
index 25677d253..28d5494f8 100644
--- a/topology/Makefile.in
+++ b/topology/Makefile.in
@@ -149,5 +149,10 @@ check-regress: topology.sql
check: check-regress
+clean: clean-subdirs
+clean-subdirs:
+ $(MAKE) -C test clean
distclean: clean
rm -f Makefile test/Makefile
commit a9214782dbc8b35f86526c3822d777ac7bb092f5
Date: Wed Feb 23 22:05:29 2022 +0100
Do not create sfcgal Makefiles if sfcgal is disabled
diff --git a/configure.ac b/configure.ac
index 586d5da3a..d9335d716 100644
--- a/configure.ac
+++ b/configure.ac
@@ -798,9 +798,10 @@ if test "x$with_sfcgal" != "xno"; then
if test "x$SFCGAL_STATIC" = "xON"; then
AC_MSG_WARN([The SFCGAL version found is not installed as a dynamic library.])
else
- SFCGAL="sfcgal"
+ SFCGAL="sfcgal"
HAVE_SFCGAL="yes"
- AC_DEFINE([HAVE_SFCGAL], [1], [Define to 1 if sfcgal is being built])
+ AC_DEFINE([HAVE_SFCGAL], [1], [Define to 1 if sfcgal is being built])
+ SFCGAL_MAKEFILE_LIST="sfcgal/Makefile sfcgal/regress/Makefile extensions/postgis_sfcgal/Makefile"
fi
if test ! "$POSTGIS_SFCGAL_VERSION" -ge 10301; then
AC_MSG_ERROR([PostGIS requires SFCGAL >= 1.3.1 (found $SFCGAL_VERSION)])
@@ -1710,7 +1711,6 @@ AC_CONFIG_FILES([GNUmakefile
extensions/Makefile
extensions/postgis/Makefile
extensions/postgis_raster/Makefile
- extensions/postgis_sfcgal/Makefile
extensions/postgis_topology/Makefile
extensions/postgis_tiger_geocoder/Makefile
extensions/address_standardizer/Makefile
@@ -1721,8 +1721,7 @@ AC_CONFIG_FILES([GNUmakefile
libpgcommon/cunit/Makefile
postgis/Makefile
postgis/sqldefines.h
- sfcgal/Makefile
- sfcgal/regress/Makefile
+ $SFCGAL_MAKEFILE_LIST
loader/Makefile
loader/cunit/Makefile
topology/Makefile
commit ec2513dae7b3ac5d6fddb4a44ba4e33a6efba774
Date: Fri Feb 25 10:48:37 2022 +0100
Add check_distclean utility script
diff --git a/utils/check_distclean.sh b/utils/check_distclean.sh
new file mode 100755
index 000000000..05ee73286
--- /dev/null
+++ b/utils/check_distclean.sh
@@ -0,0 +1,38 @@
+#!/bin/sh
+TMPDIR="/tmp/postgis_check_distclean_$$"
+cleanup()
+ #echo "${TMPDIR} has things"
+ rm -rf ${TMPDIR}
+trap 'cleanup' 0
+mkdir -p $TMPDIR
+find . -type f | sort > ${TMPDIR}/leftover_files_after_distclean
+cat <<EOF > ${TMPDIR}/leftover_files_after_distclean.expected
+./doc/postgis_comments.sql
+./doc/raster_comments.sql
+./doc/sfcgal_comments.sql
+./doc/tiger_geocoder_comments.sql
+./doc/topology_comments.sql
+./liblwgeom/lwin_wkt_lex.c
+./liblwgeom/lwin_wkt_parse.c
+./liblwgeom/lwin_wkt_parse.h
+./postgis_revision.h
+EOF
+fgrep -vf \
+ ${TMPDIR}/leftover_files_after_distclean.expected \
+ ${TMPDIR}/leftover_files_after_distclean > \
+ ${TMPDIR}/unexpected_leftovers
+if test $(cat ${TMPDIR}/unexpected_leftovers | wc -l) != 0; then
+ echo "Unexpected left over files after distclean:" >&2
+ cat ${TMPDIR}/unexpected_leftovers >&2
+ false
+fi
commit 7fd8bf5829d0d95fdda518635e47f5aaeb3947e6
Date: Thu Feb 17 18:57:42 2022 +0100
[gitlab-ci] Drop LONG_INT print (debug leftover?)
index b91e1b9fa..e57fd2aa1 100644
@@ -11,7 +11,6 @@
libprotobuf-c1 libprotobuf-c-dev protobuf-c-compiler
- lsb_release -a
- uname -a
- - echo "LONG INT is "`getconf LONG_BIT`"bit"
- service postgresql start
- su -l postgres -c "createuser -s `whoami`"
script:
Summary of changes:
.gitlab-ci.yml | 3 ++-
configure.ac | 9 ++++-----
topology/Makefile.in | 5 +++++
utils/check_distclean.sh | 38 ++++++++++++++++++++++++++++++++++++++
4 files changed, 49 insertions(+), 6 deletions(-)
create mode 100755 utils/check_distclean.sh
hooks/post-receive
