[postgis-tickets] [PostGIS] #5100: Installation failure with PostgreSQL v15 (no more pg_atoi)
PostGIS trac at osgeo.org
Fri Feb 25 07:09:19 PST 2022
  Reporter:  robe                   |      Owner:  robe
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.1.6
 Component:  build/upgrade/install  |    Version:  3.2.x
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"f1e799c7ee4a76f0d1029f91983f9dd2e05db8fe/git" f1e799c/git]:
 #!CommitTicketReference repository="git"
 revision="f1e799c7ee4a76f0d1029f91983f9dd2e05db8fe"
 Stop using pg_atoi, removed in PG 15
 Closes #5100 for PostGIS 3.1.6
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5100#comment:11>
