[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-613-g863242c5a
Fri Feb 25 08:29:37 PST 2022
the project "PostGIS".
       via  863242c5a0e7b64e2772b9857d56a0991f7e5e75 (commit)
      from  238d5803776169a17c0677750434713de9986ebf (commit)
revisions in full, below.
commit 863242c5a0e7b64e2772b9857d56a0991f7e5e75
Author: Chen <onsummer at foxmail.com>
Date:   Fri Feb 25 16:29:34 2022 +0000
    Added translation using Weblate (Chinese (Simplified))
diff --git a/doc/po/zh_Hans/installation.xml.po b/doc/po/zh_Hans/installation.xml.po
new file mode 100644
index 000000000..5b83d9463
--- /dev/null
+++ b/doc/po/zh_Hans/installation.xml.po
@@ -0,0 +1,2322 @@
+# SOME DESCRIPTIVE TITLE.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
+"POT-Creation-Date: 2022-01-25 19:29+0000\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: Automatically generated\n"
+"Language-Team: none\n"
+"Language: zh_Hans\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+#. Tag: title
+#: installation.xml:3
+#, no-c-format
+msgid "PostGIS Installation"
+msgstr ""
+#. Tag: para
+#: installation.xml:5
+#, no-c-format
+msgid "This chapter details the steps required to install PostGIS."
+msgstr ""
+#. Tag: title
+#: installation.xml:10
+#, no-c-format
+msgid "Short Version"
+msgstr ""
+#. Tag: para
+#: installation.xml:11
+#, no-c-format
+msgid "To compile assuming you have all the dependencies in your search path:"
+msgstr ""
+#. Tag: programlisting
+#: installation.xml:12
+#, no-c-format
+msgid ""
+"tar -xvfz postgis-&last_release_version;.tar.gz\n"
+"cd postgis-&last_release_version;\n"
+"./configure\n"
+"make\n"
+"make install"
+msgstr ""
+#. Tag: para
+#: installation.xml:13
+#, no-c-format
+msgid ""
+"Once PostGIS is installed, it needs to be enabled (<xref linkend="
+"\"create_spatial_db\"/>) or upgraded (<xref linkend=\"upgrading\"/>) in each "
+"individual database you want to use it in."
+msgstr ""
+#. Tag: title
+#: installation.xml:23
+#, no-c-format
+msgid "Compiling and Install from Source"
+msgstr ""
+#. Tag: para
+#: installation.xml:26
+#, no-c-format
+msgid ""
+"Many OS systems now include pre-built packages for PostgreSQL/PostGIS. In "
+"many cases compilation is only necessary if you want the most bleeding edge "
+"versions or you are a package maintainer."
+msgstr ""
+#. Tag: para
+#: installation.xml:31
+#, no-c-format
+msgid ""
+"This section includes general compilation instructions, if you are compiling "
+"for Windows etc or another OS, you may find additional more detailed help at "
+"<ulink url=\"http://trac.osgeo.org/postgis/wiki/UsersWikiInstall\">PostGIS "
+"User contributed compile guides</ulink> and <ulink url=\"http://trac.osgeo."
+"org/postgis/wiki/DevWikiMain\">PostGIS Dev Wiki</ulink>."
+msgstr ""
+#. Tag: para
+#: installation.xml:33
+#, no-c-format
+msgid ""
+"Pre-Built Packages for various OS are listed in <ulink url=\"http://trac."
+"osgeo.org/postgis/wiki/UsersWikiPackages\">PostGIS Pre-built Packages</ulink>"
+msgstr ""
+#. Tag: para
+#: installation.xml:34
+#, no-c-format
+msgid ""
+"If you are a windows user, you can get stable builds via Stackbuilder or "
+"<ulink url=\"https://postgis.net/windows_downloads\">PostGIS Windows "
+"download site</ulink> We also have <ulink url=\"https://postgis.net/"
+"windows_downloads\">very bleeding-edge windows experimental builds</ulink> "
+"that are built usually once or twice a week or whenever anything exciting "
+"happens. You can use these to experiment with the in progress releases of "
+"PostGIS"
+msgstr ""
+#. Tag: para
+#: installation.xml:39
+#, no-c-format
+msgid ""
+"The PostGIS module is an extension to the PostgreSQL backend server. As "
+"such, PostGIS &last_release_version; <emphasis>requires</emphasis> full "
+"PostgreSQL server headers access in order to compile. It can be built "
+"against PostgreSQL versions &min_postgres_version; or higher. Earlier "
+"versions of PostgreSQL are <emphasis>not</emphasis> supported."
+msgstr ""
+#. Tag: para
+#: installation.xml:47
+#, no-c-format
+msgid ""
+"Refer to the PostgreSQL installation guides if you haven't already installed "
+"PostgreSQL. <ulink url=\"http://www.postgresql.org\"> http://www.postgresql."
+"org </ulink> ."
+msgstr ""
+#. Tag: para
+#: installation.xml:57
+#, no-c-format
+msgid ""
+"For GEOS functionality, when you install PostgresSQL you may need to "
+"explicitly link PostgreSQL against the standard C++ library:"
+msgstr ""
+#: installation.xml:62
+#, no-c-format
+msgid "LDFLAGS=-lstdc++ ./configure [YOUR OPTIONS HERE]"
+msgstr ""
+#. Tag: para
+#: installation.xml:64
+#, no-c-format
+msgid ""
+"This is a workaround for bogus C++ exceptions interaction with older "
+"development tools. If you experience weird problems (backend unexpectedly "
+"closed or similar things) try this trick. This will require recompiling your "
+"PostgreSQL from scratch, of course."
+msgstr ""
+#. Tag: para
+#: installation.xml:72
+#, no-c-format
+msgid ""
+"The following steps outline the configuration and compilation of the PostGIS "
+"source. They are written for Linux users and will not work on Windows or Mac."
+msgstr ""
+#. Tag: title
+#: installation.xml:79
+#, no-c-format
+msgid "Getting the Source"
+msgstr ""
+#. Tag: para
+#: installation.xml:81
+#, no-c-format
+msgid ""
+"Retrieve the PostGIS source archive from the downloads website <ulink url="
+"\"&postgis_download_url;\"> &postgis_download_url; </ulink>"
+msgstr ""
+#: installation.xml:88
+#, no-c-format
+msgid ""
+"wget &postgis_download_url;\n"
+"tar -xvzf postgis-&last_release_version;.tar.gz"
+msgstr ""
+#. Tag: para
+#: installation.xml:90
+#, no-c-format
+msgid ""
+"This will create a directory called <varname>postgis-&last_release_version;</"
+"varname> in the current working directory."
+msgstr ""
+#. Tag: para
+#: installation.xml:96
+#, no-c-format
+msgid ""
+"Alternatively, checkout the source from the <ulink url=\"https://git-scm.com/"
+"\"> git </ulink> repository <ulink url=\"https://git.osgeo.org/gitea/postgis/"
+"postgis/\"> https://git.osgeo.org/gitea/postgis/postgis/ </ulink> ."
+msgstr ""
+#: installation.xml:108
+#, no-c-format
+msgid "git clone https://git.osgeo.org/gitea/postgis/postgis.git postgis"
+msgstr ""
+#. Tag: para
+#: installation.xml:110
+#, no-c-format
+msgid ""
+"Change into the newly created <varname>postgis</varname> directory to "
+"continue the installation."
+msgstr ""
+#. Tag: title
+#: installation.xml:118
+#, no-c-format
+msgid "Install Requirements"
+msgstr ""
+#. Tag: para
+#: installation.xml:120
+#, no-c-format
+msgid "PostGIS has the following requirements for building and usage:"
+msgstr ""
+#. Tag: emphasis
+#: installation.xml:125
+#, no-c-format
+msgid "Required"
+msgstr ""
+#. Tag: para
+#: installation.xml:130
+#, no-c-format
+msgid ""
+"PostgreSQL &min_postgres_version; or higher. A complete installation of "
+"PostgreSQL (including server headers) is required. PostgreSQL is available "
+"from <ulink url=\"http://www.postgresql.org\"> http://www.postgresql.org </"
+"ulink> ."
+msgstr ""
+#. Tag: para
+#: installation.xml:139
+#, no-c-format
+msgid ""
+"For a full PostgreSQL / PostGIS support matrix and PostGIS/GEOS support "
+"matrix refer to <ulink url=\"http://trac.osgeo.org/postgis/wiki/"
+"UsersWikiPostgreSQLPostGIS\">http://trac.osgeo.org/postgis/wiki/"
+"UsersWikiPostgreSQLPostGIS</ulink>"
+msgstr ""
+#. Tag: para
+#: installation.xml:145
+#, no-c-format
+msgid ""
+"GNU C compiler (<filename>gcc</filename>). Some other ANSI C compilers can "
+"be used to compile PostGIS, but we find far fewer problems when compiling "
+"with <filename>gcc</filename>."
+msgstr ""
+#. Tag: para
+#: installation.xml:153
+#, no-c-format
+msgid ""
+"GNU Make (<filename>gmake</filename> or <filename>make</filename>). For many "
+"systems, GNU <filename>make</filename> is the default version of make. Check "
+"the version by invoking <filename>make -v</filename>. Other versions of "
+"<filename>make</filename> may not process the PostGIS <filename>Makefile</"
+"filename> properly."
+msgstr ""
+#. Tag: para
+#: installation.xml:163
+#, no-c-format
+msgid ""
+"Proj reprojection library. Proj 4.9 or above is required. The Proj library "
+"is used to provide coordinate reprojection support within PostGIS. Proj is "
+"available for download from <ulink url=\"https://proj.org/\"> https://proj."
+"org/ </ulink> ."
+msgstr ""
+#. Tag: para
+#: installation.xml:175
+#, no-c-format
+msgid ""
+"GEOS geometry library, version 3.6 or greater, but GEOS 3.9+ is required to "
+"take full advantage of all the new functions and features. GEOS is available "
+"for download from <ulink url=\"http://trac.osgeo.org/geos/\"> http://trac."
+"osgeo.org/geos/ </ulink>."
+msgstr ""
+#. Tag: para
+#: installation.xml:183
+#, no-c-format
+msgid ""
+"LibXML2, version 2.5.x or higher. LibXML2 is currently used in some imports "
+"functions (ST_GeomFromGML and ST_GeomFromKML). LibXML2 is available for "
+"download from <ulink url=\"http://xmlsoft.org/downloads.html\">http://"
+"xmlsoft.org/downloads.html</ulink>."
+msgstr ""
+#. Tag: para
+#: installation.xml:190
+#, no-c-format
+msgid ""
+"JSON-C, version 0.9 or higher. JSON-C is currently used to import GeoJSON "
+"via the function ST_GeomFromGeoJson. JSON-C is available for download from "
+"<ulink url=\"https://github.com/json-c/json-c/releases\">https://github.com/"
+"json-c/json-c/releases/</ulink>."
+msgstr ""
+#. Tag: para
+#: installation.xml:198
+#, no-c-format
+msgid ""
+"GDAL, version 2+ is required 3+ is preferred. This is required for raster "
+"support. <ulink url=\"http://trac.osgeo.org/gdal/wiki/DownloadSource"
+"\">http://trac.osgeo.org/gdal/wiki/DownloadSource</ulink>."
+msgstr ""
+#. Tag: para
+#: installation.xml:206
+#, no-c-format
+msgid ""
+"If compiling with PostgreSQL+JIT, LLVM version >=6 is required <ulink url="
+"\"https://trac.osgeo.org/postgis/ticket/4125\">https://trac.osgeo.org/"
+"postgis/ticket/4125</ulink>."
+msgstr ""
+#. Tag: emphasis
+#: installation.xml:215
+#, no-c-format
+msgid "Optional"
+msgstr ""
+#. Tag: para
+#: installation.xml:220
+#, no-c-format
+msgid ""
+"GDAL (pseudo optional) only if you don't want raster you can leave it out. "
+"Also make sure to enable the drivers you want to use as described in <xref "
+"linkend=\"raster_configuration\"/>."
+msgstr ""
+#. Tag: para
+#: installation.xml:228
+#, no-c-format
+msgid ""
+"GTK (requires GTK+2.0, 2.8+) to compile the shp2pgsql-gui shape file loader. "
+"<ulink url=\"http://www.gtk.org/\"> http://www.gtk.org/ </ulink> ."
+msgstr ""
+#. Tag: para
+#: installation.xml:238
+#, no-c-format
+msgid ""
+"SFCGAL, version 1.3.1 (or higher), 1.4.0 or higher is recommended. SFCGAL "
+"can be used to provide additional 2D and 3D advanced analysis functions to "
+"PostGIS cf <xref linkend=\"reference_sfcgal\"/>. And also allow to use "
+"SFCGAL rather than GEOS for some 2D functions provided by both backends "
+"(like ST_Intersection or ST_Area, for instance). A PostgreSQL configuration "
+"variable <code>postgis.backend</code> allow end user to control which "
+"backend he want to use if SFCGAL is installed (GEOS by default). Nota: "
+"SFCGAL 1.2 require at least CGAL 4.3 and Boost 1.54 (cf: <ulink url="
+"\"https://oslandia.gitlab.io/SFCGAL/dev.html\">https://oslandia.gitlab.io/"
+"SFCGAL/dev.html</ulink>) <ulink url=\"https://gitlab.com/Oslandia/SFCGAL/"
+"\">https://gitlab.com/Oslandia/SFCGAL/</ulink>."
+msgstr ""
+#. Tag: para
+#: installation.xml:246
+#, no-c-format
+msgid ""
+"In order to build the <xref linkend=\"Address_Standardizer\"/> you will also "
+"need PCRE <ulink url=\"http://www.pcre.org\">http://www.pcre.org</ulink> "
+"(which generally is already installed on nix systems). <code>Regex::"
+"Assemble</code> perl CPAN package is only needed if you want to rebuild the "
+"data encoded in <filename>parseaddress-stcities.h</filename>. <xref linkend="
+"\"Address_Standardizer\"/> will automatically be built if it detects a PCRE "
+"library, or you pass in a valid <varname>--with-pcre-dir=/path/to/pcre</"
+"varname> during configure."
+msgstr ""
+#. Tag: para
+#: installation.xml:253
+#, no-c-format
+msgid ""
+"To enable ST_AsMVT protobuf-c library 1.1.0 or higher (for usage) and the "
+"protoc-c compiler (for building) are required. Also, pkg-config is required "
+"to verify the correct minimum version of protobuf-c. See <ulink url="
+"\"https://github.com/protobuf-c/protobuf-c\">protobuf-c</ulink>. By default, "
+"Postgis will use Wagyu to validate MVT polygons faster which requires a c+"
+"+11 compiler. It will use CXXFLAGS and the same compiler as the PostgreSQL "
+"installation. To disable this and use GEOS instead use the <varname>--"
+"without-wagyu</varname> during the configure step."
+msgstr ""
+#. Tag: para
+#: installation.xml:262
+#, no-c-format
+msgid ""
+"CUnit (<filename>CUnit</filename>). This is needed for regression testing. "
+"<ulink url=\"http://cunit.sourceforge.net/\">http://cunit.sourceforge.net/</"
+"ulink>"
+msgstr ""
+#. Tag: para
+#: installation.xml:268
+#, no-c-format
+msgid ""
+"DocBook (<filename>xsltproc</filename>) is required for building the "
+"documentation. Docbook is available from <ulink url=\"http://www.docbook.org/"
+"\"> http://www.docbook.org/ </ulink> ."
+msgstr ""
+#. Tag: para
+#: installation.xml:279
+#, no-c-format
+msgid ""
+"DBLatex (<filename>dblatex</filename>) is required for building the "
+"documentation in PDF format. DBLatex is available from <ulink url=\"http://"
+"dblatex.sourceforge.net/\"> http://dblatex.sourceforge.net/ </ulink> ."
+msgstr ""
+#. Tag: para
+#: installation.xml:290
+#, no-c-format
+msgid ""
+"ImageMagick (<filename>convert</filename>) is required to generate the "
+"images used in the documentation. ImageMagick is available from <ulink url="
+"\"http://www.imagemagick.org/\"> http://www.imagemagick.org/ </ulink> ."
+msgstr ""
+#. Tag: title
+#: installation.xml:304
+#, no-c-format
+msgid "Build configuration"
+msgstr ""
+#. Tag: para
+#: installation.xml:306
+#, no-c-format
+msgid ""
+"As with most linux installations, the first step is to generate the Makefile "
+"that will be used to build the source code. This is done by running the "
+"shell script"
+msgstr ""
+#. Tag: para
+#: installation.xml:316
+#, no-c-format
+msgid ""
+"With no additional parameters, this command will attempt to automatically "
+"locate the required components and libraries needed to build the PostGIS "
+"source code on your system. Although this is the most common usage of "
+"<command>./configure</command>, the script accepts several parameters for "
+"those who have the required libraries and programs in non-standard locations."
+msgstr ""
+#. Tag: para
+#: installation.xml:324
+#, no-c-format
+msgid ""
+"The following list shows only the most commonly used parameters. For a "
+"complete list, use the <command>--help</command> or <command>--help=short</"
+"command> parameters."
+msgstr ""
+#. Tag: para
+#: installation.xml:334
+#, no-c-format
+msgid ""
+"Starting with PostGIS 3.0, the library files generated by default will no "
+"longer have the minor version as part of the file name. This means all "
+"PostGIS 3 libs will end in <code>postgis-3</code>. This was done to make "
+"pg_upgrade easier, with downside that you can only install one version "
+"PostGIS 3 series in your server. To get the old behavior of file including "
+"the minor version: e.g. <code>postgis-3.0</code> add this switch to your "
+"configure statement."
+msgstr ""
+#. Tag: para
+#: installation.xml:349
+#, no-c-format
+msgid ""
+"This is the location the PostGIS loader executables and shared libs will be "
+"installed. By default, this location is the same as the detected PostgreSQL "
+"installation."
+msgstr ""
+#. Tag: para
+#: installation.xml:356
+#, no-c-format
+msgid ""
+"This parameter is currently broken, as the package will only install into "
+"the PostgreSQL installation directory. Visit <ulink url=\"http://trac.osgeo."
+"org/postgis/ticket/635\"> http://trac.osgeo.org/postgis/ticket/635 </ulink> "
+"to track this bug."
+msgstr ""
+#. Tag: para
+#: installation.xml:371
+#, no-c-format
+msgid ""
+"PostgreSQL provides a utility called <command>pg_config</command> to enable "
+"extensions like PostGIS to locate the PostgreSQL installation directory. Use "
+"this parameter (<command>--with-pgconfig=/path/to/pg_config</command>) to "
+"manually specify a particular PostgreSQL installation that PostGIS will "
+"build against."
+msgstr ""
+#. Tag: para
+#: installation.xml:385
+#, no-c-format
+msgid ""
+"GDAL, a required library, provides functionality needed for raster support "
+"<command>gdal-config</command> to enable software installations to locate "
+"the GDAL installation directory. Use this parameter (<command>--with-"
+"gdalconfig=/path/to/gdal-config</command>) to manually specify a particular "
+"GDAL installation that PostGIS will build against."
+msgstr ""
+#. Tag: para
+#: installation.xml:399
+#, no-c-format
+msgid ""
+"GEOS, a required geometry library, provides a utility called <command>geos-"
+"config</command> to enable software installations to locate the GEOS "
+"installation directory. Use this parameter (<command>--with-geosconfig=/path/"
+"to/geos-config</command>) to manually specify a particular GEOS installation "
+"that PostGIS will build against."
+msgstr ""
+#. Tag: para
+#: installation.xml:413
+#, no-c-format
+msgid ""
+"LibXML is the library required for doing GeomFromKML/GML processes. It "
+"normally is found if you have libxml installed, but if not or you want a "
+"specific version used, you'll need to point PostGIS at a specific "
+"<filename>xml2-config</filename> confi file to enable software installations "
+"to locate the LibXML installation directory. Use this parameter (<command>>--"
+"with-xml2config=/path/to/xml2-config</command>) to manually specify a "
+"particular LibXML installation that PostGIS will build against."
+msgstr ""
+#. Tag: para
+#: installation.xml:431
+#, no-c-format
+msgid ""
+"Proj is a reprojection library required by PostGIS. Use this parameter "
+"(<command>--with-projdir=/path/to/projdir</command>) to manually specify a "
+"particular Proj installation directory that PostGIS will build against."
+msgstr ""
+#. Tag: para
+#: installation.xml:443
+#, no-c-format
+msgid "Directory where iconv is installed."
+msgstr ""
+#. Tag: para
+#: installation.xml:452
+#, no-c-format
+msgid ""
+"<ulink url=\"http://oss.metaparadigm.com/json-c/\">JSON-C</ulink> is an MIT-"
+"licensed JSON library required by PostGIS ST_GeomFromJSON support. Use this "
+"parameter (<command>--with-jsondir=/path/to/jsondir</command>) to manually "
+"specify a particular JSON-C installation directory that PostGIS will build "
+"against."
+msgstr ""
+#. Tag: para
+#: installation.xml:464
+#, no-c-format
+msgid ""
+"<ulink url=\"http://www.pcre.org/\">PCRE</ulink> is an BSD-licensed Perl "
+"Compatible Regular Expression library required by address_standardizer "
+"extension. Use this parameter (<command>--with-pcredir=/path/to/pcredir</"
+"command>) to manually specify a particular PCRE installation directory that "
+"PostGIS will build against."
+msgstr ""
+#. Tag: para
+#: installation.xml:476
+#, no-c-format
+msgid ""
+"Compile the data import GUI (requires GTK+2.0). This will create shp2pgsql-"
+"gui graphical interface to shp2pgsql."
+msgstr ""
+#. Tag: para
+#: installation.xml:485
+#, no-c-format
+msgid "Compile without raster support."
+msgstr ""
+#. Tag: para
+#: installation.xml:493
+#, no-c-format
+msgid ""
+"Disable topology support. There is no corresponding library as all logic "
+"needed for topology is in postgis-&last_release_version; library."
+msgstr ""
+#. Tag: para
+#: installation.xml:502
+#, no-c-format
+msgid ""
+"By default PostGIS will try to detect gettext support and compile with it, "
+"however if you run into incompatibility issues that cause breakage of "
+"loader, you can disable it entirely with this command. Refer to ticket "
+"<ulink url=\"http://trac.osgeo.org/postgis/ticket/748\">http://trac.osgeo."
+"org/postgis/ticket/748</ulink> for an example issue solved by configuring "
+"with this. NOTE: that you aren't missing much by turning this off. This is "
+"used for international help/label support for the GUI loader which is not "
+"yet documented and still experimental."
+msgstr ""
+#. Tag: para
+#: installation.xml:513
+#, no-c-format
+msgid ""
+"By default PostGIS will not install with sfcgal support without this switch. "
+"<varname>PATH</varname> is an optional argument that allows to specify an "
+"alternate PATH to sfcgal-config."
+msgstr ""
+#. Tag: para
+#: installation.xml:522
+#, no-c-format
+msgid ""
+"Disable updating postgis_revision.h to match current HEAD of the git "
+"repository."
+msgstr ""
+#. Tag: para
+#: installation.xml:529
+#, no-c-format
+msgid ""
+"If you obtained PostGIS from the <ulink url=\"https://trac.osgeo.org/postgis/"
+"wiki/CodeRepository\"> code repository </ulink> , the first step is really "
+"to run the script"
+msgstr ""
+#. Tag: para
+#: installation.xml:541
+#, no-c-format
+msgid ""
+"This script will generate the <command>configure</command> script that in "
+"turn is used to customize the installation of PostGIS."
+msgstr ""
+#. Tag: para
+#: installation.xml:546
+#, no-c-format
+msgid ""
+"If you instead obtained PostGIS as a tarball, running <command>./autogen.sh</"
+"command> is not necessary as <command>configure</command> has already been "
+"generated."
+msgstr ""
+#. Tag: title
+#: installation.xml:555
+#, no-c-format
+msgid "Building"
+msgstr ""
+#. Tag: para
+#: installation.xml:557
+#, no-c-format
+msgid ""
+"Once the Makefile has been generated, building PostGIS is as simple as "
+"running"
+msgstr ""
+#. Tag: para
+#: installation.xml:566
+#, no-c-format
+msgid ""
+"The last line of the output should be \"<code>PostGIS was built "
+"successfully. Ready to install.</code>\""
+msgstr ""
+#. Tag: para
+#: installation.xml:571
+#, no-c-format
+msgid ""
+"As of PostGIS v1.4.0, all the functions have comments generated from the "
+"documentation. If you wish to install these comments into your spatial "
+"databases later, run the command which requires docbook. The "
+"postgis_comments.sql and other package comments files raster_comments.sql, "
+"topology_comments.sql are also packaged in the tar.gz distribution in the "
+"doc folder so no need to make comments if installing from the tar ball. "
+"Comments are also included as part of the CREATE EXTENSION install."
+msgstr ""
+#. Tag: command
+#: installation.xml:581 installation.xml:605
+#, no-c-format
+msgid "make comments"
+msgstr ""
+#. Tag: para
+#: installation.xml:584
+#, no-c-format
+msgid ""
+"Introduced in PostGIS 2.0. This generates html cheat sheets suitable for "
+"quick reference or for student handouts. This requires xsltproc to build and "
+"will generate 4 files in doc folder <filename>topology_cheatsheet.html</"
+"filename>, <filename>tiger_geocoder_cheatsheet.html</filename>, "
+"<filename>raster_cheatsheet.html</filename>, <filename>postgis_cheatsheet."
+"html</filename>"
+msgstr ""
+#. Tag: para
+#: installation.xml:589
+#, no-c-format
+msgid ""
+"You can download some pre-built ones available in html and pdf from <ulink "
+"url=\"http://www.postgis.us/study_guides\">PostGIS / PostgreSQL Study "
+"Guides</ulink>"
+msgstr ""
+#. Tag: command
+#: installation.xml:592
+#, no-c-format
+msgid "make cheatsheets"
+msgstr ""
+#. Tag: title
+#: installation.xml:597
+#, no-c-format
+msgid "Building PostGIS Extensions and Deploying them"
+msgstr ""
+#. Tag: para
+#: installation.xml:599
+#, no-c-format
+msgid ""
+"The PostGIS extensions are built and installed automatically if you are "
+"using PostgreSQL 9.1+."
+msgstr ""
+#. Tag: para
+#: installation.xml:602
+#, no-c-format
+msgid ""
+"If you are building from source repository, you need to build the function "
+"descriptions first. These get built if you have docbook installed. You can "
+"also manually build with the statement:"
+msgstr ""
+#. Tag: para
+#: installation.xml:607
+#, no-c-format
+msgid ""
+"Building the comments is not necessary if you are building from a release "
+"tar ball since these are packaged pre-built with the tar ball already."
+msgstr ""
+#. Tag: para
+#: installation.xml:608
+#, no-c-format
+msgid ""
+"The extensions should automatically build as part of the make install "
+"process. You can if needed build from the extensions folders or copy files "
+"if you need them on a different server."
+msgstr ""
+#: installation.xml:610
+#, no-c-format
+msgid ""
+"cd extensions\n"
+"cd postgis\n"
+"make clean\n"
+"make\n"
+"export PGUSER=postgres #overwrite psql variables\n"
+"make check #to test before install\n"
+"make install\n"
+"# to test extensions\n"
+"make check RUNTESTFLAGS=--extension"
+msgstr ""
+#. Tag: para
+#: installation.xml:611
+#, no-c-format
+msgid ""
+"<code>make check</code> uses psql to run tests and as such can use psql "
+"environment variables. Common ones useful to override are <varname>PGUSER</"
+"varname>,<varname>PGPORT</varname>, and <varname>PGHOST</varname>. Refer to "
+"<ulink url=\"https://www.postgresql.org/docs/current/libpq-envars.html"
+"\">psql environment variables</ulink>"
+msgstr ""
+#. Tag: para
+#: installation.xml:613
+#, no-c-format
+msgid ""
+"The extension files will always be the same for the same version of PostGIS "
+"and PostgreSQL regardless of OS, so it is fine to copy over the extension "
+"files from one OS to another as long as you have the PostGIS binaries "
+"already installed on your servers."
+msgstr ""
+#. Tag: para
+#: installation.xml:615
+#, no-c-format
+msgid ""
+"If you want to install the extensions manually on a separate server "
+"different from your development, You need to copy the following files from "
+"the extensions folder into the <filename>PostgreSQL / share / extension</"
+"filename> folder of your PostgreSQL install as well as the needed binaries "
+"for regular PostGIS if you don't have them already on the server."
+msgstr ""
+#. Tag: para
+#: installation.xml:622
+#, no-c-format
+msgid ""
+"These are the control files that denote information such as the version of "
+"the extension to install if not specified. <filename>postgis.control, "
+"postgis_topology.control</filename>."
+msgstr ""
+#. Tag: para
+#: installation.xml:628
+#, no-c-format
+msgid ""
+"All the files in the /sql folder of each extension. Note that these need to "
+"be copied to the root of the PostgreSQL share/extension folder "
+"<filename>extensions/postgis/sql/*.sql</filename>, <filename>extensions/"
+"postgis_topology/sql/*.sql</filename>"
+msgstr ""
+#. Tag: para
+#: installation.xml:634
+#, no-c-format
+msgid ""
+"Once you do that, you should see <varname>postgis</varname>, "
+"<varname>postgis_topology</varname> as available extensions in PgAdmin -> "
+"extensions."
+msgstr ""
+#. Tag: para
+#: installation.xml:635
+#, no-c-format
+msgid ""
+"If you are using psql, you can verify that the extensions are installed by "
+"running this query:"
+msgstr ""
+#: installation.xml:636
+#, no-c-format
+msgid ""
+"SELECT name, default_version,installed_version\n"
+"FROM pg_available_extensions WHERE name LIKE 'postgis%' or name LIKE 'address"
+"%';\n"
+"\n"
+"             name             | default_version | installed_version\n"
+"------------------------------+-----------------+-------------------\n"
+" address_standardizer         | &last_release_version;         | "
+"&last_release_version;\n"
+" address_standardizer_data_us | &last_release_version;         | "
+" postgis                      | &last_release_version;         | "
+" postgis_raster               | &last_release_version;         | "
+" postgis_sfcgal               | &last_release_version;         |\n"
+" postgis_tiger_geocoder       | &last_release_version;         | "
+" postgis_topology             | &last_release_version;         |\n"
+"(6 rows)"
+msgstr ""
+#. Tag: para
+#: installation.xml:638
+#, no-c-format
+msgid ""
+"If you have the extension installed in the database you are querying, you'll "
+"see mention in the <varname>installed_version</varname> column. If you get "
+"no records back, it means you don't have postgis extensions installed on the "
+"server at all. PgAdmin III 1.14+ will also provide this information in the "
+"<varname>extensions</varname> section of the database browser tree and will "
+"even allow upgrade or uninstall by right-clicking."
+msgstr ""
+#. Tag: para
+#: installation.xml:642
+#, no-c-format
+msgid ""
+"If you have the extensions available, you can install postgis extension in "
+"your database of choice by either using pgAdmin extension interface or "
+"running these sql commands:"
+msgstr ""
+#: installation.xml:643
+#, no-c-format
+msgid ""
+"CREATE EXTENSION postgis;\n"
+"CREATE EXTENSION postgis_raster;\n"
+"CREATE EXTENSION postgis_sfcgal;\n"
+"CREATE EXTENSION fuzzystrmatch; --needed for postgis_tiger_geocoder\n"
+"--optional used by postgis_tiger_geocoder, or can be used standalone\n"
+"CREATE EXTENSION address_standardizer;\n"
+"CREATE EXTENSION address_standardizer_data_us;\n"
+"CREATE EXTENSION postgis_tiger_geocoder;\n"
+"CREATE EXTENSION postgis_topology;"
+msgstr ""
+#. Tag: para
+#: installation.xml:645
+#, no-c-format
+msgid ""
+"In psql you can use to see what versions you have installed and also what "
+"schema they are installed."
+msgstr ""
+#: installation.xml:646
+#, no-c-format
+msgid ""
+"\\connect mygisdb\n"
+"\\x\n"
+"\\dx postgis*"
+msgstr ""
+#. Tag: screen
+#: installation.xml:648
+#, no-c-format
+msgid ""
+"List of installed extensions\n"
+"-[ RECORD 1 ]-------------------------------------------------\n"
+"Name        | postgis\n"
+"Version     | &last_release_version;\n"
+"Schema      | public\n"
+"Description | PostGIS geometry, geography, and raster spat..\n"
+"-[ RECORD 2 ]-------------------------------------------------\n"
+"Name        | postgis_raster\n"
+"Version     | 3.0.0dev\n"
+"Description | PostGIS raster types and functions\n"
+"-[ RECORD 3 ]-------------------------------------------------\n"
+"Name        | postgis_tiger_geocoder\n"
+"Schema      | tiger\n"
+"Description | PostGIS tiger geocoder and reverse geocoder\n"
+"-[ RECORD 4 ]-------------------------------------------------\n"
+"Name        | postgis_topology\n"
+"Schema      | topology\n"
+"Description | PostGIS topology spatial types and functions"
+msgstr ""
+#. Tag: para
+#: installation.xml:650
+#, no-c-format
+msgid ""
+"Extension tables <varname>spatial_ref_sys</varname>, <varname>layer</"
+"varname>, <varname>topology</varname> can not be explicitly backed up. They "
+"can only be backed up when the respective <varname>postgis</varname> or "
+"<varname>postgis_topology</varname> extension is backed up, which only seems "
+"to happen when you backup the whole database. As of PostGIS 2.0.1, only srid "
+"records not packaged with PostGIS are backed up when the database is backed "
+"up so don't go around changing srids we package and expect your changes to "
+"be there. Put in a ticket if you find an issue. The structures of extension "
+"tables are never backed up since they are created with <code>CREATE "
+"EXTENSION</code> and assumed to be the same for a given version of an "
+"extension. These behaviors are built into the current PostgreSQL extension "
+"model, so nothing we can do about it."
+msgstr ""
+#. Tag: para
+#: installation.xml:655
+#, no-c-format
+msgid ""
+"If you installed &last_release_version;, without using our wonderful "
+"extension system, you can change it to be extension based by running the "
+"below commands to package the functions in their respective extension. "
+"Installing using `unpackaged` was removed in PostgreSQL 13, so you are "
+"advised to switch to an extension build before upgrading to PostgreSQL 13."
+msgstr ""
+#: installation.xml:660
+#, no-c-format
+msgid ""
+"CREATE EXTENSION postgis FROM unpackaged;\n"
+"CREATE EXTENSION postgis_raster FROM unpackaged;\n"
+"CREATE EXTENSION postgis_topology FROM unpackaged;\n"
+"CREATE EXTENSION postgis_tiger_geocoder FROM unpackaged;"
+msgstr ""
+#. Tag: title
+#: installation.xml:666
+#, no-c-format
+msgid "Testing"
+msgstr ""
+#. Tag: para
+#: installation.xml:668
+#, no-c-format
+msgid "If you wish to test the PostGIS build, run"
+msgstr ""
+#. Tag: command
+#: installation.xml:673
+#, no-c-format
+msgid "make check"
+msgstr ""
+#. Tag: para
+#: installation.xml:676
+#, no-c-format
+msgid ""
+"The above command will run through various checks and regression tests using "
+"the generated library against an actual PostgreSQL database."
+msgstr ""
+#. Tag: para
+#: installation.xml:682
+#, no-c-format
+msgid ""
+"If you configured PostGIS using non-standard PostgreSQL, GEOS, or Proj "
+"locations, you may need to add their library locations to the "
+"<varname>LD_LIBRARY_PATH</varname> environment variable."
+msgstr ""
+#. Tag: para
+#: installation.xml:690
+#, no-c-format
+msgid ""
+"Currently, the <command>make check</command> relies on the <code>PATH</code> "
+"and <code>PGPORT</code> environment variables when performing the checks - "
+"it does <emphasis>not</emphasis> use the PostgreSQL version that may have "
+"been specified using the configuration parameter <command>--with-pgconfig</"
+"command>. So make sure to modify your PATH to match the detected PostgreSQL "
+"installation during configuration or be prepared to deal with the impending "
+"headaches."
+msgstr ""
+#. Tag: para
+#: installation.xml:702
+#, no-c-format
+msgid ""
+"If successful, make check will produce the output of almost 500 tests. The "
+"results will look similar to the following (numerous lines omitted below):"
+msgstr ""
+#: installation.xml:707
+#, no-c-format
+msgid ""
+"CUnit - A unit testing framework for C - Version 2.1-3\n"
+"     http://cunit.sourceforge.net/\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"Run Summary:    Type  Total    Ran Passed Failed Inactive\n"
+"              suites     44     44    n/a      0        0\n"
+"               tests    300    300    300      0        0\n"
+"             asserts   4215   4215   4215      0      n/a\n"
+"Elapsed time =    0.229 seconds\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"Running tests\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"Run tests: 134\n"
+"Failed: 0\n"
+"\n"
+"\n"
+"-- if you build with SFCGAL\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"Running tests\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"Run tests: 13\n"
+"Failed: 0\n"
+"\n"
+"-- if you built with raster support\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"              suites     12     12    n/a      0        0\n"
+"               tests     65     65     65      0        0\n"
+"             asserts  45896  45896  45896      0      n/a\n"
+"\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"Running tests\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"Run tests: 101\n"
+"Failed: 0\n"
+"\n"
+"-- topology regress\n"
+"\n"
+".\n"
+".\n"
+".\n"
+"\n"
+"Running tests\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"Run tests: 51\n"
+"Failed: 0\n"
+"\n"
+"-- if you built --with-gui, you should see this too\n"
+"\n"
+"     CUnit - A unit testing framework for C - Version 2.1-2\n"
+"\n"
+"        .\n"
+"        .\n"
+"        .\n"
+"\n"
+"              suites      2      2    n/a      0        0\n"
+"               tests      4      4      4      0        0\n"
+"             asserts      4      4      4      0      n/a"
+msgstr ""
+#. Tag: para
+#: installation.xml:709
+#, no-c-format
+msgid ""
+"The <varname>postgis_tiger_geocoder</varname> and "
+"<varname>address_standardizer</varname> extensions, currently only support "
+"the standard PostgreSQL installcheck. To test these use the below. Note: the "
+"make install is not necessary if you already did make install at root of "
+"PostGIS code folder."
+msgstr ""
+#. Tag: para
+#: installation.xml:710
+#, no-c-format
+msgid "For address_standardizer:"
+msgstr ""
+#: installation.xml:711
+#, no-c-format
+msgid ""
+"cd extensions/address_standardizer\n"
+"make install\n"
+"make installcheck"
+msgstr ""
+#. Tag: para
+#: installation.xml:713
+#, no-c-format
+msgid "Output should look like:"
+msgstr ""
+#. Tag: screen
+#: installation.xml:714
+#, no-c-format
+msgid ""
+"============== dropping database \"contrib_regression\" ==============\n"
+"DROP DATABASE\n"
+"============== creating database \"contrib_regression\" ==============\n"
+"CREATE DATABASE\n"
+"ALTER DATABASE\n"
+"============== running regression test queries        ==============\n"
+"test test-init-extensions     ... ok\n"
+"test test-parseaddress        ... ok\n"
+"test test-standardize_address_1 ... ok\n"
+"test test-standardize_address_2 ... ok\n"
+"\n"
+"=====================\n"
+" All 4 tests passed.\n"
+msgstr ""
+#. Tag: para
+#: installation.xml:716
+#, no-c-format
+msgid ""
+"For tiger geocoder, make sure you have postgis and fuzzystrmatch extensions "
+"available in your PostgreSQL instance. The address_standardizer tests will "
+"also kick in if you built postgis with address_standardizer support:"
+msgstr ""
+#: installation.xml:717
+#, no-c-format
+msgid ""
+"cd extensions/postgis_tiger_geocoder\n"
+"make install\n"
+msgstr ""
+#. Tag: para
+#: installation.xml:718
+#, no-c-format
+msgid "output should look like:"
+msgstr ""
+#. Tag: screen
+#: installation.xml:719
+#, no-c-format
+msgid ""
+"DROP DATABASE\n"
+"ALTER DATABASE\n"
+"============== installing fuzzystrmatch               ==============\n"
+"CREATE EXTENSION\n"
+"============== installing postgis                     ==============\n"
+"============== installing postgis_tiger_geocoder      ==============\n"
+"============== installing address_standardizer        ==============\n"
+"test test-normalize_address   ... ok\n"
+"test test-pagc_normalize_address ... ok\n"
+"\n"
+"All 2 tests passed.\n"
+msgstr ""
+#. Tag: title
+#: installation.xml:723
+#, no-c-format
+msgid "Installation"
+msgstr ""
+#. Tag: para
+#: installation.xml:725
+#, no-c-format
+msgid "To install PostGIS, type"
+msgstr ""
+#. Tag: command
+#: installation.xml:730
+#, no-c-format
+msgid "make install"
+msgstr ""
+#. Tag: para
+#: installation.xml:733
+#, no-c-format
+msgid ""
+"This will copy the PostGIS installation files into their appropriate "
+"subdirectory specified by the <command>--prefix</command> configuration "
+"parameter. In particular:"
+msgstr ""
+#. Tag: para
+#: installation.xml:741
+#, no-c-format
+msgid ""
+"The loader and dumper binaries are installed in <filename>[prefix]/bin</"
+"filename>."
+msgstr ""
+#. Tag: para
+#: installation.xml:748
+#, no-c-format
+msgid ""
+"The SQL files, such as <filename>postgis.sql</filename>, are installed in "
+"<filename>[prefix]/share/contrib</filename>."
+msgstr ""
+#. Tag: para
+#: installation.xml:755
+#, no-c-format
+msgid ""
+"The PostGIS libraries are installed in <filename>[prefix]/lib</filename>."
+msgstr ""
+#. Tag: para
+#: installation.xml:762
+#, no-c-format
+msgid ""
+"If you previously ran the <command>make comments</command> command to "
+"generate the <filename>postgis_comments.sql</filename>, "
+"<filename>raster_comments.sql</filename> file, install the sql file by "
+"running"
+msgstr ""
+#. Tag: command
+#: installation.xml:769
+#, no-c-format
+msgid "make comments-install"
+msgstr ""
+#. Tag: para
+#: installation.xml:773
+#, no-c-format
+msgid ""
+"<filename>postgis_comments.sql</filename>, <filename>raster_comments.sql</"
+"filename>, <filename>topology_comments.sql</filename> was separated from the "
+"typical build and installation targets since with it comes the extra "
+"dependency of <command>xsltproc</command>."
+msgstr ""
+#. Tag: title
+#: installation.xml:782
+#, no-c-format
+msgid "Installing and Using the address standardizer"
+msgstr ""
+#. Tag: para
+#: installation.xml:783
+#, no-c-format
+msgid ""
+"The <code>address_standardizer</code> extension used to be a separate "
+"package that required separate download. From PostGIS 2.2 on, it is now "
+"bundled in. For more information about the address_standardize, what it "
+"does, and how to configure it for your needs, refer to <xref linkend="
+"\"Address_Standardizer\"/>."
+msgstr ""
+#. Tag: para
+#: installation.xml:785
+#, no-c-format
+msgid ""
+"This standardizer can be used in conjunction with the PostGIS packaged tiger "
+"geocoder extension as a replacement for the <xref linkend=\"Normalize_Address"
+"\"/> discussed. To use as replacement refer to <xref linkend="
+"\"tiger_pagc_address_standardizing\"/>. You can also use it as a building "
+"block for your own geocoder or use it to standardize your addresses for "
+"easier compare of addresses."
+msgstr ""
+#. Tag: para
+#: installation.xml:789
+#, no-c-format
+msgid ""
+"The address standardizer relies on PCRE which is usually already installed "
+"on many Nix systems, but you can download the latest at: <ulink url=\"http://"
+"www.pcre.org\">http://www.pcre.org</ulink>. If during <xref linkend="
+"\"installation_configuration\"/>, PCRE is found, then the address "
+"standardizer extension will automatically be built. If you have a custom "
+"pcre install you want to use instead, pass to configure <code>--with-"
+"pcredir=/path/to/pcre</code> where <filename>/path/to/pcre</filename> is the "
+"root folder for your pcre include and lib directories."
+msgstr ""
+#. Tag: para
+#: installation.xml:792
+#, no-c-format
+msgid ""
+"For Windows users, the PostGIS 2.1+ bundle is packaged with the "
+"address_standardizer already so no need to compile and can move straight to "
+"<code>CREATE EXTENSION</code> step."
+msgstr ""
+#. Tag: para
+#: installation.xml:795
+#, no-c-format
+msgid ""
+"Once you have installed, you can connect to your database and run the SQL:"
+msgstr ""
+#: installation.xml:796
+#, no-c-format
+msgid "CREATE EXTENSION address_standardizer;"
+msgstr ""
+#. Tag: para
+#: installation.xml:798
+#, no-c-format
+msgid "The following test requires no rules, gaz, or lex tables"
+msgstr ""
+#: installation.xml:799
+#, no-c-format
+msgid ""
+"SELECT num, street, city, state, zip\n"
+" FROM parse_address('1 Devonshire Place PH301, Boston, MA 02109');"
+msgstr ""
+#. Tag: para
+#: installation.xml:800
+#, no-c-format
+msgid "Output should be"
+msgstr ""
+#. Tag: screen
+#: installation.xml:801
+#, no-c-format
+msgid ""
+"num |         street         |  city  | state |  zip\n"
+"-----+------------------------+--------+-------+-------\n"
+" 1   | Devonshire Place PH301 | Boston | MA    | 02109"
+msgstr ""
+#. Tag: title
+#: installation.xml:803
+#, no-c-format
+msgid "Installing Regex::Assemble"
+msgstr ""
+#. Tag: para
+#: installation.xml:804
+#, no-c-format
+msgid ""
+"Perl Regex:Assemble is no longer needed for compiling address_standardizer "
+"extension since the files it generates are part of the source tree. However "
+"if you need to edit the <filename>usps-st-city-orig.txt</filename> or "
+"<filename>usps-st-city-orig.txt usps-st-city-adds.tx</filename>, you need to "
+"rebuild <filename>parseaddress-stcities.h</filename> which does require "
+"Regex:Assemble."
+msgstr ""
+#: installation.xml:805
+#, no-c-format
+msgid "cpan Regexp::Assemble"
+msgstr ""
+#. Tag: para
+#: installation.xml:806
+#, no-c-format
+msgid "or if you are on Ubuntu / Debian you might need to do"
+msgstr ""
+#: installation.xml:807
+#, no-c-format
+msgid "sudo perl -MCPAN -e \"install Regexp::Assemble\""
+msgstr ""
+#. Tag: title
+#: installation.xml:812
+#, no-c-format
+msgid "Installing, Upgrading Tiger Geocoder and loading data"
+msgstr ""
+#. Tag: para
+#: installation.xml:814
+#, no-c-format
+msgid ""
+"Extras like Tiger geocoder may not be packaged in your PostGIS distribution. "
+"If you are missing the tiger geocoder extension or want a newer version than "
+"what your install comes with, then use the <filename>share/extension/"
+"postgis_tiger_geocoder.*</filename> files from the packages in <ulink url="
+"\"http://postgis.net/windows_downloads/\">Windows Unreleased Versions</"
+"ulink> section for your version of PostgreSQL. Although these packages are "
+"for windows, the postgis_tiger_geocoder extension files will work on any OS "
+"since the extension is an SQL/plpgsql only extension."
+msgstr ""
+#. Tag: title
+#: installation.xml:818
+#, no-c-format
+msgid "Tiger Geocoder Enabling your PostGIS database: Using Extension"
+msgstr ""
+#. Tag: para
+#: installation.xml:819
+#, no-c-format
+msgid ""
+"If you are using PostgreSQL 9.1+ and PostGIS 2.1+, you can take advantage of "
+"the new extension model for installing tiger geocoder. To do so:"
+msgstr ""
+#. Tag: para
+#: installation.xml:821
+#, no-c-format
+msgid ""
+"First get binaries for PostGIS 2.1+ or compile and install as usual. This "
+"should install the necessary extension files as well for tiger geocoder."
+msgstr ""
+#. Tag: para
+#: installation.xml:822
+#, no-c-format
+msgid ""
+"Connect to your database via psql or pgAdmin or some other tool and run the "
+"following SQL commands. Note that if you are installing in a database that "
+"already has postgis, you don't need to do the first step. If you have "
+"<varname>fuzzystrmatch</varname> extension already installed, you don't need "
+"to do the second step either."
+msgstr ""
+#: installation.xml:823
+#, no-c-format
+msgid ""
+"CREATE EXTENSION fuzzystrmatch;\n"
+"--this one is optional if you want to use the rules based standardizer "
+"(pagc_normalize_address)\n"
+"CREATE EXTENSION address_standardizer;"
+msgstr ""
+#. Tag: para
+#: installation.xml:825
+#, no-c-format
+msgid ""
+"If you already have postgis_tiger_geocoder extension installed, and just "
+"want to update to the latest run:"
+msgstr ""
+#: installation.xml:826
+#, no-c-format
+msgid ""
+"ALTER EXTENSION postgis UPDATE;\n"
+"ALTER EXTENSION postgis_tiger_geocoder UPDATE;"
+msgstr ""
+#. Tag: para
+#: installation.xml:827
+#, no-c-format
+msgid ""
+"If you made custom entries or changes to <varname>tiger.loader_platform</"
+"varname> and <varname>tiger.loader_variables</varname> you may need to "
+"update these."
+msgstr ""
+#. Tag: para
+#: installation.xml:829
+#, no-c-format
+msgid ""
+"To confirm your install is working correctly, run this sql in your database:"
+msgstr ""
+#: installation.xml:830
+#, no-c-format
+msgid ""
+"SELECT na.address, na.streetname,na.streettypeabbrev, na.zip\n"
+"        FROM normalize_address('1 Devonshire Place, Boston, MA 02109') AS na;"
+msgstr ""
+#. Tag: para
+#: installation.xml:831
+#, no-c-format
+msgid "Which should output"
+msgstr ""
+#. Tag: screen
+#: installation.xml:832
+#, no-c-format
+msgid ""
+"address | streetname | streettypeabbrev |  zip\n"
+"---------+------------+------------------+-------\n"
+"           1 | Devonshire | Pl               | 02109"
+msgstr ""
+#. Tag: para
+#: installation.xml:834
+#, no-c-format
+msgid ""
+"Create a new record in <varname>tiger.loader_platform</varname> table with "
+"the paths of your executables and server."
+msgstr ""
+#. Tag: para
+#: installation.xml:835
+#, no-c-format
+msgid ""
+"So for example to create a profile called debbie that follows <code>sh</"
+"code> convention. You would do:"
+msgstr ""
+#: installation.xml:836
+#, no-c-format
+msgid ""
+"INSERT INTO tiger.loader_platform(os, declare_sect, pgbin, wget, "
+"unzip_command, psql, path_sep,\n"
+"                   loader, environ_set_command, county_process_command)\n"
+"SELECT 'debbie', declare_sect, pgbin, wget, unzip_command, psql, path_sep,\n"
+"           loader, environ_set_command, county_process_command\n"
+"  FROM tiger.loader_platform\n"
+"  WHERE os = 'sh';"
+msgstr ""
+#. Tag: para
+#: installation.xml:837
+#, no-c-format
+msgid ""
+"And then edit the paths in the <emphasis>declare_sect</emphasis> column to "
+"those that fit Debbie's pg, unzip,shp2pgsql, psql, etc path locations."
+msgstr ""
+#. Tag: para
+#: installation.xml:839
+#, no-c-format
+msgid ""
+"If you don't edit this <varname>loader_platform</varname> table, it will "
+"just contain common case locations of items and you'll have to edit the "
+"generated script after the script is generated."
+msgstr ""
+#. Tag: para
+#: installation.xml:841
+#, no-c-format
+msgid ""
+"As of PostGIS 2.4.1 the Zip code-5 digit tabulation area <varname>zcta5</"
+"varname> load step was revised to load current zcta5 data and is part of the "
+"<xref linkend=\"Loader_Generate_Nation_Script\"/> when enabled. It is turned "
+"off by default because it takes quite a bit of time to load (20 to 60 "
+"minutes), takes up quite a bit of disk space, and is not used that often."
+msgstr ""
+#. Tag: para
+#: installation.xml:843
+#, no-c-format
+msgid "To enable it, do the following:"
+msgstr ""
+#: installation.xml:844
+#, no-c-format
+msgid ""
+"UPDATE tiger.loader_lookuptables SET load = true WHERE table_name = "
+"'zcta510';"
+msgstr ""
+#. Tag: para
+#: installation.xml:845
+#, no-c-format
+msgid ""
+"If present the <xref linkend=\"Geocode\"/> function can use it if a boundary "
+"filter is added to limit to just zips in that boundary. The <xref linkend="
+"\"Reverse_Geocode\"/> function uses it if the returned address is missing a "
+"zip, which often happens with highway reverse geocoding."
+msgstr ""
+#. Tag: para
+#: installation.xml:848
+#, no-c-format
+msgid ""
+"Create a folder called <filename>gisdata</filename> on root of server or "
+"your local pc if you have a fast network connection to the server. This "
+"folder is where the tiger files will be downloaded to and processed. If you "
+"are not happy with having the folder on the root of the server, or simply "
+"want to change to a different folder for staging, then edit the field "
+"<varname>staging_fold</varname> in the <varname>tiger.loader_variables</"
+"varname> table."
+msgstr ""
+#. Tag: para
+#: installation.xml:850
+#, no-c-format
+msgid ""
+"Create a folder called temp in the <filename>gisdata</filename> folder or "
+"wherever you designated the <varname>staging_fold</varname> to be. This will "
+"be the folder where the loader extracts the downloaded tiger data."
+msgstr ""
+#. Tag: para
+#: installation.xml:852
+#, no-c-format
+msgid ""
+"Then run the <xref linkend=\"Loader_Generate_Nation_Script\"/> SQL function "
+"make sure to use the name of your custom profile and copy the script to a ."
+"sh or .bat file. So for example to build the nation load:"
+msgstr ""
+#: installation.xml:853
+#, no-c-format
+msgid ""
+"psql -c \"SELECT Loader_Generate_Nation_Script('debbie')\" -d geocoder -tA "
+"> /gisdata/nation_script_load.sh"
+msgstr ""
+#. Tag: para
+#: installation.xml:856
+#, no-c-format
+msgid "Run the generated nation load commandline scripts."
+msgstr ""
+#: installation.xml:857
+#, no-c-format
+msgid ""
+"cd /gisdata\n"
+"sh nation_script_load.sh"
+msgstr ""
+#. Tag: para
+#: installation.xml:860
+#, no-c-format
+msgid ""
+"After you are done running the nation script, you should have three tables "
+"in your <code>tiger_data</code> schema and they should be filled with data. "
+"Confirm you do by doing the following queries from psql or pgAdmin"
+msgstr ""
+#: installation.xml:861
+#, no-c-format
+msgid "SELECT count(*) FROM tiger_data.county_all;"
+msgstr ""
+#. Tag: screen
+#: installation.xml:862
+#, no-c-format
+msgid ""
+"count\n"
+"-------\n"
+"  3233\n"
+"(1 row)"
+msgstr ""
+#: installation.xml:863
+#, no-c-format
+msgid "SELECT count(*) FROM tiger_data.state_all;"
+msgstr ""
+#. Tag: screen
+#: installation.xml:864
+#, no-c-format
+msgid ""
+"count\n"
+"-------\n"
+"    56\n"
+"(1 row)"
+msgstr ""
+#. Tag: para
+#: installation.xml:867
+#, no-c-format
+msgid ""
+"By default the tables corresponding to <varname>bg</varname>, "
+"<varname>tract</varname>, <varname>tabblock</varname> are not loaded. These "
+"tables are not used by the geocoder but are used by folks for population "
+"statistics. If you wish to load them as part of your state loads, run the "
+"following statement to enable them."
+msgstr ""
+#: installation.xml:869
+#, no-c-format
+msgid ""
+"UPDATE tiger.loader_lookuptables SET load = true WHERE load = false AND "
+"lookup_name IN('tract', 'bg', 'tabblock');"
+msgstr ""
+#. Tag: para
+#: installation.xml:870
+#, no-c-format
+msgid ""
+"Alternatively you can load just these tables after loading state data using "
+"the <xref linkend=\"Loader_Generate_Census_Script\"/>"
+msgstr ""
+#. Tag: para
+#: installation.xml:872
+#, no-c-format
+msgid ""
+"For each state you want to load data for, generate a state script <xref "
+"linkend=\"Loader_Generate_Script\"/>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"DO NOT Generate the state script until you have already loaded the nation "
+"data, because the state script utilizes county list loaded by nation script."
+msgstr ""
+#: installation.xml:874
+#, no-c-format
+msgid ""
+"psql -c \"SELECT Loader_Generate_Script(ARRAY['MA'], 'debbie')\" -d geocoder "
+"-tA > /gisdata/ma_load.sh"
+msgstr ""
+#. Tag: para
+#: installation.xml:876
+#, no-c-format
+msgid "Run the generated commandline scripts."
+msgstr ""
+#: installation.xml:877
+#, no-c-format
+msgid ""
+"cd /gisdata\n"
+"sh ma_load.sh"
+msgstr ""
+#. Tag: para
+#: installation.xml:879
+#, no-c-format
+msgid ""
+"After you are done loading all data or at a stopping point, it's a good idea "
+"to analyze all the tiger tables to update the stats (include inherited stats)"
+msgstr ""
+#: installation.xml:880
+#, no-c-format
+msgid ""
+"SELECT install_missing_indexes();\n"
+"vacuum (analyze, verbose) tiger.addr;\n"
+"vacuum (analyze, verbose) tiger.edges;\n"
+"vacuum (analyze, verbose) tiger.faces;\n"
+"vacuum (analyze, verbose) tiger.featnames;\n"
+"vacuum (analyze, verbose) tiger.place;\n"
+"vacuum (analyze, verbose) tiger.cousub;\n"
+"vacuum (analyze, verbose) tiger.county;\n"
+"vacuum (analyze, verbose) tiger.state;\n"
+"vacuum (analyze, verbose) tiger.zip_lookup_base;\n"
+"vacuum (analyze, verbose) tiger.zip_state;\n"
+"vacuum (analyze, verbose) tiger.zip_state_loc;"
+msgstr ""
+#. Tag: title
+#: installation.xml:883
+#, no-c-format
+msgid "Converting a Tiger Geocoder Regular Install to Extension Model"
+msgstr ""
+#. Tag: para
+#: installation.xml:884
+#, no-c-format
+msgid ""
+"If you installed the tiger geocoder without using the extension model, you "
+"can convert to the extension model as follows:"
+msgstr ""
+#. Tag: para
+#: installation.xml:886
+#, no-c-format
+msgid ""
+"Follow instructions in <xref linkend=\"upgrade_tiger_geocoder\"/> for the "
+"non-extension model upgrade."
+msgstr ""
+#. Tag: para
+#: installation.xml:887
+#, no-c-format
+msgid ""
+"Connect to your database with psql or pgAdmin and run the following command:"
+msgstr ""
+#: installation.xml:888
+#, no-c-format
+msgid "CREATE EXTENSION postgis_tiger_geocoder FROM unpackaged;"
+msgstr ""
+#. Tag: title
+#: installation.xml:895
+#, no-c-format
+msgid "Tiger Geocoder Enabling your PostGIS database: Not Using Extensions"
+msgstr ""
+#. Tag: para
+#: installation.xml:896
+#, no-c-format
+msgid "First install PostGIS using the prior instructions."
+msgstr ""
+#. Tag: para
+#: installation.xml:900 installation.xml:960
+#, no-c-format
+msgid ""
+"If you don't have an extras folder, download <ulink url="
+"\"&postgis_download_url;\">&postgis_download_url;</ulink>"
+msgstr ""
+#. Tag: command
+#: installation.xml:905 installation.xml:965
+#, no-c-format
+msgid "tar xvfz postgis-&last_release_version;.tar.gz"
+msgstr ""
+#. Tag: command
+#: installation.xml:909
+#, no-c-format
+msgid "cd postgis-&last_release_version;/extras/tiger_geocoder"
+msgstr ""
+#. Tag: para
+#: installation.xml:912
+#, no-c-format
+msgid ""
+"Edit the <filename>tiger_loader_2015.sql</filename> (or latest loader file "
+"you find, unless you want to load different year) to the paths of your "
+"executables server etc or alternatively you can update the "
+"<varname>loader_platform</varname> table once installed. If you don't edit "
+"this file or the <varname>loader_platform</varname> table, it will just "
+"contain common case locations of items and you'll have to edit the generated "
+"script after the fact when you run the <xref linkend="
+"\"Loader_Generate_Nation_Script\"/> and <xref linkend="
+"\"Loader_Generate_Script\"/> SQL functions."
+msgstr ""
+#. Tag: para
+#: installation.xml:914
+#, no-c-format
+msgid ""
+"If you are installing Tiger geocoder for the first time edit either the "
+"<filename>create_geocode.bat</filename> script If you are on windows or the "
+"<filename>create_geocode.sh</filename> if you are on Linux/Unix/Mac OSX with "
+"your PostgreSQL specific settings and run the corresponding script from the "
+"commandline."
+msgstr ""
+#. Tag: para
+#: installation.xml:918
+#, no-c-format
+msgid ""
+"Verify that you now have a <varname>tiger</varname> schema in your database "
+"and that it is part of your database search_path. If it is not, add it with "
+"a command something along the line of:"
+msgstr ""
+#, no-c-format
+msgid "ALTER DATABASE geocoder SET search_path=public, tiger;"
+msgstr ""
+#. Tag: para
+#: installation.xml:919
+#, no-c-format
+msgid ""
+"The normalizing address functionality works more or less without any data "
+"except for tricky addresses. Run this test and verify things look like this:"
+msgstr ""
+#: installation.xml:920
+#, no-c-format
+msgid ""
+"SELECT pprint_addy(normalize_address('202 East Fremont Street, Las Vegas, "
+"Nevada 89101')) As pretty_address;\n"
+"pretty_address\n"
+"---------------------------------------\n"
+"202 E Fremont St, Las Vegas, NV 89101"
+msgstr ""
+#. Tag: title
+#: installation.xml:923
+#, no-c-format
+msgid "Using Address Standardizer Extension with Tiger geocoder"
+msgstr ""
+#. Tag: para
+#: installation.xml:924
+#, no-c-format
+msgid ""
+"One of the many complaints of folks is the address normalizer function <xref "
+"linkend=\"Normalize_Address\"/> function that normalizes an address for "
+"prepping before geocoding. The normalizer is far from perfect and trying to "
+"patch its imperfectness takes a vast amount of resources. As such we have "
+"integrated with another project that has a much better address standardizer "
+"engine. To use this new address_standardizer, you compile the extension as "
+"described in <xref linkend=\"installing_pagc_address_standardizer\"/> and "
+"install as an extension in your database."
+msgstr ""
+#. Tag: para
+#: installation.xml:927
+#, no-c-format
+msgid ""
+"Once you install this extension in the same database as you have installed "
+"<code>postgis_tiger_geocoder</code>, then the <xref linkend="
+"\"Pagc_Normalize_Address\"/> can be used instead of <xref linkend="
+"\"Normalize_Address\"/>. This extension is tiger agnostic, so can be used "
+"with other data sources such as international addresses. The tiger geocoder "
+"extension does come packaged with its own custom versions of <xref linkend="
+"\"rulestab\"/> ( <code>tiger.pagc_rules</code>) , <xref linkend=\"gaztab\"/> "
+"(<code>tiger.pagc_gaz</code>), and <xref linkend=\"lextab\"/> (<code>tiger."
+"pagc_lex</code>). These you can add and update to improve your standardizing "
+"experience for your own needs."
+msgstr ""
+#. Tag: title
+#: installation.xml:930
+#, no-c-format
+msgid "Loading Tiger Data"
+msgstr ""
+#. Tag: para
+#: installation.xml:931
+#, no-c-format
+msgid ""
+"The instructions for loading data are available in a more detailed form in "
+"the <filename>extras/tiger_geocoder/tiger_2011/README</filename>. This just "
+"includes the general steps."
+msgstr ""
+#. Tag: para
+#: installation.xml:932
+#, no-c-format
+msgid ""
+"The load process downloads data from the census website for the respective "
+"nation files, states requested, extracts the files, and then loads each "
+"state into its own separate set of state tables. Each state table inherits "
+"from the tables defined in <varname>tiger</varname> schema so that its "
+"sufficient to just query those tables to access all the data and drop a set "
+"of state tables at any time using the <xref linkend="
+"\"Drop_State_Tables_Generate_Script\"/> if you need to reload a state or "
+"just don't need a state anymore."
+msgstr ""
+#. Tag: para
+#: installation.xml:934
+#, no-c-format
+msgid "In order to be able to load data you'll need the following tools:"
+msgstr ""
+#. Tag: para
+#: installation.xml:936
+#, no-c-format
+msgid "A tool to unzip the zip files from census website."
+msgstr ""
+#. Tag: para
+#: installation.xml:937
+#, no-c-format
+msgid ""
+"For Unix like systems: <varname>unzip</varname> executable which is usually "
+"already installed on most Unix like platforms."
+msgstr ""
+#. Tag: para
+#: installation.xml:938
+#, no-c-format
+msgid ""
+"For Windows, 7-zip which is a free compress/uncompress tool you can download "
+"from <ulink url=\"http://www.7-zip.org/\">http://www.7-zip.org/</ulink>"
+msgstr ""
+#. Tag: para
+#: installation.xml:940
+#, no-c-format
+msgid ""
+"<filename>shp2pgsql</filename> commandline which is installed by default "
+"when you install PostGIS."
+msgstr ""
+#. Tag: para
+#: installation.xml:941
+#, no-c-format
+msgid ""
+"<filename>wget</filename> which is a web grabber tool usually installed on "
+"most Unix/Linux systems."
+msgstr ""
+#. Tag: para
+#: installation.xml:942
+#, no-c-format
+msgid ""
+"If you are on windows, you can get pre-compiled binaries from <ulink url="
+"\"http://gnuwin32.sourceforge.net/packages/wget.htm\">http://gnuwin32."
+"sourceforge.net/packages/wget.htm</ulink>"
+msgstr ""
+#. Tag: para
+#: installation.xml:945
+#, no-c-format
+msgid ""
+"If you are upgrading from tiger_2010, you'll need to first generate and run "
+"<xref linkend=\"Drop_Nation_Tables_Generate_Script\"/>. Before you load any "
+"state data, you need to load the nation wide data which you do with <xref "
+"linkend=\"Loader_Generate_Nation_Script\"/>. Which will generate a loader "
+"script for you. <xref linkend=\"Loader_Generate_Nation_Script\"/> is a one-"
+"time step that should be done for upgrading (from 2010) and for new installs."
+msgstr ""
+#. Tag: para
+#: installation.xml:947
+#, no-c-format
+msgid ""
+"To load state data refer to <xref linkend=\"Loader_Generate_Script\"/> to "
+"generate a data load script for your platform for the states you desire. "
+"Note that you can install these piecemeal. You don't have to load all the "
+"states you want all at once. You can load them as you need them."
+msgstr ""
+#. Tag: para
+#: installation.xml:950
+#, no-c-format
+msgid ""
+"After the states you desire have been loaded, make sure to run the: "
+"<programlisting>SELECT install_missing_indexes();</programlisting> as "
+"described in <xref linkend=\"Install_Missing_Indexes\"/>."
+msgstr ""
+#. Tag: para
+#: installation.xml:952
+#, no-c-format
+msgid ""
+"To test that things are working as they should, try to run a geocode on an "
+"address in your state using <xref linkend=\"Geocode\"/>"
+msgstr ""
+#. Tag: title
+#: installation.xml:955
+#, no-c-format
+msgid "Upgrading your Tiger Geocoder Install"
+msgstr ""
+#. Tag: para
+#: installation.xml:956
+#, no-c-format
+msgid ""
+"If you have Tiger Geocoder packaged with 2.0+ already installed, you can "
+"upgrade the functions at any time even from an interim tar ball if there are "
+"fixes you badly need. This will only work for Tiger geocoder not installed "
+"with extensions."
+msgstr ""
+#. Tag: command
+#: installation.xml:969
+#, no-c-format
+msgid "cd postgis-&last_release_version;/extras/tiger_geocoder/tiger_2011"
+msgstr ""
+#. Tag: para
+#: installation.xml:972
+#, no-c-format
+msgid ""
+"Locate the <filename>upgrade_geocoder.bat</filename> script If you are on "
+"windows or the <filename>upgrade_geocoder.sh</filename> if you are on Linux/"
+"Unix/Mac OSX. Edit the file to have your postgis database credentials."
+msgstr ""
+#. Tag: para
+#: installation.xml:975
+#, no-c-format
+msgid ""
+"If you are upgrading from 2010 or 2011, make sure to unremark out the loader "
+"script line so you get the latest script for loading 2012 data."
+msgstr ""
+#. Tag: para
+#: installation.xml:976
+#, no-c-format
+msgid "Then run th corresponding script from the commandline."
+msgstr ""
+#. Tag: para
+#: installation.xml:980
+#, no-c-format
+msgid ""
+"Next drop all nation tables and load up the new ones. Generate a drop script "
+"with this SQL statement as detailed in <xref linkend="
+"\"Drop_Nation_Tables_Generate_Script\"/>"
+msgstr ""
+#. Tag: programlisting
+#: installation.xml:981
+#, no-c-format
+msgid "SELECT drop_nation_tables_generate_script();"
+msgstr ""
+#. Tag: para
+#: installation.xml:982
+#, no-c-format
+msgid "Run the generated drop SQL statements."
+msgstr ""
+#. Tag: para
+#: installation.xml:983
+#, no-c-format
+msgid ""
+"Generate a nation load script with this SELECT statement as detailed in "
+"<xref linkend=\"Loader_Generate_Nation_Script\"/>"
+msgstr ""
+#. Tag: emphasis
+#: installation.xml:984
+#, no-c-format
+msgid "For windows"
+msgstr ""
+#: installation.xml:985
+#, no-c-format
+msgid "SELECT loader_generate_nation_script('windows');"
+msgstr ""
+#. Tag: emphasis
+#: installation.xml:986
+#, no-c-format
+msgid "For unix/linux"
+msgstr ""
+#: installation.xml:987
+#, no-c-format
+msgid "SELECT loader_generate_nation_script('sh');"
+msgstr ""
+#. Tag: para
+#: installation.xml:988
+#, no-c-format
+msgid ""
+"Refer to <xref linkend=\"tiger_geocoder_loading_data\"/> for instructions on "
+"how to run the generate script. This only needs to be done once."
+msgstr ""
+#. Tag: para
+#: installation.xml:989
+#, no-c-format
+msgid ""
+"You can have a mix of 2010/2011 state tables and can upgrade each state "
+"separately. Before you upgrade a state to 2011, you first need to drop the "
+"2010 tables for that state using <xref linkend="
+"\"Drop_State_Tables_Generate_Script\"/>."
+msgstr ""
+#. Tag: title
+#: installation.xml:996
+#, no-c-format
+msgid "Common Problems during installation"
+msgstr ""
+#. Tag: para
+#: installation.xml:997
+#, no-c-format
+msgid ""
+"There are several things to check when your installation or upgrade doesn't "
+"go as you expected."
+msgstr ""
+#. Tag: para
+#: installation.xml:1004
+#, no-c-format
+msgid ""
+"Check that you have installed PostgreSQL &min_postgres_version; or newer, "
+"and that you are compiling against the same version of the PostgreSQL source "
+"as the version of PostgreSQL that is running. Mix-ups can occur when your "
+"(Linux) distribution has already installed PostgreSQL, or you have otherwise "
+"installed PostgreSQL before and forgotten about it. PostGIS will only work "
+"with PostgreSQL &min_postgres_version; or newer, and strange, unexpected "
+"error messages will result if you use an older version. To check the version "
+"of PostgreSQL which is running, connect to the database using psql and run "
+"this query:"
+msgstr ""
+#: installation.xml:1017
+#, no-c-format
+msgid "SELECT version();"
+msgstr ""
+#. Tag: para
+#: installation.xml:1019
+#, no-c-format
+msgid ""
+"If you are running an RPM based distribution, you can check for the "
+"existence of pre-installed packages using the <command>rpm</command> command "
+"as follows: <command>rpm -qa | grep postgresql</command>"
+msgstr ""
+#. Tag: para
+#: installation.xml:1027
+#, no-c-format
+msgid ""
+"If your upgrade fails, make sure you are restoring into a database that "
+"already has PostGIS installed."
+msgstr ""
+#: installation.xml:1028
+#, no-c-format
+msgid "SELECT postgis_full_version();"
+msgstr ""
+#. Tag: para
+#: installation.xml:1032
+#, no-c-format
+msgid ""
+"Also check that configure has correctly detected the location and version of "
+"PostgreSQL, the Proj library and the GEOS library."
+msgstr ""
+#. Tag: para
+#: installation.xml:1039
+#, no-c-format
+msgid ""
+"The output from configure is used to generate the <filename>postgis_config."
+"h</filename> file. Check that the <varname>POSTGIS_PGSQL_VERSION</varname>, "
+"<varname>POSTGIS_PROJ_VERSION</varname> and <varname>POSTGIS_GEOS_VERSION</"
+"varname> variables have been set correctly."
+msgstr ""
Summary of changes:
 .../{templates/installation.xml.pot => zh_Hans/installation.xml.po} | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
 copy doc/po/{templates/installation.xml.pot => zh_Hans/installation.xml.po} (99%)
hooks/post-receive
