[postgis-tickets] [SCM] postgis.net branch hugo updated. 3cdbc54e5e56a4d138ed6faf0e1576670529042d
git at osgeo.org
git at osgeo.org
Sat Feb 26 00:37:30 PST 2022
the project "postgis.net".
The branch, hugo has been updated
via 3cdbc54e5e56a4d138ed6faf0e1576670529042d (commit)
from eaeb0be58a98800903ba1a2a57ac3c105c8b3120 (commit)
revisions in full, below.
commit 3cdbc54e5e56a4d138ed6faf0e1576670529042d
Author: Regina Obe <lr at pcorp.us>
Date: Sat Feb 26 03:37:26 2022 -0500
Revert syntax back to way it was, causing the mode not to change
diff --git a/config/_default/markup.toml b/config/_default/markup.toml
index 197885b..ae478b0 100644
--- a/config/_default/markup.toml
+++ b/config/_default/markup.toml
@@ -10,8 +10,8 @@
guessSyntax = true
hl_Lines = "--"
lineNoStart = 1
- lineNos = false # always set to true # else line numbers won't show at all! even when you toggle them on in the UI
+ lineNos = true # always set to true # else line numbers won't show at all! even when you toggle them on in the UI
lineNumbersInTable = false # toggling this on (i.e to true) or deleting this line will break the code blocks functionality. Will
- noClasses = true
- style = "native"
+ noClasses = false
+ # style = "monokai"
tabWidth = 2
Summary of changes:
config/_default/markup.toml | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
postgis.net
