[postgis-tickets] [PostGIS] #5105: TopoGeo_addLineString turns topology invalid
trac at osgeo.org
Sun Feb 27 13:26:21 PST 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: topology | Version: master
Resolution: | Keywords: reliability
Comment (by strk):
On a closer look, the "face has multiple shells" seems to be a false
invalidity, as the reported "shell" is actually a ring formed only by
dangling edges. The Topology validation code is using
`ST_IsPolygonCCW(ST_MakePolygon($ringedges))` to determine if the ring is
a shell, erroneously expecting that a "flat" ring would always return
false from ST_IsPolygonCCW but this is evidently not the case.
The manual does not mention any explicit handling of such cases, I'd think
a NULL could be returned, or what other options do you see ?
https://postgis.net/docs/ST_IsPolygonCCW.html
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5105#comment:4>
