[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-617-g94199925c
git at osgeo.org
git at osgeo.org
Mon Feb 28 04:11:01 PST 2022
the project "PostGIS".
via 94199925ccb2e24ed2dfd9ce07f829fa233a4321 (commit)
via efd0954b64d6d19f3c4362daa0cb44bdb534c0ea (commit)
from 1d5778cdfadfbc02725b77cb2563737766de66d1 (commit)
revisions in full, below.
commit 94199925ccb2e24ed2dfd9ce07f829fa233a4321
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Feb 28 13:08:10 2022 +0100
Allow make update-po and update-pot in out-of-source builds
diff --git a/doc/Makefile.in b/doc/Makefile.in
index b7e093553..e02f5f459 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -168,7 +168,7 @@ XML_GENERATED_SOURCES = \
XML_INPUTS = $(XML_SOURCES) $(XML_GENERATED_SOURCES)
-XML_INPUTS_POT = $(XML_SOURCES:%.xml=po/templates/%.xml.pot)
+XML_INPUTS_POT = $(XML_SOURCES:%.xml=$(srcdir)/po/templates/%.xml.pot)
VPATH = $(srcdir)
@@ -176,7 +176,7 @@ VPATH = $(srcdir)
ifeq ($(XML2POT),)
$(XML_INPUTS_POT): requirements_not_met_xml2pot
else
-$(XML_INPUTS_POT): po/templates/%.xml.pot: %.xml
+$(XML_INPUTS_POT): $(srcdir)/po/templates/%.xml.pot: %.xml
@if test -f $@; then \
$(XML2POT) $< > $@.tmp; \
changed=`diff $@.tmp $@ \
@@ -206,8 +206,8 @@ update-po: $(XML_INPUTS_POT)
@for lang in $(translations); do \
echo "Creating po files for language $$lang..." ; \
for pot in $(XML_INPUTS_POT); do \
- mkdir -p po/$$lang; \
- po=po/$$lang/`basename $$pot .pot`.po; \
+ mkdir -p $(srcdir)/po/$$lang; \
+ po=$(srcdir)/po/$$lang/`basename $$pot .pot`.po; \
if test -f $$po; then \
$(MSGMERGE) --no-fuzzy-matching --update $$po $$pot; \
else \
commit efd0954b64d6d19f3c4362daa0cb44bdb534c0ea
Date: Mon Feb 28 12:58:32 2022 +0100
Improve ValidateTopology documentation
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 5aa96ee98..1a3624391 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -573,126 +573,227 @@ detailing issues with topology, optionally limiting the check to the
area specified by the <varname>bbox</varname> parameter.
</para>
- <para>List of possible errors and what the returned ids represent are displayed below:</para>
+ <para>List of possible errors, what they mean and what the returned ids represent are displayed below:</para>
<informaltable rowsep="1" frame="all">
- <tgroup cols="3">
- <thead><row><entry>Error</entry><entry>id1</entry><entry>id2</entry></row></thead>
+ <tgroup cols="4">
+ <thead>
+ <row>
+ <entry>Error</entry>
+ <entry>id1</entry>
+ <entry>id2</entry>
+ <entry>Meaning</entry>
+ </row>
+ </thead>
<tbody>
<row>
<entry>coincident nodes</entry>
- <entry>node_id</entry>
- <entry>null</entry>
+ <entry>Identifier of first node.</entry>
+ <entry>Identifier of second node.</entry>
+ <entry>
+Two nodes have the same geometry.
+ </entry>
</row>
<row>
<entry>edge crosses node</entry>
- <entry>edge_id</entry>
+ <entry>Identifier of the edge.</entry>
+ <entry>Identifier of the node.</entry>
+ <entry>
+An edge has a node in its interior.
+See <xref linkend="ST_Relate"/>.
+ </entry>
</row>
<row>
<entry>invalid edge</entry>
+ <entry></entry>
+ <entry>
+An edge geometry is invalid.
+See <xref linkend="ST_IsValid" />.
+ </entry>
</row>
<row>
<entry>edge not simple</entry>
+ <entry></entry>
+ <entry>
+An edge geometry has self-intersections.
+See <xref linkend="ST_IsSimple" />.
+ </entry>
</row>
<row>
<entry>edge crosses edge</entry>
+ <entry>Identifier of first edge.</entry>
+ <entry>Identifier of second edge.</entry>
+ <entry>
+Two edges have an interior intersection.
+ </entry>
</row>
<row>
<entry>edge start node geometry mis-match</entry>
+ <entry>
+Identifier of the indicated start node.
+ </entry>
+ <entry>
+The geometry of the node indicated as the starting node for an edge does
+not match the first point of the edge geometry.
+See <xref linkend="ST_StartPoint"/>.
+ </entry>
</row>
<row>
<entry>edge end node geometry mis-match</entry>
+ <entry>
+Identifier of the indicated end node.
+ </entry>
+ <entry>
+The geometry of the node indicated as the ending node for an edge does
+not match the last point of the edge geometry.
+See <xref linkend="ST_EndPoint"/>.
+ </entry>
</row>
<row>
<entry>face without edges</entry>
- <entry>face_id</entry>
+ <entry>
+Identifier of the orphaned face.
+ </entry>
+ <entry></entry>
+ <entry>
+No edge reports an existing face on either of its sides
+(left_face, right_face).
+ </entry>
</row>
<row>
<entry>face has no rings</entry>
+ <entry>
+Identifier of the partially-defined face.
+ </entry>
+ <entry></entry>
+ <entry>
+Edges reporting a face on their sides do not form a ring.
+ </entry>
</row>
<row>
<entry>face has wrong mbr</entry>
+ <entry>
+Identifier of the face with wrong mbr cache.
+ </entry>
+ <entry></entry>
+ <entry>
+Minimum bounding rectangle of a face does not match minimum bounding
+box of the collection of edges reporting the face on their sides.
+ </entry>
</row>
<row>
<entry>hole not in advertised face</entry>
- <entry>signed edge_id identifying the ring</entry>
+ <entry>
+Signed identifier of an edge, identifying the ring.
+See <xref linkend="GetRingEdges"/>.
+ </entry>
+ <entry></entry>
+ <entry>
+A ring of edges reporting a face on its exterior
+is contained in different face.
+ </entry>
</row>
<row>
- <entry>not-isolated node has not-null containing_face</entry>
+ <entry>not-isolated node has not- containing_face</entry>
+ <entry>
+Identifier of the ill-defined node.
+ </entry>
+ <entry></entry>
+ <entry>
+A node which is reported as being on the boundary of one or more edges
+is indicating a containing face.
+ </entry>
</row>
<row>
- <entry>isolated node has null containing_face</entry>
+ <entry>isolated node has containing_face</entry>
+ <entry>
+ </entry>
+ <entry></entry>
+ <entry>
+A node which is not reported as being on the boundary of any edges
+is lacking the indication of a containing face.
+ </entry>
</row>
<row>
<entry>isolated node has wrong containing_face</entry>
+ <entry>
+Identifier of the misrepresented node.
+ </entry>
+ <entry></entry>
+ <entry>
+indicates a containing face which is not the actual face containing it.
+See <xref linkend="GetFaceContainingPoint" />.
+ </entry>
</row>
<row>
<entry>invalid next_right_edge</entry>
+ <entry>
+Identifier of the misrepresented edge.
+ </entry>
+ <entry>
+Signed id of the edge which should be indicated as the next right edge.
+ </entry>
+ <entry>
+The edge indicated as the next edge encountered walking on the right
+side of an edge is wrong.
+ </entry>
</row>
<row>
<entry>invalid next_left_edge</entry>
+ <entry>
+ </entry>
+ <entry>
+Signed id of the edge which should be indicated as the next left edge.
+ </entry>
+ <entry>
+left side of an edge is wrong.
+ </entry>
</row>
<row>
<entry>mixed face labeling in ring</entry>
+ <entry>
+ </entry>
+ <entry></entry>
+ <entry>
+Edges in a ring indicate conflicting faces on the walking side.
+This is also known as a "Side Location Conflict".
+ </entry>
</row>
<row>
<entry>non-closed ring</entry>
+ <entry>
+ </entry>
+ <entry></entry>
+ <entry>
+A ring of edges formed by following next_left_edge/next_right_edge
+attributes starts and ends on different nodes.
+ </entry>
</row>
<row>
<entry>face has multiple shells</entry>
- </row>
- <row>
- <entry>face overlaps face</entry>
- </row>
- <row>
- <entry>face within face</entry>
- <entry>inner face_id</entry>
- <entry>outer face_id</entry>
- </row>
- <row>
- <entry>invalid next_left_edge</entry>
- <entry>expected next_left_edge value</entry>
- </row>
- <row>
- <entry>invalid next_right_edge</entry>
- <entry>expected next_right_edge value</entry>
+ <entry>
+Identifier of the contended face.
+ </entry>
+ <entry>
+ </entry>
+ <entry>
+More than a one ring of edges indicate the same face on its interior.
+ </entry>
</row>
</tbody>
</tgroup>
Summary of changes:
doc/Makefile.in | 8 +-
doc/extras_topology.xml | 227 ++++++++++++++++++++++++++++++++++--------------
2 files changed, 168 insertions(+), 67 deletions(-)
hooks/post-receive
