[postgis-tickets] [PostGIS] #5105: False topology invalidity returned in presence of dangling edgerings
trac at osgeo.org
Mon Feb 28 07:14:56 PST 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: topology | Version: master
Resolution: | Keywords: reliability
Comment (by strk):
I filed #5107 for tthe ST_Area issue. As for this case, here's an example
flat polygon found to be CCW by ST_IsPolygonCCW:
=# select ST_IsPolygonCCW('
POLYGON((
29.262792863298348 71.22115103790775,
29.26598031986849 71.22202978558047,
29.275379947735576 71.22044935739267,
29.29461024331857 71.22741507590429,
st_ispolygonccw
t
(1 row)
The cause could be the same (winding computed using signed area)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5105#comment:9>
