[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-621-g8108dd5fd
git at osgeo.org
git at osgeo.org
Mon Feb 28 17:17:24 PST 2022
the project "PostGIS".
via 8108dd5fd31936f449d958629a5e503003b50b73 (commit)
via 0b67924d22ec6ef5c095c41660d7cd9788027245 (commit)
from e057379151eba06435d46766eaad0bf8351a8971 (commit)
revisions in full, below.
commit 8108dd5fd31936f449d958629a5e503003b50b73
Merge: 0b67924d2 e05737915
Author: Regina Obe <lr at pcorp.us>
Date: Mon Feb 28 20:17:03 2022 -0500
Merge branch 'master' of git.osgeo.org:postgis/postgis
commit 0b67924d22ec6ef5c095c41660d7cd9788027245
Date: Mon Feb 28 15:40:17 2022 -0500
search_path vulnerability during install. References #5069
diff --git a/extensions/postgis/unpackage_raster_if_needed.sql b/extensions/postgis/unpackage_raster_if_needed.sql
index 9d48244f1..bee2a83f9 100644
--- a/extensions/postgis/unpackage_raster_if_needed.sql
+++ b/extensions/postgis/unpackage_raster_if_needed.sql
@@ -1,10 +1,10 @@
DO $unpackage_if_needed$
BEGIN
IF EXISTS (
- select t.typname from pg_depend d, pg_extension e, pg_type t where
+ select t.typname from pg_catalog.pg_depend d, pg_catalog.pg_extension e, pg_catalog.pg_type t where
e.extname = 'postgis' and d.refclassid =
'pg_catalog.pg_extension'::pg_catalog.regclass and d.refobjid = e.oid
- and d.classid = 'pg_type'::regclass and d.objid = t.oid
+ and d.classid = 'pg_catalog.pg_type'::pg_catalog.regclass and d.objid = t.oid
and t.typname = 'raster'
) THEN
diff --git a/extensions/postgis_extension_helper.sql b/extensions/postgis_extension_helper.sql
index bc1e9f92d..77ef0db74 100644
--- a/extensions/postgis_extension_helper.sql
+++ b/extensions/postgis_extension_helper.sql
@@ -30,38 +30,38 @@ DECLARE
var_sql_list text := '';
var_pgsql_version integer := current_setting('server_version_num');
BEGIN
- var_class := CASE WHEN lower(param_type) = 'function' OR lower(param_type) = 'aggregate' THEN 'pg_proc' ELSE '' END;
- var_is_aggregate := CASE WHEN lower(param_type) = 'aggregate' THEN true ELSE false END;
+ var_class := CASE WHEN pg_catalog.lower(param_type) = 'function' OR pg_catalog.lower(param_type) = 'aggregate' THEN 'pg_catalog.pg_proc' ELSE '' END;
+ var_is_aggregate := CASE WHEN pg_catalog.lower(param_type) = 'aggregate' THEN true ELSE false END;
IF var_pgsql_version < 110000 THEN
var_sql_list := $sql$SELECT 'ALTER EXTENSION ' || e.extname || ' DROP ' || $3 || ' ' || COALESCE(proc.proname || '(' || oidvectortypes(proc.proargtypes) || ')' ,typ.typname, cd.relname, op.oprname,
cs.typname || ' AS ' || ct.typname || ') ', opcname, opfname) || ';' AS remove_command
- FROM pg_depend As d INNER JOIN pg_extension As e
- ON d.refobjid = e.oid INNER JOIN pg_class As c ON
+ FROM pg_catalog.pg_depend As d INNER JOIN pg_catalog.pg_extension As e
+ ON d.refobjid = e.oid INNER JOIN pg_catalog.pg_class As c ON
c.oid = d.classid
- LEFT JOIN pg_proc AS proc ON proc.oid = d.objid
- LEFT JOIN pg_type AS typ ON typ.oid = d.objid
- LEFT JOIN pg_class As cd ON cd.oid = d.objid
+ LEFT JOIN pg_catalog.pg_proc AS proc ON proc.oid = d.objid
+ LEFT JOIN pg_catalog.pg_type AS typ ON typ.oid = d.objid
+ LEFT JOIN pg_catalog.pg_class As cd ON cd.oid = d.objid
LEFT JOIN pg_operator As op ON op.oid = d.objid
- LEFT JOIN pg_cast AS ca ON ca.oid = d.objid
- LEFT JOIN pg_type AS cs ON ca.castsource = cs.oid
- LEFT JOIN pg_type AS ct ON ca.casttarget = ct.oid
+ LEFT JOIN pg_catalog.pg_cast AS ca ON ca.oid = d.objid
+ LEFT JOIN pg_catalog.pg_type AS cs ON ca.castsource = cs.oid
+ LEFT JOIN pg_catalog.pg_type AS ct ON ca.casttarget = ct.oid
LEFT JOIN pg_opclass As oc ON oc.oid = d.objid
LEFT JOIN pg_opfamily As ofa ON ofa.oid = d.objid
WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND COALESCE(proc.proisagg, false) = $4;$sql$;
ELSE -- for PostgreSQL 11 and above, they removed proc.proisagg among others and replaced with some func type thing
c.oid = d.classid
WHERE d.deptype = 'e' and e.extname = $1 and c.relname = $2 AND (proc.prokind = 'a') = $4;$sql$;
@@ -85,7 +85,7 @@ CREATE OR REPLACE FUNCTION postgis_extension_drop_if_exists(param_extension text
RETURNS boolean AS
DECLARE
- var_sql_ext text := 'ALTER EXTENSION ' || quote_ident(param_extension) || ' ' || replace(param_statement, 'IF EXISTS', '');
+ var_sql_ext text := 'ALTER EXTENSION ' || pg_catalog.quote_ident(param_extension) || ' ' || replace(param_statement, 'IF EXISTS', '');
var_result boolean := false;
BEGIN
BEGIN
@@ -109,13 +109,13 @@ DECLARE
var_result text;
var_cur_search_path text;
BEGIN
- SELECT reset_val INTO var_cur_search_path FROM pg_settings WHERE name = 'search_path';
- IF var_cur_search_path LIKE '%' || quote_ident(a_schema_name) || '%' THEN
+ SELECT reset_val INTO var_cur_search_path FROM pg_catalog.pg_settings WHERE name = 'search_path';
+ IF var_cur_search_path LIKE '%' || pg_catalog.quote_ident(a_schema_name) || '%' THEN
var_result := a_schema_name || ' already in database search_path';
ELSE
var_cur_search_path := var_cur_search_path || ', '
- || quote_ident(a_schema_name);
- EXECUTE 'ALTER DATABASE ' || quote_ident(current_database())
+ || pg_catalog.quote_ident(a_schema_name);
+ EXECUTE 'ALTER DATABASE ' || pg_catalog.quote_ident(pg_catalog.current_database())
|| ' SET search_path = ' || var_cur_search_path;
var_result := a_schema_name || ' has been added to end of database search_path ';
END IF;
diff --git a/extras/tiger_geocoder/utility/set_search_path.sql b/extras/tiger_geocoder/utility/set_search_path.sql
index c8e8595bb..19d2f9523 100644
--- a/extras/tiger_geocoder/utility/set_search_path.sql
+++ b/extras/tiger_geocoder/utility/set_search_path.sql
@@ -13,9 +13,9 @@ DECLARE
var_result text;
BEGIN
- EXECUTE 'SET search_path = ' || quote_ident(a_schema_name) || ', ' || var_cur_search_path;
+ EXECUTE 'SET search_path = ' || pg_catalog.quote_ident(a_schema_name) || ', ' || var_cur_search_path;
var_result := a_schema_name || ' has been made primary for install ';
RETURN var_result;
END
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index 5b4e904ab..372124147 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -162,7 +162,7 @@ CREATE OR REPLACE FUNCTION postgis_typmod_type(integer)
-- Changed: 2.4.0 Limit to only list things that are tables
CREATE OR REPLACE VIEW geography_columns AS
SELECT
- current_database() AS f_table_catalog,
+ pg_catalog.current_database() AS f_table_catalog,
n.nspname AS f_table_schema,
c.relname AS f_table_name,
a.attname AS f_geography_column,
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index a66f82370..c0a206059 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -29,15 +29,15 @@ DO $$
DECLARE
pgver text;
BEGIN
- SELECT substring(version(), 'PostgreSQL ([0-9\.]+)') INTO pgver;
+ SELECT pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') INTO pgver;
IF POSTGIS_PGSQL_VERSION::text != ( SELECT CASE
- WHEN split_part(s,'.',1)::integer > 9
- THEN split_part(s,'.',1) || '0'
+ WHEN pg_catalog.split_part(s,'.',1)::integer > 9
+ THEN pg_catalog.split_part(s,'.',1) || '0'
ELSE
- split_part(s,'.', 1) || split_part(s,'.', 2)
+ pg_catalog.split_part(s,'.', 1) || pg_catalog.split_part(s,'.', 2)
END
- FROM substring(version(), 'PostgreSQL ([0-9\.]+)') AS s )
+ FROM pg_catalog.substring(pg_catalog.version(), 'PostgreSQL ([0-9\.]+)') AS s )
THEN
RAISE EXCEPTION 'PostGIS built for PostgreSQL % cannot be loaded in PostgreSQL %',
POSTGIS_PGSQL_HR_VERSION, pgver;
@@ -52,7 +52,7 @@ DECLARE
rec RECORD;
BEGIN
FOR rec IN
- SELECT n.nspname, p.proname FROM pg_proc p, pg_namespace n
+ SELECT n.nspname, p.proname FROM pg_catalog.pg_proc p, pg_catalog.pg_namespace n
WHERE p.proname = 'postgis_version'
AND p.pronamespace = n.oid
LOOP
@@ -71,7 +71,7 @@ DECLARE
BEGIN
SHOW pgaudit.log INTO pgalog;
RAISE DEBUG 'pgaudit is installed, pgaudit.log is set to ''%''', pgalog;
- IF lower(pgalog) != 'none'
+ IF pg_catalog.lower(pgalog) != 'none'
THEN
RAISE EXCEPTION 'PostGIS installation stopped: pgaudit.log is set to ''%''. Set pgaudit.log to ''none'' before installing PostGIS. You may re-enable pgaudit after installation is complete.', pgalog;
END IF;
@@ -94,9 +94,9 @@ BEGIN
-- a WARNING if in a previous version (only up to minor version checked)
curver_text := POSTGIS_LIB_VERSION;
- IF split_part(curver_text,'.',1)::int > split_part(version,'.',1)::int OR
- ( split_part(curver_text,'.',1) = split_part(version,'.',1) AND
- split_part(curver_text,'.',2) != split_part(version,'.',2) )
+ IF pg_catalog.split_part(curver_text,'.',1)::int > pg_catalog.split_part(version,'.',1)::int OR
+ ( pg_catalog.split_part(curver_text,'.',1) = pg_catalog.split_part(version,'.',1) AND
+ pg_catalog.split_part(curver_text,'.',2) != split_part(version,'.',2) )
THEN
RAISE WARNING '% signature was deprecated in %. Please use %', oldname, version, newname;
ELSE
@@ -545,7 +545,7 @@ CREATE OR REPLACE FUNCTION geometry_gist_sortsupport_2d(internal)
-- Given a table, column and query geometry, returns the estimate of what proportion
-- of the table would be returned by a query using the &&/&&& operators. The mode
-- changes whether the estimate is in x/y only or in all available dimensions.
-CREATE OR REPLACE FUNCTION _postgis_selectivity(tbl regclass, att_name text, geom geometry, mode text default '2')
+CREATE OR REPLACE FUNCTION _postgis_selectivity(tbl pg_catalog.regclass, att_name text, geom geometry, mode text default '2')
RETURNS float8
AS 'MODULE_PATHNAME', '_postgis_gserialized_sel'
LANGUAGE 'c' STRICT PARALLEL SAFE;
@@ -2943,7 +2943,7 @@ CREATE OR REPLACE FUNCTION _postgis_scripts_pgsql_version() RETURNS text
CREATE OR REPLACE FUNCTION _postgis_pgsql_version() RETURNS text
AS $$
SELECT CASE WHEN split_part(s,'.',1)::integer > 9 THEN split_part(s,'.',1) || '0' ELSE split_part(s,'.', 1) || split_part(s,'.', 2) END AS v
- FROM substring(version(), 'PostgreSQL ([0-9\.]+)') AS s;
+ FROM pg_catalog.substring(version(), 'PostgreSQL ([0-9\.]+)') AS s;
$$ LANGUAGE 'sql' STABLE;
-- Availability: 2.5.0
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index 44772dd0e..a2195c1f1 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -239,7 +239,7 @@ BEGIN
IF _postgis_scripts_pgsql_version()::integer >= 96 THEN
-- mark ST_Union agg as parallel safe if it is not already
BEGIN
- UPDATE pg_proc SET proparallel = 's'
+ UPDATE pg_catalog.pg_proc SET proparallel = 's'
WHERE oid = 'st_union(geometry)'::regprocedure AND proparallel = 'u';
EXCEPTION WHEN OTHERS THEN
RAISE DEBUG 'Could not update st_union(geometry): %', SQLERRM;
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index d02bdc42e..f901b22da 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -30,8 +30,8 @@
-- FROM pg_catalog.pg_proc p
-- LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
-- WHERE
--- LOWER(n.nspname) = LOWER('public') AND
--- LOWER(p.proname) = LOWER('ST_AsGeoJson')
+-- pg_catalog.LOWER(n.nspname) = pg_catalog.LOWER('public') AND
+-- pg_catalog.LOWER(p.proname) = pg_catalog.LOWER('ST_AsGeoJson')
-- ORDER BY 1, 2, 3, 4;
CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
function_name text,
@@ -53,9 +53,9 @@ BEGIN
SELECT oid
WHERE pronamespace = postgis_namespace
- AND LOWER(p.proname) = LOWER(function_name)
+ AND pg_catalog.LOWER(p.proname) = pg_catalog.LOWER(function_name)
AND pg_catalog.pg_function_is_visible(p.oid)
- AND LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ LOWER(function_arguments)
+ AND pg_catalog.LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ pg_catalog.LOWER(function_arguments)
INTO matching_function;
IF matching_function IS NOT NULL THEN
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index 1be585ddb..02de3390a 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -47,7 +47,7 @@ DECLARE
rec RECORD;
BEGIN
FOR rec IN
WHERE p.proname = 'postgis_raster_lib_version'
LOOP
@@ -63,11 +63,11 @@ DECLARE
nsp TEXT;
BEGIN
SELECT n.nspname
- INTO nsp FROM pg_proc p, pg_namespace n
+ INTO nsp FROM pg_catalog.pg_proc p, pg_catalog.pg_namespace n
WHERE p.proname = 'postgis_lib_version'
AND p.pronamespace = n.oid;
- IF nsp != current_schema() THEN
+ IF nsp != pg_catalog.current_schema() THEN
RAISE EXCEPTION
'PostGIS Raster must be in the same schema as PostGIS (%)',
nsp;
@@ -8715,7 +8715,7 @@ BEGIN
sql := 'SELECT r.r_table_schema sch, r.r_table_name tab, '
|| 'r.scale_x sfx, r.scale_y sfy, r.blocksize_x tw, '
|| 'r.blocksize_y th, r.extent ext, r.srid FROM @extschema at .raster_columns r, '
- || 'pg_class c, pg_namespace n WHERE r.r_table_schema = n.nspname '
+ || 'pg_class c, pg_catalog.pg_namespace n WHERE r.r_table_schema = n.nspname '
|| 'AND r.r_table_name = c.relname AND r_raster_column = $2 AND '
|| ' c.relnamespace = n.oid AND c.oid = $1'
diff --git a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
index 0d6f3ba00..cbcae6bcd 100644
--- a/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
+++ b/raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in
@@ -94,11 +94,11 @@ BEGIN
IF NOT EXISTS (
SELECT
proname
- FROM pg_proc f
- JOIN pg_type r
+ FROM pg_catalog.pg_proc f
+ JOIN pg_catalog.pg_type r
ON r.typname = 'raster'
AND (f.proargtypes::oid[])[0] = r.oid
- JOIN pg_type g
+ JOIN pg_catalog.pg_type g
ON g.typname = 'geometry'
AND (f.proargtypes::oid[])[1] = g.oid
WHERE proname = 'raster_contained_by_geometry'
@@ -117,11 +117,11 @@ BEGIN
IF NOT EXISTS (
SELECT
proname
- FROM pg_proc f
- JOIN pg_type r
AND (f.proargtypes::oid[])[1] = r.oid
- JOIN pg_type g
AND (f.proargtypes::oid[])[0] = g.oid
WHERE proname = 'geometry_contained_by_raster'
@@ -589,7 +589,7 @@ BEGIN
FROM pg_proc f
JOIN pg_type t
ON f.prorettype = t.oid
- WHERE lower(f.proname) = '_raster_constraint_nodata_values'
+ WHERE pg_catalog.lower(f.proname) = '_raster_constraint_nodata_values'
AND f.pronargs = 1
AND t.typname = '_float8'; -- array form
diff --git a/topology/sql/manage/ManageHelper.sql.in b/topology/sql/manage/ManageHelper.sql.in
index 31b70756b..2acfd9c41 100644
--- a/topology/sql/manage/ManageHelper.sql.in
+++ b/topology/sql/manage/ManageHelper.sql.in
@@ -25,13 +25,13 @@ DECLARE
var_result text;
BEGIN
ELSE
END IF;
diff --git a/utils/postgis_proc_upgrade.pl b/utils/postgis_proc_upgrade.pl
index a7fd59061..dff97bc79 100755
--- a/utils/postgis_proc_upgrade.pl
+++ b/utils/postgis_proc_upgrade.pl
@@ -610,22 +610,22 @@ BEGIN
-- FOR rec IN
-- SELECT n.nspname AS schemaname,
-- c.relname AS viewname,
--- pg_get_userbyid(c.relowner) AS viewowner,
--- pg_get_viewdef(c.oid) AS definition,
+-- pg_catalog.pg_get_userbyid(c.relowner) AS viewowner,
+-- pg_catalog.pg_get_viewdef(c.oid) AS definition,
-- CASE
-- WHEN 'check_option=cascaded' = ANY (c.reloptions) THEN 'WITH CASCADED CHECK OPTION'
-- WHEN 'check_option=local' = ANY (c.reloptions) THEN 'WITH LOCAL CHECK OPTION'
-- ELSE ''
-- END::text AS check_option
--- FROM pg_class c
--- LEFT JOIN pg_namespace n ON n.oid = c.relnamespace
+-- FROM pg_catalog.pg_class c
+-- LEFT JOIN pg_catalog.pg_namespace n ON n.oid = c.relnamespace
-- WHERE c.relkind = 'v'
--- AND pg_get_viewdef(c.oid) ~ 'deprecated_by_postgis'
+-- AND pg_catalog.pg_get_viewdef(c.oid) ~ 'deprecated_by_postgis'
-- LOOP
--- sql := format('CREATE OR REPLACE VIEW %I.%I AS %s %s',
+-- sql := pg_catalog.format('CREATE OR REPLACE VIEW %I.%I AS %s %s',
-- rec.schemaname,
-- rec.viewname,
--- regexp_replace(rec.definition, '_deprecated_by_postgis_[^(]*', '', 'g'),
+-- pg_catalog.regexp_replace(rec.definition, '_deprecated_by_postgis_[^(]*', '', 'g'),
-- rec.check_option
-- RAISE NOTICE 'Updating view % to not use deprecated signatures', rec.viewname;
@@ -635,25 +635,25 @@ BEGIN
-- WHEN OTHERS THEN
-- GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
-- RAISE WARNING 'Could not rewrite view % using deprecated functions', rec.viewname
--- USING DETAIL = format('%s: %s', SQLERRM, detail);
+-- USING DETAIL = pg_catalog.format('%s: %s', SQLERRM, detail);
-- END;
-- END LOOP;
-- Try to drop all deprecated functions, or rewrite those
-- who cannot be drop and rewrite them in SQL
- FOR rec IN SELECT unnest(deprecated_functions) as proc
+ FOR rec IN SELECT pg_catalog.unnest(deprecated_functions) as proc
LOOP --{
RAISE DEBUG 'Handling deprecated function %', rec.proc;
- new_name := regexp_replace(
+ new_name := pg_catalog.regexp_replace(
rec.proc::text,
'_deprecated_by_postgis[^(]*\\(.*',
- sql := format('DROP FUNCTION %s', rec.proc);
+ sql := pg_catalog.format('DROP FUNCTION %s', rec.proc);
--RAISE DEBUG 'SQL: %', sql;
BEGIN
EXECUTE sql;
@@ -662,7 +662,7 @@ BEGIN
hint = 'Resolve the issue';
IF detail LIKE '%view % depends%' THEN
- hint = format(
+ hint = pg_catalog.format(
'Replace the view changing all occurrences of %s in its definition with %s',
rec.proc,
new_name
@@ -678,7 +678,7 @@ BEGIN
-- Try to rewrite the function as an SQL WRAPPER
SELECT pg_get_functiondef(oid) def, pronargs
- FROM pg_proc WHERE oid = rec.proc
+ FROM pg_catalog.pg_proc WHERE oid = rec.proc
INTO procrec;
-- TODO: don't even try if it's an aggregate or windowing
@@ -687,14 +687,14 @@ BEGIN
-- function (procrec.prokind)
-- Force LANGUAGE to be SQL
- sql := regexp_replace(procrec.def, 'LANGUAGE [^ \n]*', 'LANGUAGE sql');
+ sql := pg_catalog.regexp_replace(procrec.def, 'LANGUAGE [^ \n]*', 'LANGUAGE sql');
--RAISE DEBUG 'SQL (LANGUAGE): %', sql;
-- Change body to be a wrapper
sql,
-- Find a stricted match here ?
'AS .*',
- format(
+ pg_catalog.format(
-- TODO: have the function raise a warning too ?
'AS \$\$ SELECT %s(%s) \$\$',
new_name,
@@ -727,16 +727,16 @@ BEGIN
FOR extrec IN
SELECT e.extname
FROM
- pg_extension e,
- pg_depend d
+ pg_catalog.pg_extension e,
+ pg_catalog.pg_depend d
WHERE
d.refclassid = 'pg_catalog.pg_extension'::pg_catalog.regclass AND
d.refobjid = e.oid AND
- d.classid = 'pg_proc'::regclass AND
+ d.classid = 'pg_catalog.pg_proc'::pg_catalog.regclass AND
d.objid = rec.proc::oid
LOOP
RAISE DEBUG 'Unpackaging % from extension %', rec.proc, extrec.extname;
- sql := format('ALTER EXTENSION %I DROP FUNCTION %s', extrec.extname, rec.proc);
+ sql := pg_catalog.format('ALTER EXTENSION %I DROP FUNCTION %s', extrec.extname, rec.proc);
EXECUTE sql;
END LOOP;
END;
@@ -783,8 +783,8 @@ BEGIN
SELECT into old_scripts MODULE_scripts_installed();
END;
SELECT into new_scripts 'NEWVERSION';
- SELECT into old_maj substring(old_scripts from 1 for 1);
- SELECT into new_maj substring(new_scripts from 1 for 1);
+ SELECT into old_maj pg_catalog.substring(old_scripts, 1, 1);
+ SELECT into new_maj pg_catalog.substring(new_scripts, 1, 1);
-- 2.x to 3.x was upgrade-compatible, see
-- https://trac.osgeo.org/postgis/ticket/4170#comment:1
@@ -802,18 +802,18 @@ BEGIN
) SELECT
upgraded as scripts_upgraded,
installed as scripts_installed,
- substring(upgraded from '([0-9]+)\.')::int * 100 +
- substring(upgraded from '[0-9]+\.([0-9]+)(\.|$)')::int
+ pg_catalog.substring(upgraded, '([0-9]+)\.')::int * 100 +
+ pg_catalog.substring(upgraded, '[0-9]+\.([0-9]+)(\.|$)')::int
as version_to_num,
- substring(installed from '([0-9]+)\.')::int * 100 +
- substring(installed from '[0-9]+\.([0-9]+)(\.|$)')::int
+ pg_catalog.substring(installed, '([0-9]+)\.')::int * 100 +
+ pg_catalog.substring(installed, '[0-9]+\.([0-9]+)(\.|$)')::int
as version_from_num,
installed ~ 'dev|alpha|beta'
as version_from_isdev
FROM versions INTO postgis_upgrade_info
- postgis_upgrade_info_func_code := format($func_code$
+ postgis_upgrade_info_func_code := pg_catalog.format($func_code$
CREATE FUNCTION _postgis_upgrade_info(OUT scripts_upgraded TEXT,
OUT scripts_installed TEXT,
OUT version_to_num INT,
Summary of changes:
extensions/postgis/unpackage_raster_if_needed.sql | 4 +-
extensions/postgis_extension_helper.sql | 46 +++++++++----------
extras/tiger_geocoder/utility/set_search_path.sql | 4 +-
postgis/geography.sql.in | 2 +-
postgis/postgis.sql.in | 24 +++++-----
postgis/postgis_after_upgrade.sql | 2 +-
postgis/postgis_before_upgrade.sql | 8 ++--
raster/rt_pg/rtpostgis.sql.in | 8 ++--
raster/rt_pg/rtpostgis_upgrade_cleanup.sql.in | 14 +++---
topology/sql/manage/ManageHelper.sql.in | 8 ++--
utils/postgis_proc_upgrade.pl | 54 +++++++++++------------
11 files changed, 87 insertions(+), 87 deletions(-)
hooks/post-receive
