[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-657-gbb3842bfe
git at osgeo.org
git at osgeo.org
Mon Mar 28 06:23:57 PDT 2022
the project "PostGIS".
via bb3842bfeef613f32e5dd032cad85599159ffb76 (commit)
from 1ba6bccae13bfd37383e35f8c0678b08393f6726 (commit)
revisions in full, below.
commit bb3842bfeef613f32e5dd032cad85599159ffb76
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Mar 28 14:30:39 2022 +0200
Allow dropping topologies with missing layer topogeom sequences
Closes #5118 in master branch
Includes regression test
diff --git a/NEWS b/NEWS
index deaefa28a..173815cd2 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.3.0dev
- Drop support for PostgreSQL 9.6 and 10 (Regina Obe)
* Enhancements *
+ - #5118, Allow dropping topologies with missing topogeometry sequences
+ (Sandro Santilli)
- #5111, faster topology face MBR computation (Sandro Santilli)
- postgis_extensions_upgrade() support for upgrades from any PostGIS
version, including yet to be released ones (Sandro Santilli)
diff --git a/topology/test/regress/droptopogeometrycolumn.sql b/topology/test/regress/droptopogeometrycolumn.sql
index 77046b4f9..19ad43699 100644
--- a/topology/test/regress/droptopogeometrycolumn.sql
+++ b/topology/test/regress/droptopogeometrycolumn.sql
@@ -1,10 +1,24 @@
set client_min_messages to ERROR;
-- Drop corrupted topology (with missing layer tables)
-- See http://trac.osgeo.org/postgis/ticket/3016
-SELECT topology.CreateTopology('t1') > 0;
-CREATE TABLE t1f (id int);
-SELECT topology.AddTopoGeometryColumn('t1', 'public', 't1f', 'geom_t1', 'LINE') > 0;
-DROP TABLE t1.relation;
-SELECT topology.DropTopoGeometryColumn('public','t1f','geom_t1');
-DROP TABLE t1f;
-SELECT topology.DropTopology('t1');
+SELECT NULL FROM topology.CreateTopology('t3016');
+CREATE TABLE t3016f (id int);
+SELECT NULL FROM topology.AddTopoGeometryColumn('t3016', 'public', 't3016f', 'g', 'LINE');
+DROP TABLE t3016.relation;
+SELECT 't3016.drop', topology.DropTopoGeometryColumn('public','t3016f','g');
+SELECT 't3016', 'UNEXPECTED LAYER', * FROM topology.layer WHERE table_name = 't5118f';
+DROP TABLE t3016f;
+SELECT NULL FROM topology.DropTopology('t3016');
+-- Drop corrupted topology (with missing layer sequence)
+-- See http://trac.osgeo.org/postgis/ticket/5118
+SELECT NULL FROM topology.CreateTopology('t5118');
+CREATE TABLE t5118f (id int);
+SELECT NULL FROM topology.AddTopoGeometryColumn('t5118', 'public', 't5118f', 'g', 'LINE');
+INSERT INTO t5118f(g) SELECT toTopoGeom('LINESTRING(0 0, 10 0)', 't5118', 1);
+DROP SEQUENCE t5118.topogeo_s_1;
+SELECT 't5118.drop', topology.DropTopoGeometryColumn('public','t5118f','g');
+SELECT 't5118', 'UNEXPECTED LAYER', * FROM topology.layer WHERE table_name = 't5118f';
+DROP TABLE t5118f;
+SELECT NULL FROM topology.DropTopology('t5118');
diff --git a/topology/test/regress/droptopogeometrycolumn_expected b/topology/test/regress/droptopogeometrycolumn_expected
index 65dc643d9..cc45dde87 100644
--- a/topology/test/regress/droptopogeometrycolumn_expected
+++ b/topology/test/regress/droptopogeometrycolumn_expected
@@ -1,4 +1,2 @@
-t
-t
-Layer 1 (public.t1f.geom_t1) dropped
-Topology 't1' dropped
+t3016.drop|Layer 1 (public.t3016f.g) dropped
+t5118.drop|Layer 1 (public.t5118f.g) dropped
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index a522cbcf2..c7f4e3063 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -749,22 +749,13 @@ BEGIN
schema,tbl,col;
END IF;
- -- Clean up the topology schema
+ -- Cleanup the relation table (if it exists)
BEGIN
- -- Cleanup the relation table
sql := format(
'DELETE FROM %I.relation WHERE layer_id = $1',
lyrinfo.toponame
EXECUTE sql USING lyrinfo.layer_id;
- -- Drop the sequence for topogeoms in this layer
- sql := format(
- 'DROP SEQUENCE %I.topogeo_s_%s',
- lyrinfo.toponame,
- lyrinfo.layer_id
- EXECUTE sql;
EXCEPTION
WHEN UNDEFINED_TABLE THEN
RAISE NOTICE '%', SQLERRM;
@@ -772,6 +763,14 @@ BEGIN
RAISE EXCEPTION 'Got % (%)', SQLERRM, SQLSTATE;
END;
+ -- Drop the sequence for topogeoms in this layer
+ sql := format(
+ 'DROP SEQUENCE IF EXISTS %I.topogeo_s_%s',
+ lyrinfo.toponame,
+ lyrinfo.layer_id
+ EXECUTE sql;
ok = false;
FOR rec IN SELECT * FROM pg_namespace n, pg_class c, pg_attribute a
WHERE text(n.nspname) = schema
Summary of changes:
NEWS | 2 ++
topology/test/regress/droptopogeometrycolumn.sql | 28 ++++++++++++++++------
.../test/regress/droptopogeometrycolumn_expected | 6 ++---
topology/topology.sql.in | 19 +++++++--------
4 files changed, 34 insertions(+), 21 deletions(-)
hooks/post-receive
