[PostGIS] #5817: CG_3DIntersection gives wrong result with LINESTRING and Solid
PostGIS trac at osgeo.org
Thu Dec 5 18:36:51 PST 2024
 Reporter:  nbvfgh    |      Owner:  lbartoletti
     Type:  defect    |     Status:  new
 Priority:  critical  |  Milestone:  PostGIS 3.5.1
Component:  sfcgal    |    Version:  3.5.x
 Keywords:            |
 SELECT ST_IsClosed('POLYHEDRALSURFACE Z (
 ((-1 1 -1,1 1 -1,1 -1 -1,-1 -1 -1,-1 1 -1)),
 ((-1 1 1,-1 -1 1,1 -1 1,1 1 1,-1 1 1)),
 ((-1 1 -1,-1 1 1,1 1 1,1 1 -1,-1 1 -1)),
 ((1 1 -1,1 1 1,1 -1 1,1 -1 -1,1 1 -1)),
 ((1 -1 -1,1 -1 1,-1 -1 1,-1 -1 -1,1 -1 -1)),
 ((-1 -1 -1,-1 -1 1,-1 1 1,-1 1 -1,-1 -1 -1)))');
 -- result:{true}
 Then we make the closed POLYHEDRALSURFACE a Solid, and use
 CG_3DIntersection to get the Interaction with the Solid and Linestring,
 which we get the unexpected result.
 WITH solid AS (
     SELECT
         CG_MakeSolid('POLYHEDRALSURFACE Z (
      geom
 SELECT
         ST_AsText(CG_3DIntersection(
         'LINESTRING (-2 0 0, 2 0 2)'::geometry,
         solid.geom
         'LINESTRING (-2 0 0,0 0 1,2 0 2)'::geometry,
         solid.geom
 FROM solid;
 -- expected: {{LINESTRING Z (-1 0 0.5,0 0 1)},{LINESTRING Z (-1 0 0.5,0 0
 1)}}
 -- actual  : {{POINT Z (-1 0 0.5)},{LINESTRING Z (-1 0 0.5,0 0 1)}}
 To verify that the issue is not caused by differences in the two
 Linestrings, we ran the following query:
 SELECT
         'LINESTRING (-2 0 0,2 0 2)'::geometry,
         'POLYHEDRALSURFACE Z (((-1 1 -1,1 1 -1,1 -1 -1,-1 -1 -1,-1 1
 -1)),((-1 1 1,-1 -1 1,1 -1 1,1 1 1,-1 1 1)),((-1 1 -1,-1 1 1,1 1 1,1 1
 -1,-1 1 -1)),((1 1 -1,1 1 1,1 -1 1,1 -1 -1,1 1 -1)),((1 -1 -1,1 -1 1,-1 -1
 1,-1 -1 -1,1 -1 -1)),((-1 -1 -1,-1 -1 1,-1 1 1,-1 1 -1,-1 -1 -1)))'
 -- expected: {{MULTIPOINT Z ((-1 0 0.5),(0 0 1))},{MULTIPOINT Z ((-1 0
 0.5),(0 0 1))}
 -- actual  : {{MULTIPOINT Z ((-1 0 0.5),(0 0 1))},{MULTIPOINT Z ((-1 0
 0.5),(0 0 1))}
 The intersection between the original POLYHEDRALSURFACE and these two
 linestrings yielded the same result, so there should be some bugs in the
 operation of the intersection between Solid and Linestring.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5817>
