[SCM] PostGIS branch master updated. 3.5.0-108-g317bca412
Sun Dec 8 05:37:05 PST 2024
the project "PostGIS".
       via  317bca4125c5f14468fc6fd4391ec96460818590 (commit)
      from  f0861be9a9f37354098d0fd5ca71d17d93aee161 (commit)
revisions in full, below.
commit 317bca4125c5f14468fc6fd4391ec96460818590
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Dec 8 08:36:59 2024 -0500
    Get rid of some obsolete tiger files
diff --git a/extras/tiger_geocoder/create_geocode.bat b/extras/tiger_geocoder/create_geocode.bat
deleted file mode 100755
index 46c738318..000000000
--- a/extras/tiger_geocoder/create_geocode.bat
+++ /dev/null
@@ -1,19 +0,0 @@
-set PGPORT=5432
-set PGHOST=localhost
-set PGUSER=postgres
-set PGPASSWORD=yourpasswordhere
-set THEDB=geocoder
-set PGBIN=C:\Program Files\PostgreSQL\12\bin
-set PGCONTRIB=C:\Program Files\PostgreSQL\12\share\contrib
-REM "%PGBIN%\psql" -d "%THEDB%" -f "%PGCONTRIB%\fuzzystrmatch.sql"
-REM If you are using PostgreSQL 9.1 or above, use the extension syntax instead as shown below
-"%PGBIN%\psql"  -d "%THEDB%" -c "CREATE EXTENSION fuzzystrmatch;"
-"%PGBIN%\psql"  -d "%THEDB%" -c "CREATE SCHEMA tiger;"
-REM unremark this next line and edit if you want the search paths set as part of the install
-REM "%PGBIN%\psql" -d "%THEDB%" -c "ALTER DATABASE %THEDB% SET search_path=public, tiger;"
-"%PGBIN%\psql"  -d "%THEDB%" -f "create_geocode.sql"
-REM "%PGBIN%\psql"  -d "%THEDB%" -f "tables\lookup_tables_2011.sql"
-"%PGBIN%\psql"  -d "%THEDB%" -c "CREATE SCHEMA tiger_data;"
-"%PGBIN%\psql"  -d "%THEDB%" -f "tiger_loader_2019.sql;"
-pause
diff --git a/extras/tiger_geocoder/create_geocode.sh b/extras/tiger_geocoder/create_geocode.sh
index cdd73c01f..000000000
--- a/extras/tiger_geocoder/create_geocode.sh
+++ /dev/null
@@ -1,18 +0,0 @@
-#!/usr/bin/env bash
-PGPORT=5432
-PGHOST=localhost
-PGUSER=postgres
-PGPASSWORD=yourpasswordhere
-THEDB=geocoder
-PSQL_CMD= /usr/lib/postgresql/12/bin/psql
-PGCONTRIB=/usr/share/postgresql/12/contrib
-#if you are on 9.1+ use the CREATE EXTENSION syntax instead
-${PSQL_CMD} -d "${THEDB}" -f "${PGCONTRIB}/fuzzystrmatch.sql"
-#${PSQL_CMD} -d "${THEDB}" -c "CREATE EXTENSION fuzzystrmatch"
-${PSQL_CMD} -d "${THEDB}" -c "CREATE SCHEMA tiger"
-#unremark this next line and edit if you want the search paths set as part of the install
-#${PSQL_CMD} -d "${THEDB}" -c "ALTER DATABASE ${THEDB} SET search_path=public, tiger;"
-#${PSQL_CMD} -d "${THEDB}" -f "tables/lookup_tables_2011.sql"
-${PSQL_CMD} -d "${THEDB}" -c "CREATE SCHEMA tiger_data"
-${PSQL_CMD} -d "${THEDB}" -f "create_geocode.sql"
-${PSQL_CMD} -d "${THEDB}" -f "tiger_loader_2019.sql"
diff --git a/extras/tiger_geocoder/upgrade_geocoder.bat b/extras/tiger_geocoder/upgrade_geocoder.bat
index 30d090c19..000000000
--- a/extras/tiger_geocoder/upgrade_geocoder.bat
+++ /dev/null
@@ -1,18 +0,0 @@
-set PGPORT=5432
-set THEDB=geocoder
-set PGBIN=C:\Program Files\PostgreSQL\10\bin
-set PGCONTRIB=C:\Program Files\PostgreSQL\10\share\contrib
-"%PGBIN%\psql"  -d "%THEDB%" -f "upgrade_geocode.sql"
-REM "%PGBIN%\psql" -d "%THEDB%" -c "ALTER EXTENSION postgis_tiger_geocoder UPDATE;"
-REM unremark the loader line to update your loader scripts
-REM note this wipes out your custom settings in loader_* tables
-REM "%PGBIN%\psql"  -d "%THEDB%" -f "tiger_loader_2019.sql"
-cd regress
-REM "%PGBIN%\psql"  -d "%THEDB%" -t -f regress.sql
-pause
diff --git a/extras/tiger_geocoder/upgrade_geocoder.sh b/extras/tiger_geocoder/upgrade_geocoder.sh
index 6cee9eb98..000000000
--- a/extras/tiger_geocoder/upgrade_geocoder.sh
+++ /dev/null
@@ -1,13 +0,0 @@
-export PGPORT=5432
-export PGHOST=localhost
-export PGUSER=postgres
-export PGPASSWORD=yourpasswordhere
-THEDB=geocoder
-PSQL_CMD=/usr/bin/psql
-PGCONTRIB=/usr/share/postgresql/contrib
-${PSQL_CMD} -d "${THEDB}" -f "upgrade_geocode.sql"
-#unremark the loader line to update your loader scripts
-#note this wipes out your custom settings in loader_* tables
-#${PSQL_CMD} -d "${THEDB}" -f "tiger_loader_2019.sql"
Summary of changes:
 extras/tiger_geocoder/create_geocode.bat   | 19 -------------------
 extras/tiger_geocoder/create_geocode.sh    | 18 ------------------
 extras/tiger_geocoder/upgrade_geocoder.bat | 18 ------------------
 extras/tiger_geocoder/upgrade_geocoder.sh  | 13 -------------
 4 files changed, 68 deletions(-)
 delete mode 100755 extras/tiger_geocoder/create_geocode.bat
 delete mode 100755 extras/tiger_geocoder/create_geocode.sh
 delete mode 100755 extras/tiger_geocoder/upgrade_geocoder.bat
 delete mode 100755 extras/tiger_geocoder/upgrade_geocoder.sh
hooks/post-receive
