[PostGIS] #5816: Failed Z-axis tolerance in ST_RemoveRepeatedPoints
trac at osgeo.org
Tue Dec 10 05:51:41 PST 2024
Reporter: nbvfgh | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.1
Component: postgis | Version: 3.5.x
Resolution: | Keywords:
Comment (by nbvfgh):
The use of 3D distance measurement mode is a great idea, and I suggest
supporting it with new functions, just like other functions that handle 2D
and 3D under the same semantics.
Meanwhile, I suggest checking if there are any other spatial functions
that have similar issues.
Could this be a logical error caused by unclear documentation for users?
Replying to [comment:1 mdavis]:
> "Supports 3D" has a somewhat broad meaning. In this case it means that Z
values are preserved. However, the function uses a 2D distance metric to
determine points to remove. This should be made clear in the
documentation.
> A mode that uses a 3D distance metric seems like a nice addition. It
could be invoked via a flag to this function, or perhaps via a new
function `ST_RemoveRepeatedPointsZ`?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5816#comment:3>
