[PostGIS] #5820: woodie failing on pg 15 check
PostGIS trac at osgeo.org
Wed Dec 11 17:26:39 PST 2024
 Reporter:  robe          |      Owner:  robe
     Type:  defect        |     Status:  new
 Priority:  blocker       |  Milestone:  PostGIS 3.6.0
Component:  QA/buildbots  |    Version:  master
 Keywords:                |
 Just noticed woodie is failing on master branch
 https://woodie.osgeo.org/repos/30/pipeline/2718/10
 psql:/tmp/pgis_reg/loader.out:6: NOTICE:  Adding maximum extent constraint
 psql:/tmp/pgis_reg/loader.out:6: ERROR:  could not load library
 "/woodpecker/src/git.osgeo.org/gitea/postgis/postgis/build/pg15/regress/00
 -regress-install/lib/postgis-3.6.so":
 -regress-install/lib/postgis-3.6.so: cannot open shared object file:
 Permission denied
 CONTEXT:  SQL statement "SELECT st_ashexewkb( st_setsrid( st_extent(
 st_envelope(rast)), 0)) FROM public.loadedrast"
 PL/pgSQL function _add_raster_constraint_extent(name,name,name) line 33 at
 EXECUTE
 PL/pgSQL function addrasterconstraints(name,name,name,text[]) line 104 at
 assignment
 PL/pgSQL function
 addrasterconstraints(name,name,name,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean,boolean)
 line 53 at RETURN
 not sure what would cause a permissioning issue
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5820>
