[SCM] PostGIS branch stable-3.1 updated. 3.1.11-12-ge6485c56a
Fri Dec 13 13:26:34 PST 2024
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  e6485c56aacc7ca61c28392c2652ba2fb46431cb (commit)
      from  57fb5d3124fab2b624a1ee21c980d9beed0c7b95 (commit)
revisions in full, below.
commit e6485c56aacc7ca61c28392c2652ba2fb46431cb
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Dec 13 13:21:13 2024 -0800
    Handle null returns from wkb parser
diff --git a/postgis/geography_inout.c b/postgis/geography_inout.c
index a2ff6a280..ad809d9bd 100644
--- a/postgis/geography_inout.c
+++ b/postgis/geography_inout.c
@@ -563,6 +563,11 @@ Datum geography_recv(PG_FUNCTION_ARGS)
 	lwgeom = lwgeom_from_wkb((uint8_t*)buf->data, buf->len, LW_PARSER_CHECK_ALL);
+	if ( !lwgeom )
+		ereport(ERROR,(errmsg("recv error - invalid geometry")));
+		PG_RETURN_NULL();
 	/* Error on any SRID != default */
 	srid_check_latlong(lwgeom->srid);
diff --git a/postgis/lwgeom_inout.c b/postgis/lwgeom_inout.c
index 55f335893..f9b552749 100644
--- a/postgis/lwgeom_inout.c
+++ b/postgis/lwgeom_inout.c
@@ -133,6 +133,8 @@ Datum LWGEOM_in(PG_FUNCTION_ARGS)
 		unsigned char *wkb = bytes_from_hexbytes(str, hexsize);
 		/* TODO: 20101206: No parser checks! This is inline with current 1.5 behavior, but needs discussion */
 		lwgeom = lwgeom_from_wkb(wkb, hexsize/2, LW_PARSER_CHECK_NONE);
+		/* Parser should throw error, but if not, catch here. */
+		if ( !lwgeom ) PG_RETURN_NULL();
 		/* If we picked up an SRID at the head of the WKB set it manually */
 		if ( srid ) lwgeom_set_srid(lwgeom, srid);
 		/* Add a bbox if necessary */
@@ -698,6 +700,11 @@ Datum LWGEOM_recv(PG_FUNCTION_ARGS)
+	if ( !lwgeom )
+		PG_RETURN_NULL();
 	if ( lwgeom_needs_bbox(lwgeom) )
 		lwgeom_add_bbox(lwgeom);
diff --git a/raster/rt_core/rt_geometry.c b/raster/rt_core/rt_geometry.c
index 8af91586c..514bcb949 100644
--- a/raster/rt_core/rt_geometry.c
+++ b/raster/rt_core/rt_geometry.c
@@ -1202,6 +1202,7 @@ rt_raster_gdal_polygonize(
 		/* convert WKB to LWGEOM */
 		lwgeom = lwgeom_from_wkb(wkb, wkbsize, LW_PARSER_CHECK_NONE);
+		if (!lwgeom) rterror("%s: invalid wkb", __func__);
 #if POSTGIS_DEBUG_LEVEL > 3
Summary of changes:
 postgis/geography_inout.c    | 5 +++++
 postgis/lwgeom_inout.c       | 7 +++++++
 raster/rt_core/rt_geometry.c | 1 +
 3 files changed, 13 insertions(+)
hooks/post-receive
