[PostGIS] #5821: PG18 crashing on master branch (3.6) on tickets regress
PostGIS trac at osgeo.org
Sat Dec 14 15:18:38 PST 2024
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.6.0
Component:  postgis  |    Version:  master
 Keywords:           |
 I was seeing reds on Debbie and Github, but woodie is fine.
 On further inspection these appear to only be in PG18.
 debbie
 https://debbie.postgis.net/job/PostGIS_Regress/32179/consoleFull
 16:25:03 psql:tickets.sql:1019: NOTICE:  Hole lies outside shell at or
 near point 25495368.044100001 6671726.9312000005
 16:25:03 #3719a|f
 16:25:03 #3719b|t
 16:25:03 #3774|t
 16:25:03 #1014a|POINT(0 0)
 16:25:03 #1014b|POINT(0 1)
 16:25:03 psql:tickets.sql:1047: server closed the connection unexpectedly
 16:25:03        This probably means the server terminated abnormally
 16:25:03        before or while processing the request.
 16:25:03 psql:tickets.sql:1047: error: connection to server was lost
 16:25:03 ------------------------------------------------------------
 github
 https://github.com/postgis/postgis/actions/runs/12323216874/job/34398402435
  psql:tickets.sql:1019: NOTICE:  Hole lies outside shell at or near point
 #3719a|f
 #3719b|t
 #3774|t
 #1014a|POINT(0 0)
 #1014a|POINT(0 0)
 #1014b|POINT(0 1)
 So they are failing on same place in 1047 which has this query
 SELECT '#1014c', id, st_astext(g) FROM path;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5821>
