[SCM] PostGIS branch master updated. 3.5.0-137-gda91b1bf6
Mon Dec 16 06:47:45 PST 2024
the project "PostGIS".
       via  da91b1bf6768d1996aac4e26821ed520035b6bf3 (commit)
       via  d30adb5bbfd79e1e188dd59e11190122e76b41fb (commit)
      from  4b35c9e71da3056fe019c30117a958ee101b960a (commit)
revisions in full, below.
commit da91b1bf6768d1996aac4e26821ed520035b6bf3
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Mon Dec 16 14:47:10 2024 +0000
    Translated PostGIS Manual using Weblate (German)
    Currently translated at 50.4% (2905 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index 0dec4b1ad..23f032f06 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
 "PO-Revision-Date: 2024-12-16 14:47+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/de/>\n"
 "Language: de\n"
@@ -19267,7 +19267,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "Set for all new connections to a specific database"
-msgstr ""
+msgstr "Für alle neuen Verbindungen zu einer bestimmten Datenbank festgelegt"
 #. Tag: para
 #, no-c-format
commit d30adb5bbfd79e1e188dd59e11190122e76b41fb
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date:   Mon Dec 16 14:18:20 2024 +0000
index 48a2d2ece..0dec4b1ad 100644
@@ -9,8 +9,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-12-16 14:16+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-12-16 14:47+0000\n"
+"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
 "Language: de\n"
@@ -18314,8 +18314,8 @@ msgstr "ein MULTILINESTRING LEER."
 msgid ""
 "Example: ST_RemoveSmallParts() applied to a multi-polygon. Blue parts remain."
 msgstr ""
-"Beispiel: ST_RemoveSmallParts() angewandt auf ein Multi-Polygon. Blaue Teile "
-"bleiben erhalten."
+"Beispiel: ST_RemoveSmallParts() angewendet auf ein Multi-Polygon. Blaue "
+"Teile bleiben erhalten."
 #. Tag: refpurpose
 #, no-c-format
@@ -18944,6 +18944,10 @@ msgid ""
 "href=\"https://www.postgresql.org/docs/current/sql-altersystem.html\">SQL "
 "ALTER SYSTEM</link>"
 msgstr ""
+"Weitere Anwendungsbeispiele finden Sie unter <link xlink:href=\"https://www."
+"postgresql.org/docs/current/sql-set.html\">SQL SET</link> und <link "
+"xlink:href=\"https://www.postgresql.org/docs/current/sql-altersystem.html\""
+">SQL ALTER SYSTEM</link>"
 #. Tag: refpurpose
 #, no-c-format
@@ -19168,11 +19172,15 @@ msgid ""
 "To set and reset <varname>postgis.gdal_enabled_drivers</varname> for current "
 "session"
 msgstr ""
+"Um <varname>postgis.gdal_enabled_drivers</varname> für die aktuelle Sitzung "
+"zu setzen oder zurückzusetzen"
 #. Tag: para
 #, no-c-format
 msgid "Set for all new connections to a specific database to specific drivers"
 msgstr ""
+"Setzt bestimmte Treiber für alle neuen Verbindungen zu einer bestimmten "
+"Datenbank"
 #. Tag: para
 #, no-c-format
@@ -19181,6 +19189,9 @@ msgid ""
 "user access. Also note that database, session, and user settings override "
 "this."
 msgstr ""
+"Aktiviert alle Treiber für den gesamten Datenbank-Cluster. Erfordert "
+"Superuser-Zugriff. Beachten Sie auch, dass Datenbank-, Sitzungs- und "
+"Benutzereinstellungen dies überschreiben."
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/de/postgis-manual.po | 19 +++++++++++++++----
 1 file changed, 15 insertions(+), 4 deletions(-)
hooks/post-receive
