[SCM] PostGIS branch master updated. 3.5.0-154-g85a8b418f
git at osgeo.org
git at osgeo.org
Mon Dec 16 08:28:42 PST 2024
the project "PostGIS".
via 85a8b418ff94b03d6fe38673a2b26abce826d9e0 (commit)
via e3411ab19d82adb2dd9d40e775f9c1556e9d121a (commit)
from d2e9a6b4a93ee466a3f559f42f4ab7394c780492 (commit)
revisions in full, below.
commit 85a8b418ff94b03d6fe38673a2b26abce826d9e0
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Mon Dec 16 16:27:20 2024 +0000
Translated PostGIS Manual using Weblate (German)
Currently translated at 50.6% (2918 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index edb283a6d..b5bcb1d59 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
"PO-Revision-Date: 2024-12-16 16:28+0000\n"
-"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/de/>\n"
"Language: de\n"
@@ -15768,6 +15768,9 @@ msgid ""
"<xref linkend=\"ST_GeomFromText\"/> and <xref linkend=\"ST_PointFromText\"/"
">. It is also easier to use for numeric coordinate values."
msgstr ""
+"<varname>ST_MakePoint</varname> ist zwar nicht OGC-konform, aber schneller "
+"als <xref linkend=\"ST_GeomFromText\"/> und <xref linkend=\"ST_PointFromText"
+"\"/>. Es ist auch einfacher für numerische Koordinatenwerte zu verwenden."
#. Tag: para
#, fuzzy, no-c-format
commit e3411ab19d82adb2dd9d40e775f9c1556e9d121a
Author: Andreas Schild <andreas.schild at bfw.gv.at>
Date: Mon Dec 16 16:26:29 2024 +0000
index 1ba771598..edb283a6d 100644
@@ -9,8 +9,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-12-16 16:26+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-12-16 16:28+0000\n"
+"Last-Translator: Andreas Schild <andreas.schild at bfw.gv.at>\n"
"Language: de\n"
@@ -14540,13 +14540,13 @@ msgid ""
"afterwards remove the first and last double-quote character. For geometry "
"column pass as is.\""
msgstr ""
-"Das Escaping von Namen für Tabellen und/oder Namespaces, die Sonderzeichen "
-"und Anführungszeichen enthalten, kann eine besondere Behandlung erfordern. "
-"Ein Benutzer merkt an: \"Für Schemas und Tabellen verwenden Sie die Regeln "
-"für das Escaping von Bezeichnern, um eine Zeichenkette mit doppelten "
-"Anführungszeichen zu erzeugen, und entfernen Sie anschließend das erste und "
-"letzte doppelte Anführungszeichen. Für Geometriespalten so weitergeben, wie "
-"sie sind.\""
+"Namen für Tabellen und/oder Namensräume, die Sonderzeichen und "
+"Anführungszeichen enthalten, erfordern möglicherweise eine besondere "
+"Behandlung. Anmerkung eines Benutzers: \"Für die Bezeichnung von Schemata "
+"und Tabellen sollten Sie Escape-Regeln verwenden, um einen doppelt in "
+"Anführungszeichen gesetzten String zu erzeugen, und anschließend das erste "
+"und letzte Anführungszeichen entfernen. Für Geometriespalten können Sie den "
+"Namen unverändert angeben.\""
#. Tag: para
Summary of changes:
doc/po/de/postgis-manual.po | 19 +++++++++++--------
1 file changed, 11 insertions(+), 8 deletions(-)
hooks/post-receive
