[PostGIS] #5822: Incorrect Output for ST_ASEWKT with "LINESTRING Z"
trac at osgeo.org
Fri Dec 20 12:24:28 PST 2024
Reporter: bitner | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.0
Component: postgis | Version: 3.1.x
Resolution: | Keywords: WKT
Changes (by robe):
* milestone: PostGIS 3.5.1 => PostGIS 3.6.0
* version: 3.4.x => 3.1.x
Comment:
This looks to be an issue that has existed for a while. Even testing on
PostGIS 3.1, I see it returning
SELECT ST_AsEWKT(ST_GeomFromText('LINESTRING Z(-71.160281 42.258729
1.0,-71.160837 42.259113 2.0,-71.161144 42.25932 3.0)'));
LINESTRING(-71.160281 42.258729 1,-71.160837 42.259113 2,-71.161144
42.25932 3)
So if we change this behavior, we can't do it until 3.6.0 (can't go into
micros).
I'm not sure it's worth fixing cause I think OGC concerned apps would be
using ST_ASText and ST_AsEWKT has always been our own home grown WKT to
serve our purposes. I'm more concerned about breaking existing apps that
rely on this old behavior than doing the "Right thing" here.
@pramsey @strk you have any thoughts on this.
At anyrate I think we should all agree this can't go in as a micro change.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5822#comment:1>
