[PostGIS] #5710: GA and LA TIGER TABBLOCK20 files fail to load for years 2020 through 2023
PostGIS trac at osgeo.org
Fri Dec 20 12:39:19 PST 2024
  Reporter:  weyhing         |      Owner:  robe
      Type:  defect          |     Status:  closed
  Priority:  medium          |  Milestone:  PostGIS 3.4.4
 Component:  tiger geocoder  |    Version:  3.3.x
Resolution:  wontfix         |   Keywords:  TIGER,TABBLOCK20
Changes (by robe):
 * resolution:   => wontfix
 * status:  new => closed
Comment:
 Since it's only two states, sounds like an issue with tiger data
 distributed which they might have fixed already.
 Also I never promise that a 2023 load script will work for prior versions,
 or maybe you are using the right year load script for those.
 That said I don't think this issue is worth fixing unless it is an issue
 in 2024 data as well.
 I'll make sure to test the 2024 for louisiana and Georgia before I close
 out #5810
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5710#comment:3>
