[PostGIS] #5735: ST_TRANSFORM uses Helmert transformation instead of NTV2 grid (SRID's : 3812 <->31370)
trac at osgeo.org
Sat Dec 21 21:51:08 PST 2024
3812 <->31370)
Reporter: martinvdb | Owner: rouault
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.4.4
Component: postgis | Version: 3.4.x
Resolution: worksforme | Keywords: ST_TRANSFORM Belgium NTV2
Changes (by robe):
* resolution: => worksforme
* status: new => closed
Comment:
@martinvdb,
Can you send over your
SELECT version(), postgis_full_version();
I tested:
SELECT
ST_AsText(ST_Transform(ST_SetSRID(ST_MakePoint(156681.404,238403.825),
31370), 3812));
on:
PostgreSQL 17.2 (Ubuntu 17.2-1.pgdg24.04+1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, 64-bit
POSTGIS="3.5.0 d2c3ca4" [EXTENSION] PGSQL="170" GEOS="3.12.1-CAPI-1.18.1"
PROJ="9.4.0 NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/tmp/proj DATABASE_PATH=/usr/share/proj/proj.db"
(compiled against PROJ 9.12.1) LIBXML="2.9.14" LIBJSON="0.17"
LIBPROTOBUF="1.4.1" WAGYU="0.5.0 (Internal)"
I get the below which is slightly different from your PostGIS answer,
though close
POINT(656672.8903371155 738404.4813479035)
When I test on my windows system (both 16 and 17 3.5.0), I get the same
answer as yours:
SELECT
31370), 3812));
POINT(656672.8903371155 738404.4813479027)
PostgreSQL 16.0, compiled by Visual C++ build 1935, 64-bit POSTGIS="3.5.0
3.5.0" [EXTENSION] PGSQL="160" GEOS="3.13.0-CAPI-1.19.0" PROJ="8.2.1
NETWORK_ENABLED=OFF URL_ENDPOINT=https://cdn.proj.org USER_WRI
TABLE_DIRECTORY=C:\Users\Administrator\AppData\Local/proj
DATABASE_PATH=C:\Program
Files\PostgreSQL\16\share\contrib\postgis-3.5\proj\proj.db" (compiled
against PROJ 8.13.0) GDAL="GDAL 3.9.2, released 2024/
08/13" LIBXML="2.12.5" LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0
(Internal)" TOPOLOGY RASTER
(1 row)
Also tested with PG17 windows
However when I unremark out the {{{ network = on }}} line in my C:\Program
Files\PostgreSQL\16\share\contrib\postgis-3.5\proj\proj.ini
Then do a new PG session connection and run the above query, I get a
different answer of below which is close to the cs2cs answer you received.
POINT(656673.0670463315 738404.5954985798)
When you are testing with cs2cs you are perhaps using the one shipped with
QGIS which is probably a different version and has more grid files?
I'm thinking issue is just missing grid files given I get answer similar
to cs2cs when I enable network support.
I know for example on windows I don't download the full set of grid files
as they take up too much space and network enabled is also turned off on
my windows distribution. If you are on windows, all you need to do is look
in the folder shown in your postgis_full_version() output (new for 3.5.0
sorry so for older you'll need to guess a bit if you have more than one
postgresql install.
This rule of turning on network support should work on any system unless
they compiled proj without curl support. I think most distros compile it
with curl support though.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5735#comment:5>
