[PostGIS] #5682: Bug in geometry_columns view
trac at osgeo.org
Sat Dec 21 23:28:08 PST 2024
Reporter: jonochang | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.12
Component: postgis | Version: 3.4.x
Resolution: | Keywords:
Comment (by robe):
Okay I tested this against 3.4.4dev and 3.5.1dev and I can't replicate the
issue, so I think this issue mighh be fixed already.
Output in both cases is:
f_table_catalog | f_table_schema | f_table_name | f_geometry_column |
coord_dimension | srid | type
test_postgis | public | items | location |
2 | 0 | GEOMETRY
(1 row)
I'm guessing we fixed this when we had to redo geometry_columns because of
the drop of a column, I forget which PostgreSQL version.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5682#comment:3>
