[SCM] PostGIS branch stable-3.4 updated. 3.4.3-20-gbc6ad291f
Sat Dec 21 23:57:20 PST 2024
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  bc6ad291f15f0e07fc9207570f1b7bd82455109a (commit)
       via  e11d2f67031668e213355e679c6e0317305582ee (commit)
      from  491faa9c8038ff22b3e050cf979fdd2ba8ab03af (commit)
revisions in full, below.
commit bc6ad291f15f0e07fc9207570f1b7bd82455109a
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Dec 22 02:57:12 2024 -0500
    Prep for PostGIS 3.4.4 release
diff --git a/NEWS b/NEWS
index 534bc7fcc..610b702b6 100644
--- a/NEWS
+++ b/NEWS
@@ -1,15 +1,15 @@
-PostGIS 3.4.4dev
-2024/xx/xx
+PostGIS 3.4.4
+2024/12/22
 * Bug Fixes *
-  - Quote-protect output paths of pgtopo_export (Sandro Santilli)
+  - [topology] Quote-protect output paths of pgtopo_export (Sandro Santilli)
   - #5785, [raster] ST_MapAlgebra segfaults when expression references
            a supernumerary rast argument (Dian M Fay)
-  - #5787, Check that ST_ChangeEdgeGeom doesn't change winding of rings
+  - #5787, [topology] Check that ST_ChangeEdgeGeom doesn't change winding of rings
            (Sandro Santilli)
-  - #5795, Fix ST_NewEdgesSplit can cause invalid topology
-          (Björn Harrtell
+  - #5795, [topology] Fix ST_NewEdgesSplit can cause invalid topology
+          (Björn Harrtell)
   - #5677, Retain SRID during unary union (Paul Ramsey)
   - #5790, Non-schema qualified calls causing issue with
            materialized views (Regina Obe)
diff --git a/Version.config b/Version.config
index f58fcb616..a3b7092ea 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=4
-POSTGIS_MICRO_VERSION=4dev
+POSTGIS_MICRO_VERSION=4
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index c21d184bf..f4a735581 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,33 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+        <sect1>
+            <title>PostGIS 3.4.3</title>
+            <para>2024/09/04</para>
+            <simplesect>
+                <title>Bug Fixes</title>
+                <para>Quote-protect output paths of pgtopo_export (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5785">5785</ulink>, [raster] ST_MapAlgebra segfaults when expression references
+                        a supernumerary rast argument (Dian M Fay)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5787">5787</ulink>, [topology] Check that ST_ChangeEdgeGeom doesn't change winding of rings
+                        (Sandro Santilli)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5795">5795</ulink>, [topology] Fix ST_NewEdgesSplit can cause invalid topology
+                        (Björn Harrtell)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5677">5677</ulink>, Retain SRID during unary union (Paul Ramsey)</para>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5790">5790</ulink>, Non-schema qualified calls causing issue with
+                        materialized views (Regina Obe)</para>
+            </simplesect>
+            <simplesect>
+                <title>Enhancements</title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5782">5782</ulink>, Improve robustness of min distance calculation (Sandro Santilli)</para>
+            </simplesect>
+            <simplesect>
+                <title>Breaking Changes </title>
+                <para><ulink url="https://trac.osgeo.org/postgis/ticket/5799">5799</ulink>, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)</para>
+            </simplesect>
+        </sect1>
         <sect1>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 97ff407a1..4c60f79a2 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -83,6 +83,7 @@ UPGRADEABLE_VERSIONS = \
 	3.1.9 \
 	3.1.10 \
 	3.1.11 \
+	3.1.12 \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
@@ -90,7 +91,8 @@ UPGRADEABLE_VERSIONS = \
 	3.2.4 \
 	3.2.5 \
 	3.2.6 \
-	3.2.7\
+	3.2.7 \
+	3.2.8 \
 	3.3.0 \
 	3.3.1 \
 	3.3.2 \
@@ -99,7 +101,8 @@ UPGRADEABLE_VERSIONS = \
 	3.3.5 \
 	3.3.6 \
 	3.3.7 \
+	3.3.8 \
 	3.4.0 \
 	3.4.1 \
 	3.4.2 \
-	3.4.3
+	3.4.3
commit e11d2f67031668e213355e679c6e0317305582ee
Date:   Sun Dec 22 02:32:44 2024 -0500
    Upgrade winnie dependencies
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 44fe66a86..0241c6d85 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -9,13 +9,14 @@ export PROJECTS=/projects
 # Don't convert paths
 # See https://trac.osgeo.org/postgis/ticket/5436#comment:5
 export MSYS2_ARG_CONV_EXCL=/config/tags
+export XML_CATALOG_FILES="/projects/docbook/docbook-5.0.1/catalog.xml"
 if  [[ "${OVERRIDE}" == '' ]] ; then
-	export GEOS_VER=3.12.1
-	export GDAL_VER=3.8.5
+	export GEOS_VER=3.13.0
+	export GDAL_VER=3.9.2
 	export PROJ_VER=8.2.1
-	export SFCGAL_VER=1.5.1
-	export CGAL_VER=5.6
+	export SFCGAL_VER=1.5.2
+	export CGAL_VER=5.6.1
 	export ICON_VER=1.17
 	export ZLIB_VER=1.2.13
 	export PROTOBUF_VER=3.2.0
@@ -28,7 +29,7 @@ fi;
 export PROTOBUFC_VER=1.2.1
 export JSON_VER=0.12
-export PCRE_VER=8.33
+export PCRE_VER=8.45
 #export OS_BUILD=64
@@ -52,16 +53,16 @@ fi;
 #set to something even if override is on but not set
 if  [[ "${LIBXML_VER}" == '' ]] ; then
-  export LIBXML_VER=2.9.14
+  export LIBXML_VER=2.12.5
 fi;
 if  [[ "${CGAL_VER}" == '' ]] ; then
 fi;
 ##hard code versions of cgal etc. for now
-export CGAL_VER=5.6
+export CGAL_VER=5.6.1
 BOOST_VER=1.84.0
 export BOOST_VER_WU=1_84_0
Summary of changes:
 NEWS                               | 12 ++++++------
 Version.config                     |  2 +-
 ci/winnie/winnie_common.sh         | 17 +++++++++--------
 doc/release_notes.xml              | 27 +++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk |  7 +++++--
 5 files changed, 48 insertions(+), 17 deletions(-)
hooks/post-receive
