[SCM] PostGIS branch master updated. 3.5.0-180-g04ef40af3
git at osgeo.org
git at osgeo.org
Sun Dec 22 09:51:13 PST 2024
the project "PostGIS".
via 04ef40af32ceeb671bce399b73814e8630c54a6d (commit)
via c9e5e238d44b8708f14ed1b337c9b50b2ae4ffad (commit)
from aaf6e52175fa45740cc5ca3d5b1eded4b5afdb3f (commit)
revisions in full, below.
commit 04ef40af32ceeb671bce399b73814e8630c54a6d
Author: Regina Obe <lr at pcorp.us>
Date: Sun Dec 22 12:51:08 2024 -0500
Put back codeql back to pg-14, failing on pg-16
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 6396f7408..4fdd1c507 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -54,7 +54,7 @@ jobs:
- name: Install dependencies
run: |
sudo apt-get update
- sudo apt-get install -y g++ autoconf automake libgeos-dev libproj-dev libgdal-dev libjson-c-dev gettext libxml2-dev postgresql-server-dev-16 postgresql-client-16 libprotobuf-c-dev libprotoc-dev protobuf-c-compiler
+ sudo apt-get install -y g++ autoconf automake libgeos-dev libproj-dev libgdal-dev libjson-c-dev gettext libxml2-dev postgresql-server-dev-14 postgresql-client-14 libprotobuf-c-dev libprotoc-dev protobuf-c-compiler
- name: Build
run: |
commit c9e5e238d44b8708f14ed1b337c9b50b2ae4ffad
Date: Sun Dec 22 00:59:32 2024 -0500
Fix ST_AsMVTGeom example. Closes #5758 for PostGIS 3.5.1
diff --git a/doc/reference_output.xml b/doc/reference_output.xml
index 50e7f7370..2e719d0f4 100644
--- a/doc/reference_output.xml
+++ b/doc/reference_output.xml
@@ -1395,7 +1395,7 @@ SELECT ST_AsText(ST_AsMVTGeom(
MULTIPOLYGON(((5 4096,10 4091,10 4096,5 4096)),((5 4096,0 4101,0 4096,5 4096)))
</programlisting>
- <para>Canonical example for a Web Mercator tile using a computed tile bounds to query and clip geometry.
+ <para>Canonical example for a Web Mercator tile using a computed tile bounds to query and clip geometry. This assumes the data.geom column has srid of 4326.
</para>
<programlisting><![CDATA[
@@ -1403,7 +1403,7 @@ SELECT ST_AsMVTGeom(
ST_Transform( geom, 3857 ),
ST_TileEnvelope(12, 513, 412), extent => 4096, buffer => 64) AS geom
FROM data
- WHERE geom && ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096))
+ WHERE geom && ST_Transform(ST_TileEnvelope(12, 513, 412, margin => (64.0 / 4096)),4326)
]]></programlisting>
Summary of changes:
.github/workflows/codeql.yml | 2 +-
doc/reference_output.xml | 4 ++--
2 files changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
