[PostGIS] #5824: Wrong git clone URL in installation.xml.
trac at osgeo.org
Mon Dec 23 16:08:18 PST 2024
Reporter: xinbo | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.6.0
Component: QA/testsuite | Version: master
Resolution: wontfix | Keywords:
Changes (by robe):
* resolution: => wontfix
* status: new => closed
Comment:
Not seeing why that is wrong, both
git clone https://git.osgeo.org/gitea/postgis/postgis.git postgis
and
should yield the same result. The one in the docs with the extra postgis,
explicitly creates the directory. The one you propose, creates the
default directory which is the name without .git in it.
Both should yield the same result. I prefer the explicitness of what is
in the docs, as I often do things like
git clone https://git.osgeo.org/gitea/postgis/postgis.git postgis-git
cd postgis-git
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5824#comment:4>
