[SCM] PostGIS branch master updated. 3.5.0-42-gc8c345428
git at osgeo.org
git at osgeo.org
Sat Nov 2 02:18:22 PDT 2024
the project "PostGIS".
via c8c345428bcb5f3b07d09a96e05cd8bbfcb07a28 (commit)
from e8d47bb440139d9f6c90acfd234e2fe6a668ba3d (commit)
revisions in full, below.
commit c8c345428bcb5f3b07d09a96e05cd8bbfcb07a28
Author: Sandro Santilli <strk at kbt.io>
Date: Sat Nov 2 10:16:44 2024 +0100
Revert "Check motion range upon snap/splitting edge to existing node"
This reverts commit fc88b11cdbf25999c7f1510cf7e26d40e8a9dfd3.
This reverts commit f02b6db36beb5e9e772c211dc08556377cf1a4d0.
Re-opens #5792 in master branch (3.6.0dev)
References #5786
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index e137ef336..93e98681e 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -5287,7 +5287,7 @@ _lwt_SnapEdgeToExistingNode(
for ( n=0; n<2; ++n)
int forward;
- /* TODO: directly get full existing edge rather than just id */
+ /* TODO: directly get full existing edge rather than just id * */
LWT_ELEMID existingEdgeId = _lwt_GetEqualEdge( topo, lwgeom_as_lwline(splitC->geoms[n]), &forward );
if ( existingEdgeId == -1 )
@@ -5408,74 +5408,8 @@ _lwt_SnapEdgeToExistingNode(
splitNodeNewEdgeOutgoing = 0;
- /* TODO: check that newSplitEdgeLine part does not cross any other edge ? */
+ /* TODO: check that newSplitEdgeLine part does not crosses any other edge ? */
/* TODO: check that newSplitEdgeLine retains its position in the edge end star (see ticket #5786) */
- /* TODO: check that the motion range does not contain any node */
- // build the motion range shape: splitC->geoms[0] + splitC->geoms[1] - edge->geom
- POINTARRAY *motionRange = ptarray_clone_deep(lwgeom_as_lwline(splitC->geoms[0])->points);
- ptarray_append_ptarray(motionRange, lwgeom_as_lwline(splitC->geoms[1])->points, 0);
- POINTARRAY *reverseNewLine = ptarray_clone_deep(edge->geom->points);
- ptarray_reverse_in_place(reverseNewLine);
- ptarray_append_ptarray(motionRange, reverseNewLine, 0);
- ptarray_free(reverseNewLine);
- // motionBounds takes ownership of motionRange
- LWLINE *motionBounds = lwline_construct(topo->srid, NULL, motionRange);
- // motionPoly takes ownership of motionBounds
- LWGEOM *motionPoly = (LWGEOM *)lwpoly_from_lwlines(motionBounds, 0, NULL);
- LWDEBUGG(1, motionPoly, "Motion range");
- // check the Motion range doesn't cover any of
- // the edges incident to the split node other
- // than the existing edge
- GEOSGeometry *motionPolyG = NULL;
- for ( uint64_t t=0; t<splitNodeEdges->numEdges; t++ )
- LWT_ISO_EDGE *e = &(splitNodeEdges->edges[t]);
- GEOSGeometry *eg;
- if ( e == existingEdge ) continue;
- if ( e == edge ) continue;
- if ( ! motionPolyG ) {
- motionPolyG = LWGEOM2GEOS( motionPoly, 0 );
- lwerror("Could not convert edge geometry to GEOS: %s", lwgeom_geos_errmsg);
- return -1;
- eg = LWGEOM2GEOS( lwline_as_lwgeom(e->geom), 0 );
- if ( ! eg )
- return -1;
- int covers = GEOSCovers( motionPolyG, eg );
- // TODO: use preparedCovers ?
- GEOSGeom_destroy(eg);
- if (covers == 2)
- lwerror("Covers error: %s", lwgeom_geos_errmsg);
- return -1;
- if ( covers )
- lwgeom_free(motionPoly);
- lwerror("snapping edge %" LWTFMT_ELEMID
- " to new node moves it past edge %" LWTFMT_ELEMID,
- edge->edge_id, e->edge_id
- return -1;
- if ( motionPolyG ) GEOSGeom_destroy(motionPolyG);
LWDEBUGF(1, "Existing edge %"
LWTFMT_ELEMID " (post-modEdgeSplit) next_right:%"
diff --git a/topology/test/regress/topogeo_addpoint_merge_edges.sql b/topology/test/regress/topogeo_addpoint_merge_edges.sql
index 1cc0d59bf..fc0fff28d 100644
--- a/topology/test/regress/topogeo_addpoint_merge_edges.sql
+++ b/topology/test/regress/topogeo_addpoint_merge_edges.sql
@@ -425,20 +425,4 @@ SELECT * FROM runTest('multi-merge-closest-not-containing-projected',
], 'POINT(12.472410859513998 70.77020397757477)', 0
) WHERE true ;
-SELECT * FROM runTest('#5792.0',
- ARRAY[
- 'LINESTRING(11.812075769533624 59.77938755222866,11.811862389533625 59.77938237222866)',
- 'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938496222866,11.812075769533624 59.77938755222866)'
- ], 'POINT(11.812029186127067 59.7793864213727)', 0
-) WHERE true ;
-SELECT * FROM runTest('#5792.1',
- ARRAY[
- 'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938496222866,11.812075769533624 59.77938755222866)',
- 'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938,11.812075769533624 59.77938755222866)'
-) WHERE true ;
DROP FUNCTION runTest(text, geometry[], geometry, float8, bool);
diff --git a/topology/test/regress/topogeo_addpoint_merge_edges_expected b/topology/test/regress/topogeo_addpoint_merge_edges_expected
index 994187546..90b2a3d21 100644
--- a/topology/test/regress/topogeo_addpoint_merge_edges_expected
+++ b/topology/test/regress/topogeo_addpoint_merge_edges_expected
@@ -29,5 +29,3 @@ full-merge-exterior-face|-checking-
double-merge-forward-backward|-checking-
multi-merge-forward-backward|-checking-
multi-merge-closest-not-containing-projected|-checking-
-ERROR: snapping edge 2 to new node moves it past edge 3
Summary of changes:
liblwgeom/topo/lwgeom_topo.c | 70 +---------------------
.../test/regress/topogeo_addpoint_merge_edges.sql | 16 -----
.../regress/topogeo_addpoint_merge_edges_expected | 2 -
3 files changed, 2 insertions(+), 86 deletions(-)
hooks/post-receive
