[PostGIS] #5808: Weird constant ram increase using topology
PostGIS trac at osgeo.org
Tue Nov 5 12:10:04 PST 2024
 Reporter:  latot     |      Owner:  strk
     Type:  defect    |     Status:  new
 Priority:  medium    |  Milestone:  PostGIS 3.5.1
Component:  topology  |    Version:  3.5.x
 Keywords:            |
 Hi! finally, possible memleak, but is very very weird.
 I was first using ST_ModEdgeHeal when I noticed the process was using a
 lot of ram, and it increases constantly.
 After some tests, I found this also happens when we create a topology:
 ```SQL
 select topology.DropTopology('muahahaha');
 select topology.CreateTopology('muahahaha');
 DROP TABLE IF EXISTS topoperf.case_concentric_circles;
 CREATE TABLE topoperf.case_concentric_circles AS (
   SELECT radius, ST_ExteriorRing(
     ST_Buffer('POINT(0 0)', radius, 128)
   ) g
   FROM generate_series(10, 100) radius
 DROP TABLE IF EXISTS parent;
 CREATE TABLE parent();
 SELECT topology.AddTopoGeometryColumn(
   'muahahaha',
   'public',
   'parent',
   'topo',
   'LINESTRING'
 ) As  layer_id;
 INSERT INTO parent(topo)
 SELECT topology.toTopoGeom(g, 'muahahaha', 1)
   FROM topoperf.case_concentric_circles;
 If you run the code above, will finish and everything will be Ok, until
 you see the process, "postgres: postgres postgres [local] idle", is the
 one who handle the queries.
 Here is the Ram usage of the workflow:
 Run PSQL: 2MB
 First Run: 109MB: This is not going down even after the query finished)
 Second Run: 210.6MB: From the code above, run again, the INSERT Statement,
 will be executed the same geometries, the Ram increased and even after it
 finished is up.
 The issue is that after the INSERT statements the RAM usage only
 increases, is not free after the finish, if we try to process more data it
 will eat all our Ram.
 Thx!
 My extensions seems to need some update (? still can't find how to get rid
 of that message, alter extension or the upgrade functions seems do not
 help here, but is other issue.
 SELECT PostGIS_Full_Version();
  POSTGIS="3.5.0 POSTGIS_REVISION" [EXTENSION] PGSQL="160"
 GEOS="3.12.1-CAPI-1.18.1" PROJ="9.4.1 NETWORK_ENABLED=OFF
 URL_ENDPOINT=https://cdn.proj.org
 USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
 DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 9.12.1)
 GDAL="GDAL 3.9.1, released 2024/06/22" LIBXML="2.12.7" LIBJSON="0.17"
 LIBPROTOBUF="1.5.0" WAGYU="0.5.0 (Internal)" (core procs from "3.5.0
 d2c3ca4" need upgrade) TOPOLOGY (topology procs from "3.5.0 d2c3ca4" need
 upgrade) RASTER (raster procs from "3.5.0 d2c3ca4" need upgrade)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5808>
