[PostGIS] #5808: Weird constant ram increase using topology
trac at osgeo.org
Wed Nov 6 00:05:55 PST 2024
Reporter: latot | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: 3.5.x
Resolution: | Keywords:
Comment (by strk):
Having a literal `POSTGIS_REVISION` in the output of
`postgis_full_version()` is unexpected, did you have trouble with SQLPP at
build time ?
How does postgis_config.h looks ? And `grep ^SQLPP postgis/Makefile`?
In any case is
[https://git.osgeo.org/gitea/postgis/postgis/src/tag/3.5.0/topology/postgis_topology.c#L799
currently] using
[https://github.com/postgres/postgres/blob/ba08edb065459fca62191c020362022efd42b522/src/backend/utils/mmgr/README#L185
TopMemoryContext] which is never automatically released by PostgreSQL
backend so if any code path fails to explicitly release that memory you'd
get such increasing memory usage until disconnect
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5808#comment:6>
