[SCM] PostGIS branch stable-3.5 updated. 3.5.0-22-g58d45d6ea
git at osgeo.org
git at osgeo.org
Wed Nov 6 13:01:19 PST 2024
the project "PostGIS".
The branch, stable-3.5 has been updated
via 58d45d6ead34a17cd5c500ea009e77d3e72a51dd (commit)
from 26d0eb132c404f22c99d946068d8fc12bd5c6bb9 (commit)
revisions in full, below.
commit 58d45d6ead34a17cd5c500ea009e77d3e72a51dd
Author: Sandro Santilli <strk at kbt.io>
Date: Sat Nov 2 10:19:29 2024 +0100
Check motion range upon snap/splitting edge to existing node
This time make the polygon valid before using Covers on it
Closes #5792 in 3.5 branch (3.5.1dev)
References #5786
diff --git a/NEWS b/NEWS
index 5bf942ac4..49b861726 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,8 @@ PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
* Bug fixes *
+- #5792, Prevent topology corruption with TopoGeo_addPoint near almost
+ collinear edges (Sandro Santilli)
- #5795, Fix ST_NewEdgesSplit can cause invalid topology
(Björn Harrtell)
- #5794, Fix crash in TopoGeo_addPoint (Sandro Santilli)
@@ -17,7 +19,7 @@ PostgreSQL 12-17 required. GEOS 3.8+ required. Proj 6.1+ required.
to allow pg_upgrade (Regina Obe)
- #5800, PROJ compiled version reading the wrong minor and micro
(Regina Obe)
-- #5790, Non-schema qualified calls causing issue with
+- #5790, Non-schema qualified calls causing issue with
materialized views (Regina Obe)
* Enhancements *
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 93e98681e..6cf6ccaec 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -5410,6 +5410,75 @@ _lwt_SnapEdgeToExistingNode(
/* TODO: check that newSplitEdgeLine part does not crosses any other edge ? */
/* TODO: check that newSplitEdgeLine retains its position in the edge end star (see ticket #5786) */
+ /* TODO: check that the motion range does not contain any node */
+ // build the motion range shape: splitC->geoms[0] + splitC->geoms[1] - edge->geom
+ POINTARRAY *motionRange = ptarray_clone_deep(lwgeom_as_lwline(splitC->geoms[0])->points);
+ ptarray_append_ptarray(motionRange, lwgeom_as_lwline(splitC->geoms[1])->points, 0);
+ POINTARRAY *reverseNewLine = ptarray_clone_deep(edge->geom->points);
+ ptarray_reverse_in_place(reverseNewLine);
+ ptarray_append_ptarray(motionRange, reverseNewLine, 0);
+ ptarray_free(reverseNewLine);
+ // motionBounds takes ownership of motionRange
+ LWLINE *motionBounds = lwline_construct(topo->srid, NULL, motionRange);
+ // motionPolyBare takes ownership of motionBounds
+ LWGEOM *motionPolyBare = (LWGEOM *)lwpoly_from_lwlines(motionBounds, 0, NULL);
+ LWGEOM *motionPoly = lwgeom_make_valid(motionPolyBare);
+ lwgeom_free(motionPolyBare);
+ LWDEBUGG(1, motionPoly, "Motion range");
+ // check the Motion range doesn't cover any of
+ // the edges incident to the split node other
+ // than the existing edge
+ GEOSGeometry *motionPolyG = NULL;
+ for ( uint64_t t=0; t<splitNodeEdges->numEdges; t++ )
+ LWT_ISO_EDGE *e = &(splitNodeEdges->edges[t]);
+ GEOSGeometry *eg;
+ if ( e == existingEdge ) continue;
+ if ( e == edge ) continue;
+ if ( ! motionPolyG ) {
+ motionPolyG = LWGEOM2GEOS( motionPoly, 0 );
+ lwerror("Could not convert edge geometry to GEOS: %s", lwgeom_geos_errmsg);
+ return -1;
+ eg = LWGEOM2GEOS( lwline_as_lwgeom(e->geom), 0 );
+ if ( ! eg )
+ return -1;
+ int covers = GEOSCovers( motionPolyG, eg );
+ // TODO: use preparedCovers ?
+ GEOSGeom_destroy(eg);
+ if (covers == 2)
+ lwerror("Covers error: %s", lwgeom_geos_errmsg);
+ return -1;
+ if ( covers )
+ lwgeom_free(motionPoly);
+ lwerror("snapping edge %" LWTFMT_ELEMID
+ " to new node moves it past edge %" LWTFMT_ELEMID,
+ edge->edge_id, e->edge_id
+ return -1;
+ if ( motionPolyG ) GEOSGeom_destroy(motionPolyG);
LWDEBUGF(1, "Existing edge %"
LWTFMT_ELEMID " (post-modEdgeSplit) next_right:%"
diff --git a/topology/test/regress/topogeo_addpoint_merge_edges.sql b/topology/test/regress/topogeo_addpoint_merge_edges.sql
index fc0fff28d..65f996a15 100644
--- a/topology/test/regress/topogeo_addpoint_merge_edges.sql
+++ b/topology/test/regress/topogeo_addpoint_merge_edges.sql
@@ -425,4 +425,19 @@ SELECT * FROM runTest('multi-merge-closest-not-containing-projected',
], 'POINT(12.472410859513998 70.77020397757477)', 0
) WHERE true ;
+SELECT * FROM runTest('#5792.0',
+ ARRAY[
+ 'LINESTRING(11.812075769533624 59.77938755222866,11.811862389533625 59.77938237222866)',
+ 'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938496222866,11.812075769533624 59.77938755222866)'
+ ], 'POINT(11.812029186127067 59.7793864213727)', 0
+) WHERE true ;
+SELECT * FROM runTest('#5792.1',
+ ARRAY[
+ 'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938496222866,11.812075769533624 59.77938755222866)',
+ 'LINESTRING(11.811862389533625 59.77938237222866,11.811969079533624 59.77938,11.812075769533624 59.77938755222866)'
+) WHERE true ;
DROP FUNCTION runTest(text, geometry[], geometry, float8, bool);
diff --git a/topology/test/regress/topogeo_addpoint_merge_edges_expected b/topology/test/regress/topogeo_addpoint_merge_edges_expected
index 90b2a3d21..994187546 100644
--- a/topology/test/regress/topogeo_addpoint_merge_edges_expected
+++ b/topology/test/regress/topogeo_addpoint_merge_edges_expected
@@ -29,3 +29,5 @@ full-merge-exterior-face|-checking-
double-merge-forward-backward|-checking-
multi-merge-forward-backward|-checking-
multi-merge-closest-not-containing-projected|-checking-
+ERROR: snapping edge 2 to new node moves it past edge 3
Summary of changes:
NEWS | 4 +-
liblwgeom/topo/lwgeom_topo.c | 69 ++++++++++++++++++++++
.../test/regress/topogeo_addpoint_merge_edges.sql | 15 +++++
.../regress/topogeo_addpoint_merge_edges_expected | 2 +
4 files changed, 89 insertions(+), 1 deletion(-)
hooks/post-receive
