[SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 68d9b2d99391fc22c1edcbca926cc380ec5f85b3
Thu Nov 7 08:56:58 PST 2024
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
       via  68d9b2d99391fc22c1edcbca926cc380ec5f85b3 (commit)
       via  ff5558d538cb982f28ba20aa62bb96ffa14dce59 (commit)
      from  4dcaa66928b0178a095551ca8df2e47a0b3cbd26 (commit)
revisions in full, below.
commit 68d9b2d99391fc22c1edcbca926cc380ec5f85b3
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Nov 7 11:56:54 2024 -0500
    Remove old bessie setup, now obsolete
diff --git a/freebsd/bessie_setup.txt b/freebsd/bessie_setup.txt
deleted file mode 100644
index 14901af..0000000
--- a/freebsd/bessie_setup.txt
+++ /dev/null
@@ -1,259 +0,0 @@
-Bessie currently setup on winnie's virtual box - ssh port ssh your_user_name at winnie.postgis.net -p 51022
-Built from https://download.freebsd.org/ftp/releases/VM-IMAGES/12.0-RELEASE/amd64/Latest/FreeBSD-12.0-RELEASE-amd64.vmdk.xz dated (Dec 2018)
-vi /etc/rc.conf
-add to file
-hostname="bessie"
-sshd_enable="YES"
-#then edit the sshd_config
-vi /etc/ssh/sshd_config
-Add line
-AllowGroups wheel
-and add to AllowUsers list
-vi /etc/ssh/sshd_config #:g/AllowUsers/, :g/PermitRootLogin #change to yes so can configure - can change later to no
-#Make sure jenkins is in AllowUsers list of /sshd_config
-cat /etc/ssh/sshd_config | grep AllowUsers #if jenkins not listed add
-Then run:
-service sshd restart
-#if get host keys not found run
-ssh-keygen -A
-To create and add a user robe (repeat for jenkins, pramsey, strk, komzpa, cvvergara, Algunenano) and install relevant ssh keys in homedirs
-adduser robe
-adduser Algunenano
-#when prompted make sure to add to wheel group
-#for adds after user created
-pw group mod wheel -m robe
-#Now robe can do
-su root
-(to do admin stuff)
-#upgrade to latest patches
-freebsd-update fetch
-#installing ports
-portsnap fetch
-portsnap extract
-#in future to update ports
-portsnap fetch
-portsnap update
-pkg install sudo
-#choose LDAP protocol support in addition to default selected
-Then run:
-visudo
-and uncomment line wheel nopasswd allowing wheel to use sudo without password.
-pkg install jed bash tcpdump wget git proj geos
-#had these installed, didn't work but worked with openjdk8
-pkg install openjdk11
-mount -t fdescfs fdesc /dev/fd
-mount -t procfs proc /proc
-#add following lines to /etc/fstab
-fdesc   /dev/fd         fdescfs         rw      0       0
-proc    /proc           procfs          rw      0       0
-pkg install gmake gdb subversion autoconf libtool curl automake expect
-pkg install libxslt libxml2 bison
-pkg install imagemagick #if not found try imagemagick7 (was required for FreeBSD 12)
-pkg install gdal geos proj
-pkg install sfcgal json-c
-pkg install cunit iconv
-pkg install protobuf protobuf-c  #needed for building mvt
-#was going to install postgresql in jail but got lost quickly
-#did these steps to enable jails in future
-sysctl security.jail.sysvipc_allowed=1
-#Make it persistent by adding this line to /etc/sysctl.conf
-security.jail.sysvipc_allowed=1
-#Add this line to /etc/rc.conf
-jail_sysvipc_allow="YES"
-#Enter your jail and install Postgres.
-# had to use 16 because gdal has 16 client and installing 17 removes gdal
-pkg install postgresql16-server postgresql16-contrib gdal
-service postgresql initdb #create data cluster
-edit the /etc/rc.conf
-and add a line
-postgresql_enable="YES"
-pkg update #update available list
-pkg upgrade #upgrades all packages
-pkg info proj  #get details of proj
-pkg install cmake #install needed for building pgrouting and sfcgal in future
-#for code coverage testing
-pkg install lcov
-#for pgtap tests needed for pgrouting
-git clone https://github.com/theory/pgtap.git
-cd pgtap
-gmake
-sudo gmake install
-sudo gmake installcheck PGUSER=postgres
-sudo cpan TAP::Parser::SourceHandler::pgTAP
-#installing from ports
-#installed latest proj from ports by doing https://www.freebsd.org/doc/handbook/ports-using.html
-portsnap fetch #only needs to be done once
-portsnap extract #only needs to be done once
-portsnap fetch update #to keep up to date
-cd /usr/ports/graphics/proj
-make install
-#note you might be asked remove gdal and libgeotiff go ahead
-cd /usr/ports/graphics/gdal
-make install
-#upgrade to 12.2
-#check version running
-sudo -i
-freebsd-version -k #kernel version # read 12.0-RELEASE
-freebsd-version -u #client apps userland read 12.0-RELEASE
-freebsd-update upgrade -r 12.2-RELEASE
-#after all downloaded
- /usr/sbin/freebsd-update install
- reboot
- #run again after logging back in
-/usr/sbin/freebsd-update install
-freebsd-version -k #now reads 12.2-RELEASE-p1
-freebsd-version -u #now reads 12.2-RELEASE-p1
-pkg update
-rm -rf /home/jenkin/tmp/* #had 11G of junk
-pkg upgrade #upgraded pkg: 1.13.2 -> 1.15.10
-pkg search postgresql #shows all postgresql
-pkg install postgresql11-contrib #needed to get citext
-#note said this may be needed for compiling   -Wl,-rpath=/usr/local/lib/gcc9
-cd /root
-cd pgtap
-git pull
-gmake
-sudo gmake install
-#fix date time https://www.cyberciti.biz/faq/howto-set-date-and-time-timezone-in-freebsd/
-date yymmddhhmmss
-e.g date 2106121811
-#set time without changing date
-date hhmmss
-e.g. - date 1810
-cp /usr/share/zoneinfo/US/Eastern /etc/localtime
-#see list of packages
-pkg info | grep postgresql
-#lists all installed
-pkg info –all
-pkg remove postgresql12-server postgresql12-contrib postgresql12-client gdal
-pkg install postgresql12-server postgresql12-contrib postgresql12-client gdal
-/usr/local/etc/rc.d/postgresql initdb
-#Make suretime service is running and starts on bootup otherwise looses time
-# https://forums.freebsd.org/threads/the-system-clock-is-falling-behind.61450/
-service ntpd enable
-service ntpd start
-sysrc ntpdate_enable="YES"
-# remove no longer used packages
-pkg remove subversion
-pkg autoremove
-pkg clean -a -n #will just show how much will be cleared by clearing downloads
-pkg clean -a -y #will actually purge
-#Patching to p14
-sudo -i
-freebsd-version -k #kernel version # read 12.2-RELEASE-p1
-freebsd-version -u #client apps userland read  12.2-RELEASE-p1
-rm -rf /var/db/freebsd-update/*
-freebsd-update install
-reboot
-freebsd-version -k #kernel version # read 12.2-RELEASE-p14
-freebsd-version -u #client apps userland read  12.2-RELEASE-p14
-# upgrade to 12.3
-sudo -i
-freebsd-version -u #client apps userland read 12.2-RELEASE-p15
-freebsd-update upgrade -r 12.3-RELEASE
-reboot
-freebsd-version -k #kernel version # read 12.3-RELEASE-p5
-freebsd-version -u #client apps userland read 12.3-RELEASE-p5
-reboot
-pkg update
-pkg upgrade
-# purge upgrade files
-cd /var/db/freebsd-update/files
-rm -rf [0-1]*
-rm -rf [1-3]*
-rm -rf [3-5]*
-rm -rf [5-7]*
-rm -rf [0-9]*
-rm -rf [a-b]*
-rm -rf [a-d]*
-rm -rf [a-h]*
-# build gdal from ports
-portsnap fetch extract #first time
-# there after
-export ALLOW_UNSUPPORTED_SYSTEM=yes
-cd /usr/ports/graphics/gdal/ && make install clean
-make config # to change options
\ No newline at end of file
commit ff5558d538cb982f28ba20aa62bb96ffa14dce59
Date:   Thu Nov 7 11:56:21 2024 -0500
    New bessie setup on osgeo8
diff --git a/debian/reallie.txt b/debian/reallie.txt
index 8d34c61..3f2b366 100644
--- a/debian/reallie.txt
+++ b/debian/reallie.txt
@@ -24,3 +24,5 @@ apt install pkg-config
 apt install lcov
 apt install liblz4-dev
index 371bc80..14901af 100644
+++ b/freebsd/bessie_setup.txt
@@ -5,7 +5,7 @@ vi /etc/rc.conf
 add to file
-hostname="bessie12"
+hostname="bessie"
 sshd_enable="YES"
@@ -97,8 +97,8 @@ jail_sysvipc_allow="YES"
-pkg install postgresql11-server postgresql11-contrib
+# had to use 16 because gdal has 16 client and installing 17 removes gdal
+pkg install postgresql16-server postgresql16-contrib gdal
diff --git a/freebsd/osgeo8-bessie_setup.md b/freebsd/osgeo8-bessie_setup.md
new file mode 100644
index 0000000..3017a53
--- /dev/null
+++ b/freebsd/osgeo8-bessie_setup.md
@@ -0,0 +1,165 @@
+Bessie currently setup on winnie's virtual box - ssh port ssh your_user_name at winnie.postgis.net -p 51022
+Built from wget https://download.freebsd.org/ftp/releases/VM-IMAGES/14.1-RELEASE/amd64/Latest/FreeBSD-14.1-RELEASE-amd64-zfs.qcow2.xz dated (Oct 2024)
+vi /etc/rc.conf
+add to file
+hostname="bessie"
+sshd_enable="YES"
+#then edit the sshd_config
+vi /etc/ssh/sshd_config
+Add line
+AllowGroups wheel
+and add to AllowUsers list
+vi /etc/ssh/sshd_config #:g/AllowUsers/, :g/PermitRootLogin #change to yes so can configure - can change later to no
+#Make sure jenkins is in AllowUsers list of /sshd_config
+cat /etc/ssh/sshd_config | grep AllowUsers #if jenkins not listed add
+Then run:
+service sshd restart
+#if get host keys not found run
+ssh-keygen -A
+To create and add a user robe (repeat for jenkins, pramsey, strk, komzpa, cvvergara, Algunenano) and install relevant ssh keys in homedirs
+adduser robe
+su robe
+mkdir ~/.ssh
+echo ssh-rsa AAAAB3NzaC1yc2EAAAABJQAAAQEAmf79bn/i3jeP9IuFZ0BXGTJundqVLW5gRUfnG2cPvmDtGRnvKZ/cEoxDbuvh9vyQhV/wn3Y1ACgBc+lwhJUXmjZDq2ft4iL0GfOpjyEwT+QohSyShy9lijCJ2iNdxG1ixZokXReYkyldSgjSpMzTbtaAZCx0rMk9zY/3lQM+IR3OTTv8HUmzECFwgA6fcjKnzq98Ng2fdf/1tcvz73YfVZlo92Q0pSsGFhU4ytsI7CqVF9i5JdFlUToOB+KXQpsizQ3XeDgp+kxcOGHiXHbZb3h5w7yy7J7+cwrWOrZxCEMfHITy7NQcRj3bbK2B+pPVG87/oHTzAGgDbcZYq6uzLQ== robe2048 >> ~/.ssh/authorized_keys
+adduser jenkins
+su jenkins
+mkdir ~/.ssh
+echo ssh-ed25519 AAAAC3NzaC1lZDI1NTE5AAAAIMWfil4H34fePXGfx0uR6Gd9TnHTgKKYPJLmaMsTicmx vicky at pgvicky  >> ~/.ssh/authorized_keys
+#when prompted make sure to add to wheel group
+#for adds after user created
+pw group mod wheel -m robe
+#Now robe can do
+su root
+(to do admin stuff)
+#upgrade to latest patches
+freebsd-update fetch
+#installing ports
+portsnap fetch
+portsnap extract
+#in future to update ports
+portsnap fetch
+portsnap update
+pkg install sudo
+Then run:
+visudo
+and uncomment line wheel nopasswd allowing wheel to use sudo without password.
+pkg install jed bash tcpdump wget git proj geos
+#had these installed, didn't work but worked with openjdk8
+pkg install openjdk17
+mount -t fdescfs fdesc /dev/fd
+mount -t procfs proc /proc
+#add following lines to /etc/fstab
+fdesc   /dev/fd         fdescfs         rw      0       0
+proc    /proc           procfs          rw      0       0
+pkg install gmake gdb autoconf libtool curl automake expect
+pkg install libxslt libxml2 bison
+pkg install imagemagick7
+pkg install gdal geos proj pkgconf
+projsync --system-directory --source-id us_noaa
+projsync --system-directory --source-id ch_swisstopo
+pkg install sfcgal json-c
+pkg install cunit iconv
+pkg install protobuf protobuf-c  #needed for building mvt
+ldconfig
+#was going to install postgresql in jail but got lost quickly
+#did these steps to enable jails in future
+sysctl security.jail.sysvipc_allowed=1
+#Make it persistent by adding this line to /etc/sysctl.conf
+security.jail.sysvipc_allowed=1
+#Add this line to /etc/rc.conf
+jail_sysvipc_allow="YES"
+#Enter your jail and install Postgres.
+service postgresql initdb #create data cluster
+edit the /etc/rc.conf
+and add a line
+postgresql_enable="YES"
+pkg update #update available list
+pkg upgrade #upgrades all packages
+pkg info proj  #get details of proj
+pkg install cmake #install needed for building pgrouting and sfcgal in future
+#for code coverage testing
+pkg install lcov
+#for pgtap tests needed for pgrouting
+git clone https://github.com/theory/pgtap.git
+cd pgtap
+gmake
+sudo gmake install
+sudo cpan TAP::Parser::SourceHandler::pgTAP
+sudo gmake installcheck PGUSER=postgres
+# purge upgrade files
+cd /var/db/freebsd-update/files
+rm -rf [0-1]*
+rm -rf [1-3]*
+rm -rf [3-5]*
+rm -rf [5-7]*
+rm -rf [0-9]*
+rm -rf [a-b]*
+rm -rf [a-d]*
+rm -rf [a-h]*
+# install agent jar
+su jenkins
+mkdir bin
+cd bin
+#can't use ssh for launching agent because we need bastion
+# and when using the launch command, doesnt' automatically deploy agent
+curl -sO https://debbie.postgis.net/jnlpJars/agent.jar
+#then on jenkins config use  Launch agent via execution of comman on the controller
+launch command:ssh jenkins at osgeo8-bessie " java -jar /home/jenkins/bin/agent.jar"
diff --git a/raspberry_pi/berrie.txt b/raspberry_pi/berrie.txt
index fb50578..73783f6 100644
--- a/raspberry_pi/berrie.txt
+++ b/raspberry_pi/berrie.txt
@@ -15,4 +15,8 @@ apt install git
 apt install libgeos-dev libproj-dev
 apt install libgdal-dev
-apt install lz4 liblz4-dev #needed to build postgresql with lz4 support
+apt install lz4 liblz4-dev #needed to build postgresql with lz4 support
+#upgrade jdk
+apt install openjdk-17-jdk
+update-alternatives --config java  #switch from 11 to 17
diff --git a/raspberry_pi/berrie64.txt b/raspberry_pi/berrie64.txt
index 3b34aee..feee286 100644
--- a/raspberry_pi/berrie64.txt
+++ b/raspberry_pi/berrie64.txt
@@ -23,3 +23,8 @@ apt install libgdal-dev
 sudo apt install lcov
+#upgrade jdk
Summary of changes:
 debian/reallie.txt             |   2 +
 freebsd/bessie_setup.txt       | 259 -----------------------------------------
 freebsd/osgeo8-bessie_setup.md | 165 ++++++++++++++++++++++++++
 raspberry_pi/berrie.txt        |   6 +-
 raspberry_pi/berrie64.txt      |   5 +
 5 files changed, 177 insertions(+), 260 deletions(-)
 delete mode 100644 freebsd/bessie_setup.txt
 create mode 100644 freebsd/osgeo8-bessie_setup.md
hooks/post-receive
