[PostGIS] #5808: Weird constant ram increase using topology
trac at osgeo.org
Mon Nov 11 01:14:07 PST 2024
Reporter: latot | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.5.1
Component: topology | Version: 3.5.x
Resolution: | Keywords:
Comment (by Lars Aksel Opsahl):
When running with POSTGIS="3.6.0dev 3.5.0-48-g75d9b03d6" I got this error.
I need to retest this.
>ERROR: cache lookup failed for type 15857891
/var/log/postgresql/postgresql-Sun.log.1: ' , using conn
'conn_3813f3afc65243dc84261ac1bfcdfca0_1', state : 'XX000' message:
'cache lookup failed for type 15857891' detail : '' hint : '' context:
'PL/pgSQL assignment "result =
(inputLineEdgeIds,failed_line,face_edges_to_remove_list,_table_input_order,_src_table_pk_column_value,new_line,selected_edge_face_id)"
Below is the log from sar I see now big changes in memory usage.
06:30:00 kbmemfree kbavail kbmemused %memused kbbuffers kbcached
kbcommit %commit kbactive kbinact kbdirty
09:20:03 46870604 63678672 964888 1.47 7648 17284504
11140752 15.04 4167800 13616408 12
09:30:02 54351468 61472872 1873832 2.85 7648 8881104
12203724 16.48 3478428 6845296 71228
09:40:03 54060728 61178664 1959712 2.98 7648 9061380
12277336 16.58 3931872 6653236 56692
09:50:03 54711104 61097120 1918060 2.91 7648 8439672
12248920 16.54 4266792 5664344 54144
10:00:01 52944848 59890084 2431672 3.69 7648 9684532
12721888 17.18 4855788 6823912 70692
10:10:03 52787460 59454200 2868928 4.36 7648 9399136
13156584 17.76 5115464 6714596 69132
10:20:03 53129960 59953140 2368436 3.60 7648 9543828
12665064 17.10 5148836 6324272 65856
10:30:01 52310940 59273088 3049248 4.63 7648 9673892
13336024 18.01 5191960 7076380 60728
10:40:03 52596996 59667752 2515028 3.82 7648 9914588
12799180 17.28 5372904 6593484 86952
10:50:03 52426232 59606796 2446672 3.72 7648 10147756
12736424 17.20 5531712 6614168 45972
11:00:03 51883252 59239916 2616252 3.97 7648 10512920
12925556 17.45 5723168 6960980 105172
11:10:03 52036312 59419436 2306020 3.50 7648 10662740
12610384 17.03 5928948 6596164 88712
11:20:03 51280996 58913852 2694360 4.09 7648 11020636
12973156 17.52 6060100 7206428 85928
11:30:03 51025856 58745296 2818520 4.28 7648 11143464
13103884 17.69 6140960 7357568 54288
11:40:01 50466424 58236232 3224400 4.90 7648 11288644
13495192 18.22 6274660 7775044 93132
11:50:03 46446228 55125096 5304776 8.06 7648 13217260
15581204 21.04 6904708 11144952 120416
12:00:00 45610136 54602196 5497288 8.35 7648 13859348
15707692 21.21 7494788 11377356 44188
12:10:03 44237648 53522212 6236368 9.47 7648 14490436
16397884 22.14 7958108 12270112 74448
12:20:03 43445796 53091948 6220168 9.45 7648 15294224
16391312 22.13 8394292 12622436 60064
12:30:03 43492280 53229880 5805956 8.82 7648 15660896
15975884 21.57 8675324 12300800 24412
12:40:03 43594052 53222528 5817408 8.84 7648 15549396
16049928 21.67 8717608 12155880 22116
12:50:03 39943508 50632364 7559464 11.48 7648 17449480
17776788 24.00 9077192 15427732 96372
13:00:04 39013616 50327196 7371292 11.20 7648 18562680
17549968 23.69 9853320 15544592 97144
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5808#comment:19>
