[SCM] PostGIS branch master updated. 3.5.0-51-g2b7380ec7
Mon Nov 11 07:47:00 PST 2024
the project "PostGIS".
       via  2b7380ec7f2eb0f95b2cbd7bb81674cbda90bd75 (commit)
      from  31a628d75450169ee7979799f2bed386609f2b31 (commit)
revisions in full, below.
commit 2b7380ec7f2eb0f95b2cbd7bb81674cbda90bd75
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Nov 11 10:38:43 2024 +0100
    Add ST_AsRasterAgg aggregate
    Closes #1247
    Includes regress test and documentation
diff --git a/NEWS b/NEWS
index 7040644c3..66c522a19 100644
--- a/NEWS
+++ b/NEWS
@@ -3,12 +3,13 @@ PostGIS 3.6.0
 * Breaking Changes *
-#5799, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)
+  - #5799, make ST_TileEnvelope clips envelopes to tile plane extent (Paul Ramsey)
 * Deprecated signatures *
 * New Features *
-#5784, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use
-      (Maxime Schoemans)
+  - #1247, ST_AsRasterAgg (Sandro Santilli)
+  - #5784, GT-223 Export circ_tree_distance_tree_internal for mobilitydb use
+           (Maxime Schoemans)
diff --git a/doc/reference_raster.xml b/doc/reference_raster.xml
index ac94dd31f..b79b32dce 100644
--- a/doc/reference_raster.xml
+++ b/doc/reference_raster.xml
@@ -2064,6 +2064,88 @@ SELECT ST_AsPNG(
             </refsection>
         </refentry>
+<!-- { ST_AsRasterAgg -->
+      <refentry xml:id="RT_ST_AsRasterAgg">
+            <refnamediv>
+                <refname>ST_AsRasterAgg</refname>
+                <refpurpose>
+                    Aggregate. Renders PostGIS geometries into a new raster.
+                </refpurpose>
+            </refnamediv>
+            <refsynopsisdiv>
+                <funcsynopsis>
+                    <funcprototype>
+                        <funcdef>raster <function>ST_AsRasterAgg</function></funcdef>
+                        <paramdef><type>geometry </type> <parameter>geom</parameter></paramdef>
+                        <paramdef><type>double precision </type> <parameter>val</parameter></paramdef>
+                        <paramdef><type>raster </type> <parameter>ref</parameter></paramdef>
+                        <paramdef><type>text </type> <parameter>pixeltype</parameter></paramdef>
+                        <paramdef><type>double precision </type> <parameter>nodataval</parameter></paramdef>
+                        <paramdef><type>text </type> <parameter>uniontype</parameter></paramdef>
+                        <paramdef><type>boolean </type> <parameter>touched</parameter></paramdef>
+                    </funcprototype>
+                </funcsynopsis>
+            </refsynopsisdiv>
+            <refsection>
+                <title>Description</title>
+                <para>
+Returns a single-band raster containing the rendered version of all incoming
+geometries, each with its associated value.
+                </para>
+                <para role="availability" conformance="3.6.0">Availability: 3.6.0 </para>
+            </refsection>
+            <refsection>
+                <title>Examples</title>
+                <programlisting>
+WITH inp(g,v) AS (
+	VALUES
+		( ST_Buffer(ST_MakePoint(10,0), 10), 1 ),
+		( ST_Buffer(ST_MakePoint(20,0), 10), 2 )
+agg AS (
+	SELECT ST_AsRasterAgg(
+		g,
+		v,
+		ST_MakeEmptyRaster(0,0,0,0,1.0),
+		'8BUI',
+		99,
+		'SUM',
+		true
+	) r
+	FROM inp
+SELECT
+	ST_Width(r) w,
+	ST_Height(r) h,
+	ST_Value(r,'POINT(5 0)') v5_0,
+	ST_Value(r,'POINT(15 0)') v15_0,
+	ST_Value(r,'POINT(25 0)') v25_0
+FROM agg;
+ w  | h  | v5_0 | v15_0 | v25_0
+ 30 | 20 |    1 |     3 |     2
+(1 row)
+                </programlisting>
+            </refsection>
+            <refsection>
+                <title>See Also</title>
+                <para>
+                    <xref linkend="RT_ST_AsRaster"/>,
+                    <xref linkend="RT_ST_DumpAsPolygons"/>,
+                    <xref linkend="RT_ST_Union"/>
+                </para>
+            </refsection>
+        </refentry>
+<!-- ST_AsRasterAgg }-->
             <refentry xml:id="RT_ST_Band">
             <refnamediv>
                 <refname>ST_Band</refname>
@@ -14008,6 +14090,7 @@ ORDER BY val;
                     <para>
                         <xref linkend="geomval"/>,
+                        <xref linkend="RT_ST_AsRasterAgg"/>,
                         <xref linkend="RT_ST_Value"/>,
                         <xref linkend="RT_ST_Polygon"/>,
                         <xref linkend="RT_ST_ValueCount"/>
diff --git a/raster/rt_pg/rtpostgis.sql.in b/raster/rt_pg/rtpostgis.sql.in
index c5e66c7a3..c4f897484 100644
--- a/raster/rt_pg/rtpostgis.sql.in
+++ b/raster/rt_pg/rtpostgis.sql.in
@@ -5,7 +5,7 @@
 -- http://trac.osgeo.org/postgis/wiki/WKTRaster
 -- Copyright (c) 2015-2017 Regina Obe <lr at pcorp.us>
--- Copyright (c) 2009-2023 Sandro Santilli <strk at kbt.io>
+-- Copyright (c) 2009-2024 Sandro Santilli <strk at kbt.io>
 -- Copyright (c) 2009-2010 Pierre Racine <pierre.racine at sbf.ulaval.ca>
 -- Copyright (c) 2009-2010 Jorge Arevalo <jorge.arevalo at deimos-space.com>
 -- Copyright (c) 2009-2010 Mateusz Loskot <mateusz at loskot.net>
@@ -6570,6 +6570,51 @@ CREATE AGGREGATE st_union(raster, text) (
 	FINALFUNC = _st_union_finalfn
+-- ST_AsRasterAgg aggregate
+-- Availability: 3.6.0
+CREATE OR REPLACE FUNCTION _ST_AsRasterAgg_transfn(staterast raster, geom geometry, val float8, rast raster, pixeltype text, nodataval float8, uniontype text, touched boolean)
+RETURNS raster AS $BODY$
+DECLARE
+  tmprast RASTER;
+BEGIN
+  tmprast := @extschema at .ST_AsRaster(geom, rast,
+    pixeltype => pixeltype,
+    value => val,
+    nodataval => nodataval,
+    touched => touched
+  IF staterast IS NULL THEN
+    staterast = tmprast;
+  ELSE
+    SELECT @extschema at .ST_Union(r, uniontype)
+    FROM ( VALUES (staterast), (tmprast) ) AS foo(r)
+    INTO staterast;
+  END IF;
+  RETURN staterast;
+END;
+$BODY$ LANGUAGE 'plpgsql';
+CREATE OR REPLACE FUNCTION _ST_AsRasterAgg_finalfn(rast raster)
+BEGIN
+	RETURN rast;
+END;
+CREATE AGGREGATE ST_AsRasterAgg(geom geometry, val float8, ref raster, pixeltype text, nodataval float8, uniontype text, touched boolean) (
+	SFUNC = _ST_AsRasterAgg_transfn,
+	STYPE = raster,
+	parallel = safe,
+	FINALFUNC = _ST_AsRasterAgg_finalfn
 -- ST_Clip
@@ -6638,7 +6683,7 @@ CREATE OR REPLACE FUNCTION st_clip(
 -- Availability: 2.0.0
 -- Changed: 3.5.0 - added touched parameter
--- Replaces st_clip(raster, geometry, float8[], boolean) deprecated in 3.5.0
+-- Replaces st_clip(raster, geometry, float8[], boolean) deprecated in 3.5.0
 	rast raster,
 	geom geometry,
diff --git a/raster/test/regress/rt_asrasteragg.sql b/raster/test/regress/rt_asrasteragg.sql
new file mode 100644
index 000000000..61af174a3
--- /dev/null
+++ b/raster/test/regress/rt_asrasteragg.sql
@@ -0,0 +1,26 @@
+WITH inp(g,v) AS (
+	VALUES
+agg AS (
+		g, -- geometry
+		v, -- value to render
+		ST_MakeEmptyRaster(0,0,0,0,1.0), -- reference raster, for alignment
+		'8BUI', -- pixel type
+		99, -- nodata value
+		'SUM', -- union operation
+		true -- touch
+	) r
+	FROM inp
+SELECT
+	't1',
+	ST_Width(r) w,
+	ST_Height(r) h,
+	ST_Value(r,'POINT(0 10)', exclude_nodata_value=>false) v0_10,
+FROM agg;
diff --git a/raster/test/regress/rt_asrasteragg_expected b/raster/test/regress/rt_asrasteragg_expected
index 000000000..f9ca7fb13
--- /dev/null
+++ b/raster/test/regress/rt_asrasteragg_expected
@@ -0,0 +1 @@
+t1|30|20|99|1|3|2
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 00918e134..ac17fda9e 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -87,6 +87,7 @@ RASTER_TEST_UTILITY = \
 	$(top_srcdir)/raster/test/regress/rt_gdalwarp \
 	$(top_srcdir)/raster/test/regress/rt_gdalcontour \
 	$(top_srcdir)/raster/test/regress/rt_asraster \
+	$(top_srcdir)/raster/test/regress/rt_asrasteragg \
 	$(top_srcdir)/raster/test/regress/rt_dumpvalues \
 	$(top_srcdir)/raster/test/regress/rt_makeemptycoverage \
 	$(top_srcdir)/raster/test/regress/rt_createoverview
Summary of changes:
 NEWS                                        |  7 +--
 doc/reference_raster.xml                    | 83 +++++++++++++++++++++++++++++
 raster/rt_pg/rtpostgis.sql.in               | 49 ++++++++++++++++-
 raster/test/regress/rt_asrasteragg.sql      | 26 +++++++++
 raster/test/regress/rt_asrasteragg_expected |  1 +
 raster/test/regress/tests.mk                |  1 +
 6 files changed, 162 insertions(+), 5 deletions(-)
 create mode 100644 raster/test/regress/rt_asrasteragg.sql
 create mode 100644 raster/test/regress/rt_asrasteragg_expected
hooks/post-receive
