[SCM] PostGIS branch master updated. 3.5.0-79-g3baef024e
git at osgeo.org
git at osgeo.org
Tue Nov 19 18:47:38 PST 2024
the project "PostGIS".
via 3baef024ebacff32572291c6e6497dcb58306582 (commit)
from 70b0e7a0a6cd9dc0a1a60f073c694e7d410cef3e (commit)
revisions in full, below.
commit 3baef024ebacff32572291c6e6497dcb58306582
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Wed Nov 20 01:23:12 2024 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 100.0% (5756 of 5756 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 8f2ea451c..d692edd3b 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -8,10 +8,10 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-11-19 11:58+0000\n"
-"PO-Revision-Date: 2024-11-18 03:47+0000\n"
+"PO-Revision-Date: 2024-11-20 02:47+0000\n"
"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
-"manual/ja/>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"postgis-manual/ja/>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
@@ -40723,7 +40723,7 @@ msgstr ""
#. Tag: para
#, no-c-format
msgid "Availability: 3.6.0 - requires SFCGAL >= 2.0.0."
-msgstr ""
+msgstr "Availability: 3.6.0 - SFCGAL >= 2.0.0が必要です。"
#. Tag: refpurpose
#, no-c-format
@@ -40741,17 +40741,17 @@ msgid ""
"The <parameter>buffer_type</parameter> specifies the type of buffer to "
"create: 0: Rounded buffer (default) 1: Flat buffer 2: Square buffer"
msgstr ""
-"入力ジオメトリ<parameter>geom</parameter>の周りに指定した<parameter>radius</"
-"parameter>で3次元バッファを生成します。バッファは3次元空間内に生成され、ジオ"
-"メトリの周囲の立体表現を生成します。<parameter>segments</parameter>パラメータ"
-"は、バッファの曲線部の近似分割数を指定するものです。<parameter>buffer_type</"
-"parameter>は、バッファ生成タイプを指定します。0: 曲面バッファ (デフォルト) "
-"1: 平面バッファ 2: 四角バッファ (訳注: ST_Bufferの端点処理を参照して下さい)"
+"入力ジオメトリ<parameter>geom</parameter>の周りに指定した<parameter>radius</p"
+"arameter>で3次元バッファを生成します。バッファは3次元空間内に生成され、ジオメ"
+"トリの周囲の立体表現を生成します。<parameter>segments</parameter>パラメータは"
+"、バッファの曲線部の近似分割数を指定するものです。<parameter>buffer_type</par"
+"ameter>は、バッファ生成タイプを指定します。0: 球形バッファ (デフォルト) 1: "
+"平面バッファ 2: 四角形バッファ (訳注: ST_Bufferの端点処理を参照して下さい)"
#. Tag: para
#, no-c-format
msgid "Availability: 3.6.0 - requires SFCGAL >= 2.0.0"
-msgstr ""
+msgstr "Availability: 3.6.0 - SFCGAL >= 2.0.0が必要です"
#. Tag: para
#, no-c-format
@@ -40760,31 +40760,34 @@ msgid ""
"into <link xlink:href=\"https://postgis.net/docs/support/viewers/x3d_viewer."
"htm\">X3D Viewer</link>."
msgstr ""
+"次の画像はST_AsX3Dクエリの出力を<link xlink:href=\"https://postgis.net/docs/"
+"support/viewers/x3d_viewer.htm\">X3D "
+"Viewer</link>に貼り付けて描画したものです。"
#. Tag: para
#, no-c-format
msgid "segments=32 (rounded buffer)"
-msgstr ""
+msgstr "segments=32 (球形バッファ)"
#. Tag: para
#, no-c-format
msgid "5 segments rounded"
-msgstr ""
+msgstr "5辺 球形"
#. Tag: para
#, no-c-format
msgid "32 segments, round"
-msgstr ""
+msgstr "32辺 球形"
#. Tag: para
#, no-c-format
msgid "32 segments, square"
-msgstr ""
+msgstr "32辺 四角形"
#. Tag: para
#, no-c-format
msgid ", <xref linkend=\"ST_3DConvexHull\"/>, <xref linkend=\"ST_AsX3D\"/>"
-msgstr ""
+msgstr ", <xref linkend=\"ST_3DConvexHull\"/>, <xref linkend=\"ST_AsX3D\"/>"
#. Tag: refpurpose
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 35 +++++++++++++++++++----------------
1 file changed, 19 insertions(+), 16 deletions(-)
hooks/post-receive
