[SCM] PostGIS branch master updated. 3.5.0-88-g4dd7f73bd
Thu Nov 28 05:04:55 PST 2024
the project "PostGIS".
       via  4dd7f73bd97f7747aa38e9cfb6cbb2cd4522a28d (commit)
      from  2d42b2e5531e8ca9d6efe1f22e305d49eb605959 (commit)
revisions in full, below.
commit 4dd7f73bd97f7747aa38e9cfb6cbb2cd4522a28d
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Thu Nov 28 13:02:28 2024 +0000
    Translated PostGIS Manual using Weblate (German)
    Currently translated at 49.5% (2850 of 5756 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/de/
diff --git a/doc/po/de/postgis-manual.po b/doc/po/de/postgis-manual.po
index d6e866099..982d9f4c2 100644
--- a/doc/po/de/postgis-manual.po
+++ b/doc/po/de/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-11-19 11:58+0000\n"
-"PO-Revision-Date: 2024-11-28 09:47+0000\n"
+"PO-Revision-Date: 2024-11-28 13:04+0000\n"
 "Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/de/>\n"
@@ -5803,6 +5803,10 @@ msgid ""
 "existing nodes or edges within given tolerance. Existing edges and faces may "
 "be split as a consequence of the load."
 msgstr ""
+"Lädt eine Geometrie in eine bestehende Topologie. Die gegebene Geometrie "
+"rastet an vorhandenen Knoten oder Kanten innerhalb der angegebenen Toleranz "
+"ein. Vorhandene Kanten und Flächen können als Folge der Belastung geteilt "
+"werden."
 #. Tag: para
 #, fuzzy, no-c-format
@@ -5815,6 +5819,8 @@ msgid ""
 ", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref "
 "linkend=\"TopoGeo_AddPolygon\"/>, <xref linkend=\"CreateTopology\"/>"
 msgstr ""
+", <xref linkend=\"TopoGeo_AddLineString\"/>, <xref linkend="
+"\"TopoGeo_AddPolygon\"/>, <xref linkend=\"CreateTopology\"/>"
 #. Tag: title
 #, no-c-format
Summary of changes:
 doc/po/de/postgis-manual.po | 8 +++++++-
 1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
