[PostGIS] #5813: installcheck does not run tiger geocoder tests
PostGIS trac at osgeo.org
Thu Nov 28 07:13:41 PST 2024
 Reporter:  strk          |      Owner:  strk
     Type:  defect        |     Status:  new
 Priority:  medium        |  Milestone:  PostGIS 3.5.1
Component:  QA/testsuite  |    Version:  3.4.x
 Keywords:                |
 See https://github.com/postgis/postgis/pull/784
 `make installcheck` in top-level dir fails to descend in extensions/ and
 thus misses tiger geocoder checks that are instead run with `make -C
 extensions installcheck`
 This is probably true for old branches as well
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5813>
