[PostGIS] #5564: BRIN indexes cause server crash after continuous autovacuum
trac at osgeo.org
Sun Jan 5 02:10:23 PST 2025
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS Fund Me
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Comment (by robe):
Tested
DROP TABLE IF EXISTS random_points;
CREATE TABLE random_points AS
SELECT ST_MakePoint(0, 0) AS geom FROM generate_series(1, 130_561);
CREATE INDEX ON random_points USING brin(geom);
on:
* PG13, 3.0.12dev
* PG14 3.1.12, 3.6.0dev
* PG15 3.5.0
* PG16 3.5.0
and doesn't crash on those, but 130_561 also gives a syntax error on
PG13-PG15 above. So had to change that to 130561. 130561 crashes on 17
3.5.0 too.
We know this issue only triggers with parallelism enabled, e.g doing this:
SET max_parallel_workers TO 0;
will prevent it from crashing on PG17. So I guess the trivial issue case
only arises on PG17 and higher with parallelism enabled. I presuming
because PG17 is the first version to support parallel builds of BRIN as
noted in the feature matrix -
https://www.postgresql.org/about/featurematrix/#indexing-constraints
"Parallelized CREATE INDEX for BRIN indexes"
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5564#comment:9>
