[PostGIS] #5827: ST_3DDFullyWithin gives wrong result
    trac at osgeo.org
    Sun Jan  5 18:24:23 PST 2025
  Reporter:  nbvfgh    |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  critical  |  Milestone:  PostGIS 3.6.0
 Component:  postgis   |    Version:  3.5.x
Resolution:            |   Keywords:
Comment (by nbvfgh):
 Since there is currently no implementation of 3DContains or 3DWithin (at
 least I haven't seen it in the documentation), I have a simple suggestion.
 For ST_3DDFullyWithin (a, b, dis), you can use ST_3DClosestPoint(a. b) to
 first calculate the cloest point from geometry a to geometry b, then use
 ST_3DMaxDistance(p, b) to calculate the maximum distance from the point p
 to geometry b, and finally compare the obtained distance with dis.
 That is, ST_3DDFullyWithin (a, b, dis) <=>
 ST_3DMaxDistance(ST_3DClosestPoint(a, b), b) <= dis.
 The same applies to 2D.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5827#comment:4>
