[PostGIS] #5830: Bug in ST_Equals for large data volumes
trac at osgeo.org
Mon Jan 6 01:52:18 PST 2025
Reporter: hhinrichs | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone: PostGIS 3.5.2
Component: postgis | Version: 3.5.x
Resolution: | Keywords: st_within, llvm, st_equals
Description changed by hhinrichs:
Old description:
> Hello,
> I ran into an issue running a query that processes a large data volume.
> I suspect the issue is related to https://lists.osgeo.org/pipermail
> /postgis-users/2024-November/046606.html.
> Dummy query that fails:
> SELECT 1 FROM communities c1, communities c2 WHERE ST_Equals(c1.geom,
> c2.geom)
> Dummy query that runs:
> c2.geom) AND c1.gisco_code = 'DE_01001000'
> The error my postgres container logs:
> error: Unknown attribute kind (86) (Producer: 'LLVM16.0.6' Reader: 'LLVM
> 15.0.6')
> I tried to run the failing query on our staging environment where we have
> PostGis 3.4.0 and it runs without any error.
> I was unable to install 3.4.x locally as older versions seem to get
> deleted from the apt repository and installing it from source was pain
> and did not work in the end.
> EDIT: I wanted to attach the data but it exceeds the size limit.
> Should we try to find another way`to exchange it or are you able to
> reproduce the error with a large dataset by yourself?
New description:
Hello,
c2.geom)
c2.geom) AND ST_Intersects(c1.geom, c2.geom)
What also works is
SELECT 1 FROM communities c1, communities c2 WHERE ST_Within(c1.geom,
c2.geom)
15.0.6')
deleted from the apt repository and installing from source I was unable to
Installing it from s.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5830#comment:3>
