[SCM] PostGIS branch master updated. 3.5.0-183-g06bb82e17
git at osgeo.org
git at osgeo.org
Tue Jan 7 10:52:09 PST 2025
the project "PostGIS".
via 06bb82e17a9b43922e40873315dda09c096eac21 (commit)
from 778431a971aaed8ee7a8f31d9d1c55d26f6f8eef (commit)
revisions in full, below.
commit 06bb82e17a9b43922e40873315dda09c096eac21
Author: Regina Obe <lr at pcorp.us>
Date: Tue Jan 7 13:50:42 2025 -0500
pg_upgrade postgis_sfcgal failing
because of missing ST_ConstrainDelaunayTriangles
References #5833 for PostGIS 3.6.0
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 0e6424e79..61ebe0842 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -46,7 +46,7 @@ SQL_OBJS = \
# Objects to build using PGXS
-OBJS = lwgeom_sfcgal.o
+OBJS = lwgeom_sfcgal.o postgis_sfcgal_legacy.o
# Libraries to link into the module (proj, geos)
diff --git a/sfcgal/postgis_sfcgal_legacy.c b/sfcgal/postgis_sfcgal_legacy.c
new file mode 100644
index 000000000..cbd669928
--- /dev/null
+++ b/sfcgal/postgis_sfcgal_legacy.c
@@ -0,0 +1,55 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS. If not, see <http://www.gnu.org/licenses/>.
+ * Copyright (C) 2025 Regina Obe <lr at pcorp.us>
+ * This file is to hold functions we no longer use,
+ * but we need to keep because they were used at one time behind SQL API functions.
+ * This is to ease pg_upgrade upgrades
+ * All functions in this file should throw an error telling the user to upgrade
+ * the install
+#include "postgres.h"
+#include "utils/builtins.h"
+#include "../postgis_config.h"
+#include "lwgeom_pg.h"
+#define POSTGIS_DEPRECATE(version, funcname) \
+ Datum funcname(PG_FUNCTION_ARGS); \
+ PG_FUNCTION_INFO_V1(funcname); \
+ Datum funcname(PG_FUNCTION_ARGS) \
+ ereport(ERROR, (\
+ errcode(ERRCODE_FEATURE_NOT_SUPPORTED), \
+ errmsg("A stored procedure tried to use deprecated C function '%s'", \
+ __func__), \
+ errdetail("Library function '%s' was deprecated in PostGIS %s", \
+ __func__, version), \
+ errhint("Consider running: SELECT postgis_extensions_upgrade()") \
+ PG_RETURN_POINTER(NULL); \
+POSTGIS_DEPRECATE("3.4.0", ST_ConstrainedDelaunayTriangles)
\ No newline at end of file
Summary of changes:
sfcgal/Makefile.in | 2 +-
.../postgis_sfcgal_legacy.c | 47 ++++++++++------------
2 files changed, 22 insertions(+), 27 deletions(-)
copy raster/rt_pg/rtpg_legacy.c => sfcgal/postgis_sfcgal_legacy.c (57%)
hooks/post-receive
