[PostGIS] #5564: BRIN indexes cause server crash after continuous autovacuum
PostGIS trac at osgeo.org
Fri Jan 17 20:19:54 PST 2025
  Reporter:  robe     |      Owner:  pramsey
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.4.5
 Component:  postgis  |    Version:  3.1.x
Resolution:  fixed    |   Keywords:
Changes (by Regina Obe <lr@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"a02435c7900f515956c51ae4f6b2860f998c668a/git" a02435c/git]:
 {{{#!CommitTicketReference repository="git"
 revision="a02435c7900f515956c51ae4f6b2860f998c668a"
 BRIN Merge Support
   - Add merge AM support function (11) for all BRIN operator class
     families. Supports parallel BRIN build on PG17+
     and in general should fix some longstanding low-probability crash
     cases related to BRIN.
  - Add upgrade logic to shimmy in the brin_inclusion_merge functions
  - Add crash tests
 Closes #5564 for PostGIS 3.4.5
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5564#comment:15>
