[PostGIS] #5840: Reversed order of input for topology.TopoGeo_addLinestring many times faster for a test case
trac at osgeo.org
Thu Jan 23 07:33:24 PST 2025
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.5.3
Component: topology | Version: 3.5.x
Keywords: |
When running the overlay below code below, where we have 3 input datasets.
CALL topo_rog_static.rog_overlay(
ARRAY[
'sl_hfm.reguleringsplan_omrade omrade',
'sl_hfm.reguleringsplan_rb_formal rb_formal',
'sl_hfm.reguleringsplan_rp_formal rp_formal'
], --input tables
'sl_hfm_regplan_01.res_01'::text -- result table name
The job is split into 1393 cells (temp topology cells) where 15 workers
was running in parallel , one cell was using a very long time (2203
seconds )to add 501 lines.
NOTICE: Done with 501 number of add_border_lines for _box_id 529 to temp
topollogy (number of failed lines <NULL>), number edges to remove <NULL>,
phase 0 for topology sl_hfm_regplan_01_topo_529 with tolerance 0 at
2025-01-23 10:38:59.365515+01 used_time: 2203.7744
On this server we have postgis version
POSTGIS="3.6.0dev 3.5.0-180-g04ef40af3" [EXTENSION] PGSQL="160"
GEOS="3.13.0-CAPI-1.19.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
URL_ENDPOINT=https://cdn.proj.org
USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 8.2.1)
LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
(Internal)" TOPOLOGY
I did some more digging and problem and I found 4 big geom where 1 and 2
are almost equal and 3 and 4 are almost equal.
I tested this geom on my local mac running and confirmed a lot time was
spent here.
POSTGIS="3.6.0dev 3.5.0-191-g09b3419dc" [EXTENSION] PGSQL="160"
GEOS="3.13.0-CAPI-1.19.0" PROJ="9.5.1 NETWORK_ENABLED=OFF
USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
DATABASE_PATH=/opt/homebrew/Cellar/proj/9.5.1/share/proj/proj.db"
(compiled against PROJ 9.5.1) LIBXML="2.13.0" LIBJSON="0.18" (core procs
from "3.5.0dev 3.4.0rc1-1272-g80806376a" need upgrade) TOPOLOGY (topology
procs from "3.5.0dev 3.4.0rc1-1272-g80806376a" need upgrade)
And this lines was taking almost 10 minutes to add using the code below
-- from files testcases_sortorder.sql
-- lines for testcase 1
SELECT
topology.TopoGeo_addLinestring('tmp_dyrkbarjord_14_topo_006_5591','0102000......
(1 row)
Time: 47,809 ms
(3 rows)
Time: 21,493 ms
(4 rows)
Time: 32,742 ms
(2164 rows)
Time: 466148,919 ms (07:46,149)
The I reversed the order off adding the lines, like this and this takes
less that a minute .
-- lines for testcase 2
SELECT
topology.TopoGeo_addLinestring('tmp_dyrkbarjord_14_topo_006_5591','01020000
(1 row)
Time: 15,901 ms
(2162 rows)
Time: 36258,478 ms (00:36,258)
(6 rows)
Time: 338,154 ms
(8 rows)
Time: 34,628 ms
So I implemented the same sorting order in topo_rog_static.rog_overlay and
the execution time was down with more than 20 minutes to 48 minutes for
the total job.
But when we just check the above problem cell on the original prod server
with the new code we see this.
NOTICE: Done with 501 number of add_border_lines for _box_id 430 to temp
phase 0 for topology sl_hfm_regplan_01_topo_430 with tolerance 0 at
2025-01-23 13:53:53.790329+01 used_time: 19.044277
So we are down from 2203 seconds to 20 seconds for this cell with this
commit[https://gitlab.com/nibioopensource/resolve-overlap-and-
gap/-/commit/cd4b23af920737bd48b7e1d0f43b08474315fcb7] , this was
surprisingly fast.
I think the reason why we are not down by more than 20 minutes in
topo_rog_static.rog_overlay is that things are running parallel and that
the slow cell started early.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5840>
