[PostGIS] #5840: Reversed order of input for topology.TopoGeo_addLinestring many times faster for a test case
trac at osgeo.org
Thu Jan 23 08:19:57 PST 2025
Reporter: Lars Aksel Opsahl | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.5.3
Component: topology | Version: 3.5.x
Resolution: | Keywords:
Description changed by Lars Aksel Opsahl:
Old description:
> When running the overlay below code below, where we have 3 input
> datasets.
> CALL topo_rog_static.rog_overlay(
> ARRAY[
> 'sl_hfm.reguleringsplan_omrade omrade',
> 'sl_hfm.reguleringsplan_rb_formal rb_formal',
> 'sl_hfm.reguleringsplan_rp_formal rp_formal'
> ], --input tables
> 'sl_hfm_regplan_01.res_01'::text -- result table name
> The job is split into 1393 cells (temp topology cells) where 15 workers
> was running in parallel , one cell was using a very long time (2203
> seconds )to add 501 lines.
> NOTICE: Done with 501 number of add_border_lines for _box_id 529 to temp
> topollogy (number of failed lines <NULL>), number edges to remove <NULL>,
> phase 0 for topology sl_hfm_regplan_01_topo_529 with tolerance 0 at
> 2025-01-23 10:38:59.365515+01 used_time: 2203.7744
> On this server we have postgis version
> POSTGIS="3.6.0dev 3.5.0-180-g04ef40af3" [EXTENSION] PGSQL="160"
> GEOS="3.13.0-CAPI-1.19.0" PROJ="8.2.1 NETWORK_ENABLED=OFF
> URL_ENDPOINT=https://cdn.proj.org
> USER_WRITABLE_DIRECTORY=/var/lib/postgresql/.local/share/proj
> DATABASE_PATH=/usr/share/proj/proj.db" (compiled against PROJ 8.2.1)
> LIBXML="2.9.13" LIBJSON="0.15" LIBPROTOBUF="1.3.3" WAGYU="0.5.0
> (Internal)" TOPOLOGY
> I did some more digging and problem and I found 4 big geom where 1 and 2
> are almost equal and 3 and 4 are almost equal.
> I tested this geom on my local mac running and confirmed a lot time was
> spent here.
> POSTGIS="3.6.0dev 3.5.0-191-g09b3419dc" [EXTENSION] PGSQL="160"
> GEOS="3.13.0-CAPI-1.19.0" PROJ="9.5.1 NETWORK_ENABLED=OFF
> USER_WRITABLE_DIRECTORY=/Users/lop/Library/Application Support/proj
> DATABASE_PATH=/opt/homebrew/Cellar/proj/9.5.1/share/proj/proj.db"
> (compiled against PROJ 9.5.1) LIBXML="2.13.0" LIBJSON="0.18" (core procs
> from "3.5.0dev 3.4.0rc1-1272-g80806376a" need upgrade) TOPOLOGY (topology
> procs from "3.5.0dev 3.4.0rc1-1272-g80806376a" need upgrade)
> And this lines was taking almost 10 minutes to add using the code below
> -- from files testcases_sortorder.sql
> -- lines for testcase 1
> SELECT
> topology.TopoGeo_addLinestring('tmp_dyrkbarjord_14_topo_006_5591','0102000......
> (1 row)
> Time: 47,809 ms
> (3 rows)
> Time: 21,493 ms
> (4 rows)
> Time: 32,742 ms
> (2164 rows)
> Time: 466148,919 ms (07:46,149)
> The I reversed the order off adding the lines, like this and this takes
> less that a minute .
> -- lines for testcase 2
> SELECT
> topology.TopoGeo_addLinestring('tmp_dyrkbarjord_14_topo_006_5591','01020000
> (1 row)
> Time: 15,901 ms
> (2162 rows)
> Time: 36258,478 ms (00:36,258)
> (6 rows)
> Time: 338,154 ms
> (8 rows)
> Time: 34,628 ms
> So I implemented the same sorting order in topo_rog_static.rog_overlay
> and the execution time was down with more than 20 minutes to 48 minutes
> for the total job.
> But when we just check the above problem cell on the original prod server
> with the new code we see this.
> NOTICE: Done with 501 number of add_border_lines for _box_id 430 to temp
> phase 0 for topology sl_hfm_regplan_01_topo_430 with tolerance 0 at
> 2025-01-23 13:53:53.790329+01 used_time: 19.044277
> So we are down from 2203 seconds to 20 seconds for this cell with this
> commit[https://gitlab.com/nibioopensource/resolve-overlap-and-
> gap/-/commit/cd4b23af920737bd48b7e1d0f43b08474315fcb7] , this was
> surprisingly fast.
> I think the reason why we are not down by more than 20 minutes in
> topo_rog_static.rog_overlay is that things are running parallel and that
> the slow cell started early.
New description:
When running the overlay below code below, where we have 3 input datasets.
ARRAY[
], --input tables
spent here.
SELECT
(1 row)
Time: 47,809 ms
(3 rows)
Time: 21,493 ms
(4 rows)
Time: 32,742 ms
(2164 rows)
SELECT
(1 row)
Time: 15,901 ms
(2162 rows)
(6 rows)
Time: 338,154 ms
(8 rows)
Time: 34,628 ms
So I implemented the same sorting order in topo_rog_static.rog_overlay and
the execution time was down with more than 20 minutes to 48 minutes for
the total job.
NOTICE: Done with 544 number of add_border_lines for _box_id 529 to temp
2025-01-23 17:08:37.089278+01 used_time: 194.6801
So we are down from 2203 seconds to 200 seconds for this cell with this
gap/-/commit/cd4b23af920737bd48b7e1d0f43b08474315fcb7] and that coorsponds
well to the test above.
(The number of rows are different because after a certain time the server
return to caller and starts a new job to add rest of the lines)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5840#comment:1>
