[SCM] PostGIS branch master updated. 3.5.0-201-g2a3669666
    git at osgeo.org
    git at osgeo.org
    Mon Jan 27 13:33:00 PST 2025
the project "PostGIS".
       via  2a36696661a000b1bfb775a9c61ff441667a7315 (commit)
       via  54219526a6c937179d1ce0afea79e64a9c755bf5 (commit)
      from  cc75b983ed9e36b4124e108141e5c638f4da1a6a (commit)
revisions in full, below.
commit 2a36696661a000b1bfb775a9c61ff441667a7315
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Jan 27 22:12:42 2025 +0100
    Add check-spell Makefile target and hook it to "check" one
    Skips the test if codespell is not installed.
    Install codespell in gitlab-ci, to enable those tests.
diff --git a/.codespellrc b/.codespellrc
index 05df63a69..daf57c70c 100644
--- a/.codespellrc
+++ b/.codespellrc
@@ -1,3 +1,3 @@
 [codespell]
-skip = *.sql,*.po,spatial_ref_sys.sql,./deps,./extras/tiger_geocoder/tables/lookup_tables_2011.sql,./extras/tiger_geocoder/pagc_normalize/pagc_tables.sql,./extensions/address_standardizer,./configure,./macros/*.m4,./autom4te.cache,./build-aux,./libtool,./extensions/postgis_tiger_geocoder/*.in,.git,build*
+skip = *.sql,*.po,spatial_ref_sys.sql,./deps,./extras/tiger_geocoder/tables/lookup_tables_2011.sql,./extras/tiger_geocoder/pagc_normalize/pagc_tables.sql,./extensions/address_standardizer,./configure*,./macros/*.m4,./autom4te.cache,./build-aux,./libtool,./extensions/postgis_tiger_geocoder/*.in,.git,build*
 ignore-words = .codespell.ignore
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index 376d2e336..ee4d9d870 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -4,6 +4,7 @@
   before_script:
     - apt-get update -qq && apt-get install -y
         autoconf
+        codespell
         bison
         build-essential
         docbook-xsl-ns
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 2d8898364..2b2b68fb2 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -78,7 +78,7 @@ clean-local:
 # TODO: drop 'test' target..
 test: check
-check: check-unit docs-check check-lint
+check: check-unit docs-check check-lint check-spell
 ifeq (@SUPPORT_POSTGRESQL@,yes)
 check: check-regress
@@ -304,3 +304,10 @@ ifeq (@TOPOLOGY@,topology)
 	$(MAKE) -C topology/test $@
 endif
+check-spell:
+ifneq (@CODESPELL@,)
+	cd $(top_srcdir) && @CODESPELL@
+else
+	@echo "SKIP: codespell not installed, cannot check spell"
+endif
diff --git a/configure.ac b/configure.ac
index ed5d17255..ccb778064 100644
--- a/configure.ac
+++ b/configure.ac
@@ -186,6 +186,11 @@ case $host_os in
 esac
 AC_SUBST([MINGWBUILD])
+AC_PATH_PROG([CODESPELL], [codespell], [])
+if test "x$CODESPELL" = "x"; then
+	AC_MSG_WARN([codespell is not installed so spelling cannot be checked])
+fi
 AC_PATH_PROG([PERL], [perl], [])
 if test "x$PERL" = "x"; then
         AC_MSG_ERROR([Perl was not found. Building PostGIS requires Perl.])
Summary of changes:
 .codespell.ignore | 14 ++++++++------
 .codespellrc      |  2 +-
 .gitlab-ci.yml    |  1 +
 GNUmakefile.in    |  9 ++++++++-
 configure.ac      |  5 +++++
 5 files changed, 23 insertions(+), 8 deletions(-)
hooks/post-receive
